What Jets Do You Run?
Discussion in 'Fuel / Air' started by BadBrad, Aug 6, 2009.
  1. toomanybikes
    toomanybikes not enough time 4 riding
    Sterling, VA
    2006 Big Dog Mastiff, 1992 Yamaha FJ1200. 2012 Screamin' Eagle Street Glide, 2014 HD Breakout
    Stephen, but I will answer to Steve
    After a few mods (xXx carb, Thunderheart ignition, S&S 600 cam, S&S 2 into exhaust) I am running a 32 intermediate and a 78 main.
  2. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    32 & 78 with VH 2 into2, S&S Dual runner and .585
  3. Tom Chop
    Tom Chop Active Member
    Cottondale, Alabama
    `06 K-9
    Tom aka Tom Chop
    '06-K9, 117cu.in. S&S Super "G", V&H 2/2 with full baffles, Speed`s Performance Plus 90deg. Intake facing foreward, 120-350ft. above sea level, #80 H/S, #32 Intermediate. Fuel Bowl Bleed #80, Accelerator Pump Screw backed out almost all of the way.
    I'm getting 36 to 38 mpg. and making good power with no spitting or coughing. Throttle response is immediate and strong.
    #23 Tom Chop, Feb 24, 2013
  4. toolmaker
    toolmaker New Member
    Near Flint MI
    Big Dog- Bull Dog 2001
    Dave
    I seem to be the only one running a Mikuni carb. I have a TP 107, K&N round air cleaner, hooker 2 into 1 with adjustable baffle running wide open, 22.5 pilot jet, 175 main, standard needle in middle slot, idle adjustment set at 1.75, with accelerator pump set at 0 for immediate activation.
    Runs great.
    Dave
  5. Srodden
    Srodden Well-Known Member
    Flint, Michigan
    2011 mastiff, 2013 deluxe
    Scott
    05 mastiff original cam V&H 2 into 2 29.5 and 71
  6. ZeDevil
    ZeDevil Member
    Bucharest, ROMANIA
    '03 Chopper / RT
    David
    03 Chopper @ Sea level,
    32 int and 80 main ,
    V&H Shortshots Staggered exhaust,
    everything else is stock.
  7. francoblay1
    francoblay1 The Spaniard
    L´Escala, 17130 Spain
    K9 (2006)
    Franco
    @ Sea level
    32/78
    60 Air Bleed
    xXx Booster kit
    D&M cone, Vertical
    TH Programable Ignition (#3)
    585 Cam
    V&H 2-2, with BCT Baffles.
    :2thumbs:
    #27 francoblay1, Aug 31, 2013
  8. Germanbiker
    Germanbiker Active Member
    08 Pitbull / 13 MV Agusta Brutale RR
    34 (custom made by Bob Maltz)/82
    bored xXx Carb
    highly modded air filter case with K&N 3323
    585 Cam
    Penzl exhaust with X pipe (EC legal)
    NOT running rich!!
    francoblay1 likes this.
  9. francoblay1
    K9 (2006)
    Franco
    What elevation are you at? (from Sea Level)
  10. Germanbiker
    app. 250 m. But temperatures here are much less than in Spain (I suppose).
    Jochen
  11. francoblay1
    K9 (2006)
    Franco
    Yup, the colder the air is, the bike runs leaner. :2thumbs:
  12. haze324
    haze324 Active Member
    Miami
    03 Chopper
    I have a stock 03 Chop. Recently changed the S&S air filter to a K&N and had some decel popping, and loss of throttle response. Bike had stock jets 29.5 and 70 and ran great with S&S filter, plugs were a tad light, but bike ran great.
    So I bumped them both up to 31 and 72. Immediately the decel popping was gone and throttle response was back. However, seat of my pants, I don't think there is any difference with the K&N....in fact I think it ran a tad harder/faster with the other filter and jets. Perhaps I just need to get the carb just right. Bike does run really good right now, just not sure if it's any better than before? I'll probably just leave it as is...and send the carb to XXX soon! :)
  13. francoblay1
    K9 (2006)
    Franco
    :2thumbs: :D
    #33 francoblay1, Sep 10, 2013
  14. zenBD
    zenBD Active Member
    Deland, Fl 32724
    08 K9 & 2015 Ducati Diavel
    Matt
    Hey guys... I'm in Fl... getting some popping on decel... Running stock carb/air cleaner & VH 2-2 big radius. I had Carl's Speed Shop jet the carb for the pipes. They basically told me "they just do that with that set up" when I asked them how to eliminate the popping. I have a hard time believing this. They installed 31/76. Does this sound about right? Bike is all stock other then the pipes... 08 k9. I rode it once (when checking it out before buying it) in OH when it had the stock jets....it popped a bit, but I figured that conditioned would be cured after Carl's did their work, but it didn't seem to pop nearly as much then as it does now. Any thoughts? I read a thread about vacuum caps dry rotting, but I don't know where to find them to check them out. Any help would be much appreciated.
    Sent from my iPad using Tapatalk HD
  15. francoblay1
    K9 (2006)
    Franco
    Vacuum Caps are located right on top of the Carb, it´s black and it´s hold in place by a small zip-tie.
    See the black thing on top?
    #35 francoblay1, Oct 5, 2013
  16. zenBD
    zenBD Active Member
    Deland, Fl 32724
    Matt
    Yep...thanks! Found it. Is this something I could pickup from Harley, or would I have to go to S&S for it? I just took the bike out today... I've never ridden any other Big Dogs do I don't know how it should behave...that being said, I feel like it hesitates to much...
  17. okie_dog
    okie_dog Guest
    09 k-9. XXX "G" carb, S&S Dual Runner Intake, V&H 2 into 2 big radius with BCT monster baffles, stock cam. 33 Intermediate, 76 main, 60 air bleed.
    Kenai likes this.
  18. Slipngrip
    Slipngrip New Member
    New Mexico
    2004 Mastiff 117; 2002 RC51; 2005 YZF450
    Richard
    awesome thread..... I guess I should have read this before posting my questions else where...
    great info!!!
  19. StreetHog
    StreetHog Active Member
    Scott City, Kansas
    2012 HD Street Glide, 2007 BD K9
    Pat
    07 K9. Just bought it and it came from sea level to 3500 feet above. It has the wimmer twin spike air cleaners and V&H big radius exhaust, no baffles. I took the float bowl off yesterday and it had the stock 295/74 jets. I fattened it up with a 32/78 but still seems lean according to the plugs. At 65 mph it spits and splutters quite a bit. Yes I readjusted the idle mixture and accel pump after rejet. Do I need to up the intermediate jet some more to rid the sluggishness? It seems to run fine at 3000 rpm but kinda falls on its face between 2000 and 3000
  20. francoblay1
    K9 (2006)
    Franco
    Typical transition between jets.... go up on the Air Bleed jet.... go to a 60.
    No need to go up on the Inter jet?... I am at Sea level and with the 32 is just fine... you are higher so... you should go no bigger than 31/32... which it´s the recommended for the V&H exhaust... (and maybe 76/78 in the Main) but again... every bike is a bit different.
