What Jets Do You Run?
Discussion in 'Fuel / Air' started by BadBrad, Aug 6, 2009.
  1. StreetHog
    StreetHog Active Member
    Scott City, Kansas
    2012 HD Street Glide, 2007 BD K9
    Pat
    I wondered about the air bleed. I currently don't have any 60's but I did go with a 36 pilot and 80 main. Now it seems to be spot on and the midrange dead spot is gone. BTW...the aux float plug is still in. Seems to run fine now but what the hell does this do if I remove this plug????
    francoblay1 likes this.
  2. mml03102
    mml03102 Active Member
    NH
    2006 big dog pitbull
    Marc
    I WAS HAVING PROBLEMS AFTER PUTTING ON THE SPIKED AIR CLEANER AND I ALSO HAVE THE 2 INTO TO BUT WITH BAFFLES , WITH THE ADVISE OF R AND R CYCLES THEY ADVISED A 33 INTERMEDIATE AND A 78 MAIN AND IT HOLDS STEADY AT HIGH AND LOW SPEEDS . I DID NOT CHANGE THE AIR BLEED.
    IM NOT A TECH , THAT WAS JUST MY EXPERIENCE IS ALL.
  3. francoblay1
    francoblay1 The Spaniard
    L´Escala, 17130 Spain
    K9 (2006)
    Franco
    Here ya go http://www.bigdogbiker.com/threads/aux-bowl-vent-screw.47662/
    #43 francoblay1, Jul 7, 2014
  4. francoblay1
    K9 (2006)
    Franco
    Inter 32 <3K rpm
    Main 78 >3K & up rpm...
  5. StreetHog
    Scott City, Kansas
    Pat
    Good enuff, but...
    I'm good with removing the vent plug but I assume I have to rejet the damn thing again after removing it??? Seriously thinking about putting the stock S&S intake on it. Thinking my Wimmer intake is just to look at. This bike definitely has to be alot fatter than my other one. 32/78 vs 36/80 :bang:
  6. francoblay1
    K9 (2006)
    Franco
    NO, no need to re-jet.
    #46 francoblay1, Jul 8, 2014
  7. StreetHog
    Scott City, Kansas
    Pat
    This jet combo seems pretty fat to me but I checked plugs both above and under 3K. Tan....perfect. Went to the pump and 47 mpg. It's done :D
  8. francoblay1
    K9 (2006)
    Franco
    Cool! :2thumbs: :cheers:
  9. donk
    donk New Member
    29.5 /78 real bad spot at 3500 rpms. They got it on the Dyno right now and I guess they put an 88 main in and not sure with the intermediate. It's got l.a.f drag pipes on it also. If anyone knows a good setup that would be great.
  10. francoblay1
    K9 (2006)
    Franco
    Well.... it´s getting HOT here.... went down to 31 & 76 :whoop:
  11. boostlife7
    boostlife7 Member
    So what do you suggest for my 2003 pitbull with 107S&S drag pipes and K&N filter one and a while I'll give it throttle and it will pop or will just removing my vent bowl screw work
  12. francoblay1
    K9 (2006)
    Franco
    It is not that easy to say it just like that.... what elevation are you at? Te,temperature is a big factor and every bike is different (just a bit).
    You need to find her sweet spot.
    Big D Florida, chubs and BWG56 like this.
  13. 07k9skull
    07k9skull Member
    Utah
    07k9
    Dave
    36
    78
    chubs likes this.
  14. francoblay1
    K9 (2006)
    Franco
    2006 K9 @ Sea level
    32/78
    60 Air Bleed
    xXx Booster kit
    D&M cone, Vertical
    TH Programable Ignition (#3)
    585 Cam
    V&H 2-2, with BCT Baffles.
    :chopper:
    Big D Florida likes this.
  15. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Holy moly, are ya sure?
  16. francoblay1
    K9 (2006)
    Franco
    about??? :oldconfused:
  17. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Post 53 and 57 and to stay on topic I run 33/78
  18. francoblay1
    K9 (2006)
    Franco
    Hummm.... yes, I was sure in 2015 and still I am now in 2018.
    Carburator bikes will run richer in summer and/or at higher altitud than in winter and/or at sea level.
    Cold air and hot air are different densities, therefore your bike that was perfectly tuned for winter feels all sluggish on a hot day and your bike that runs crisply in summer will run lean in winter. Unless you adjust... 1/4 of a turn it does it for me.
    I don´t get your point.
  19. SEAL-rider
    SEAL-rider Active Member
    Del Mar, CA
    2005 Big Dog Chopper 600 cam, John Sachs Super G Carb, V&H Big Radius
    Spencer
    Sachs bored Super G -
    2005 117 - 585 cam
    V&H Big Radius pipes
    31/74-Thunderjet
  20. liferider
    liferider Guru
    Louisiana
    Jonathan
    Jetting for me is a thing of the past!!!!! B83377C3-7271-456D-8EA1-C68D65E068A4.png
    francoblay1 and pknowles like this.
