What's leaking ?
Discussion in 'Motor' started by Jwooky, Mar 20, 2016.
  1. Jwooky
    Jwooky Well-Known Member
    Full Member
    Oxford, MI
    2008 Mastiff EFI
    JJ
    I haven't put much effort into figuring this out, but thought I would share before I tear into it since I have so many things going on the bike and could use a head start and maybe get the parts on the way from WSW.
    While working on everything else I saw this. Rocker box, valve cover, not sure. This is the rear cylinder.
    @KaptinAmerika , @john sachs
    #1 Jwooky, Mar 20, 2016
    chubs likes this.
  2. Brew
    Brew Troop Supporter
    Washington State
    08 Mastiff / 09 Softail Deluxe
    Rob
    Rocker box gaskets!
    chubs, dentdude36 and pknowles like this.
  3. Jwooky
    Full Member
    Oxford, MI
    2008 Mastiff EFI
    JJ
    Wth....why?
    Sure looks like it. Hopefully Curtis has them.
  4. BigDogBro1
    BigDogBro1 Made in the USA
    Near Hell MI
    07 Bulldog, full chrome, Pergy w/gold leaf paint, V&H BR pipes, Gator & Ostrich seats
    Rocker box gasket or O-rings.
    chubs likes this.
  5. Jwooky
    Full Member
    Oxford, MI
    2008 Mastiff EFI
    JJ
    What o rings you referring to?
  6. liferider
    liferider Guru
    Full Member
    Louisiana
    Jonathan
    Get rocker box gasket set also exhaust flange gasket set
    chubs, dentdude36 and Bdm4ever like this.
  7. Bowhunter
    Bowhunter Well-Known Member
    Full Member
    Oliver Springs, Tn.
    2009 K9
    Steve
    I just did the same repair on Postman's bike, the gasket between the cylinder and the rocker box is blown. You can take care of it with the engine still in the frame if you are willing to cut a few allen wrenches and are mechanically inclined.
    As Curtis at Wild Steed pointed out, this can be performed without collapsing the pushrods by removing the pushrod covers and rotating the cylinder until the piston is at Top Dead Center. At this point you can remove the rocker assembly and the rocker boxes. Reassembly is effortless since you will not have to readjust the pushrods. Good luck, lots of help available on this forum.
    Tomtang aka Reptilejim and chubs like this.
