WHAT TO DO IF THE STARTER WON'T TURN
Discussion in 'How-To' started by Moespeeds, Mar 24, 2011.
  1. Coolbreezin
    Coolbreezin Active Member
    Full Member
    Northeast FL
    05 Ridgeback
    Pete
    Hello,
    I was getting the click sound also, this site said to ck the solenoid. I decided to replace the guts just to be sure it wasnt the problem. I installed the slam button form WildSteelWorx. I read somewhere on here that the key is no longer needed to start the bike if it has the button. Thats another subject. Anyway, without the key, I pressed the slam button and the engine spun over about 10 times fast. I then inserted the key and tried the slam button again...now the starter seems to be hung up on something. It doesnt turn over at all. I believe the hang up is mechanical, not electrical. But everything seems to sound like normal. I tried to start button on the bars and same problem. Im going to figure it out tomorrow, but some advice would be greatly appreciated. Thank you.
    chubs likes this.
  2. Coolbreezin
    Full Member
    Northeast FL
    05 Ridgeback
    Pete
    I spoke to another rider and he explained that the piston stops at the point where the most resistance is...the compression stroke. So that explains why it seems to "hang up". My questions is how do you guys get the slam button to turn the motor over? Ive been pushing one of the compression releases down while I initially hit the slam button. Any ideas? Thank you.
    chubs likes this.
  3. Moespeeds
    Moespeeds Well-Known Member
    Cherry Hill, NJ
    2004 Big Dog Chopper, 2011? Redneck Monoshock, 2003 Roadstar Midnight, 2000 Roadstar Custom
    Wire the compression releases to the post on the starter side of the assembly. In the last picture that says "use a wire not your fingers" it's the post that my thumb is resting on. Now whenever you hit the slam button, and as long as it is held down, the compression releases will stay open.
    chubs and francoblay1 like this.
  4. Coolbreezin
    Full Member
    Northeast FL
    05 Ridgeback
    Pete
    I do not have a wiring diagram for my bike. As Moespeeds directed, Im wanting to attach my comp release wire to the starter post. My question for yall is, can anyone tell me which wire is the correct one? If you have a picture of the wire/harness that would be most helpful. Thank you for your help.
    chubs likes this.
  5. Coolbreezin
    Full Member
    Northeast FL
    05 Ridgeback
    Pete
    Does anyone know which wire is the one Im to attach to the solenoid post so my comp releases open when I hit the slam button? Thank you in advance for your help.
    chubs likes this.
  6. KaptinAmerika
    KaptinAmerika Well-Known Member
    Full Member
    2006 Big Dog K9
    Curtis
    So is Moe saying disconnect the comp release wore from the EHC circuit and wrote it directly to the starter post?
    chubs likes this.
  7. Coolbreezin
    Full Member
    Northeast FL
    05 Ridgeback
    Pete
    Hey Kapt. Thats just it, Im a little lost as to where this "comp release wire" is. I dont have a wire diagram so I have absolutely no idea where to start. My electrical knowledge is minimal, but I could accomplish the task if given a little more direction.
    chubs likes this.
  8. Moespeeds
    Cherry Hill, NJ
    Do a forum or google search for the wiring diagram for your bike. Or just cut the wires up at the compression releases and run new wires down to the starter. The idea behind this is that when you press the slam button, it closes the switch and energizes the starter motor side post. If you wire the compression releases to this post, then every time the post is energized, and the starter motor is turning, the compression releases will open.
    chubs likes this.
  9. Moespeeds
    Cherry Hill, NJ
    And your bike will not start with the ignition off. You can turn over the starter, but without the key in and the run button pressed, the plugs will not fire.
    chubs likes this.
  10. Coolbreezin
    Full Member
    Northeast FL
    05 Ridgeback
    Pete
    Moespeeds, thank you for the quick reply.
    1) I figured the comment of starting w/o the key was odd. I didnt believe it but Im not verse in the v-twin world. So the engine/tranny/starter design is still somewhat uncharted territory for me.
    2) I appreciate you and Kapt jumping in and helping me. I did find another thread in here that shows the connection number on the EHC. I think Ill take yr advice and rewire from the comp release area.
    chubs likes this.
  11. Coolbreezin
    Full Member
    Northeast FL
    05 Ridgeback
    Pete
    wire gauge for comp releases
    Anyone out there offer a little advice on the gauge wire to use to rewire the comp releases? I looked very close at the wires coming from my heads and also asked a NAPA guy what he thought they may be. It appears the insulation and opaque cover over the wires gives the impression that they are a much heavier gauge.
    chubs likes this.
  12. Moespeeds
    Cherry Hill, NJ
    18ga is fine
    chubs likes this.
  13. spadesluck
    spadesluck Active Member
    New Mexico
    05 Chopper DT
    Jason
    i just rewired my compression releases over the weekend. I used 18ga wire no problem.
    chubs likes this.
  14. francoblay1
    francoblay1 The Spaniard
    Full Member
    LĀ“Escala, 17130 Spain
    K9 (2006)
    Franco
    Guys,
    Could you do a "How To" on this subject? It would be awesome! :up:
    Big D Florida and chubs like this.
  15. Coolbreezin
    Full Member
    Northeast FL
    05 Ridgeback
    Pete
    Hello all,
    Just wanted to say thanks for the info regarding my rewiring my C/R's. Did it this morning and it works like a champ. Hopefully this resolves my breaking jackshafts.
    chubs likes this.
  16. Moespeeds
    Cherry Hill, NJ
    If you're breaking jackshafts make sure your ring gear is in good condition, and the starter is not cracked at either of the two ears where the bolts attach it to the inner primary.
    chubs likes this.
  17. Coolbreezin
    Full Member
    Northeast FL
    05 Ridgeback
    Pete
    Tampa BDM determined the inner primary case (hole for pinion gear) was not cut correctly and it cause the jackshaft to wobble (so to speak) when I pressed the Start button. This R&R was after 7 starter replacements. Since then Ive broken 4 more jackshafts due to my own carelessness (rolling while starting, so on). However, and I feel this is odd, but I have not had a single "slam" sound or broken shaft since I got the slam button. My Starter button died, so the slam button is my primary Start button now.
    chubs likes this.
  18. Moespeeds
    Cherry Hill, NJ
    When you start the bike the conventional way, with the button on the handlebars, you may not get a good positive engagement. Anyone who has ever taken the side cover off their starter sees how the copper contacts are covered with arc strikes and soot from poor or partial engagement. This transfers all the way to the end of that jackshaft which could end up skipping across the ring gear teeth. The best way to start a big bike is with that slam button. As long as there is enough juice, the starter has no choice but to turn, and the jackshaft is held firmly in place by the pressure you put on the button.
    chubs likes this.
  19. Coolbreezin
    Full Member
    Northeast FL
    05 Ridgeback
    Pete
    Well said Moespeed, and that is exactly what I am experiencing. So I gave up on the Start button.
    chubs likes this.
  20. jdotto
    jdotto Member
    verona ontario
    big dog k9
    this forum always has an answer!
    thanks for the information.my 07 k9 was acting up today.followed your instructions and i guess i need a starter. could be worse.Can they be rebuilt? thanks again:up:
    chubs likes this.
