What Jets Do You Run?
Discussion in 'Fuel / Air' started by BadBrad, Aug 6, 2009.
  1. BadBrad
    BadBrad 2005 Pitbull
    Brooklyn, MS....Why? Is there another Brooklyn?
    2005 Pitbull / EHC-less
    Brad
    I know there are a lot of different factors for running different jets. After having my Dog just over 6 months, I finally read enough threads on this site to figure out I was running too lean and corrected the problem with re-jetting. If we get enough replies, I'll take all the information and attempt to make a "Guideline Chart" to use for getting the right jet combination for new users and maybe a few old. List anything you feel may be a factor for using the jets you have, e.g. altitude (it would be nice for all to list that), exhaust type, breather (if not stock), motor modifications, etc.
    I'll lead off: 2005 Pitbull, 117ci, 0 - 200 ft above sea level, 78 main, 33 intermediate, VH BR 2x2 pipes, runs great!:cheers:
  2. V
    V Guru
    08
    .32 intermediate
    .78 main
    .40 air bleed
    .590 woods cam
    S&S Despardo cover with K&N filter
    Mean mothers with thunder monster baffles
    750-1000 ft above
  3. Big Ron
    Big Ron Well-Known Member
    Franklin, Virginia
    2001 Road King
    Ron
    07-K9 @ Sea level
    Big Radius 2 into 2 baffled
    K&N with vented stock cover
    31-Intermediate
    72-Main
    Air Bleed- Stock
    Runs great, no hiccups, flat spots or decel pops:up:
  4. Alicat
    Alicat Hanging out
    Close to Insanity, Michigan
    o6 K-9
    Citation Jet
    oops sorry, running 34/78 with XXX Carb and R&B Racing pipes
  5. BadBrad
    Brad
    I guess I asked for that!:lol:One thing about this site, you have to have a sense of humor. For those that are just reading this thread, take a minute to give some feedback. If you're like me, you can't afford to have a shop do all your repairs, especially if it's out of warrenty. Of course, I didn't know until last week when I changed my jets what I actually had in there. That "cough/spit/hic-up" at 70 mph was driving me crazy. Thanks Gas Man and all the others that have written the "How-To's" on this forum. It sure took the fear out of doing the work myself. :up:
    Big D Florida likes this.
  6. Loafington
    Loafington Active Member
    Tewksbury, MA
    2010 Ducati Streetfighter S
    36/80
    Wimmer 90 deg tapered cone intake mounted vertically
    Zippers Thunderjet and modified by them, bored venturi, additional bowl vent, Yost Power Tube
    .600 Cam
    Doug Keim Bad Ass Pipe
    Anywhere between sea level to 2000 ft above
  7. toomanybikes
    toomanybikes not enough time 4 riding
    Sterling, VA
    2006 Big Dog Mastiff, 1992 Yamaha FJ1200. 2012 Screamin' Eagle Street Glide, 2014 HD Breakout
    Stephen, but I will answer to Steve
    31/76
    Doherty PowerPacc air cleaner with S&S air cleaner cover
    Hooker Troublemakers with the "quiet" bafles
    250-2000 feet above sea level
  8. mlb2992
    mlb2992 Active Member
    Tavernier FL. (Fl. Keys)
    2007 K-9 & 2008 K-9
    Marc
    American Airlines 767 & 757 :2thumbs:
  9. Chopper117
    Chopper117 Chopper Nutt
    PA
    2005 Ridgeback Chopper
    Gregg
    31/88
    Super G
    K&N
    2 into 1 RP Geez Street Walker Exhaust
    Thunderheart Ign
    650 feet
    #9 Chopper117, Aug 7, 2009
  10. GymRat
    GymRat Member
    Colorado
    2005 BD Chopper
    John
    36 and 84, 5800 feet. Running a 628 cam, Crane High 4 ignition, opened the intake and exhaust valves to S&S spec's and have CC'd heads and jugs.
  11. barhopper
    barhopper Another round please
    So Cal
    04 RSD Bulldog
    88? Your gas mileage must suck. I had a big main in after the dyno work. Ran great but got 80 miles per tank. I dropped it back to a 82 I think, still runs great, but get 120 per tank. Just my 2 cents. :cheers:
  12. Gas Man
    Gas Man Cool isn't cheap
    Metro Detoilet
    So the carb how to took care of you?
  13. BadBrad
    Brad
    Hey Gas, without a doubt, the carb "how to" got me through it without any parts left over. The numerous threads about carb problems let me know that the intermediate and main kind of "swap up" at 2750 rpm and if you get a "cough" around that rpm, then the intermediate should be a little higher. Everything I read was right on the money and with these "how to's" I may never have to take my bike to a shop again. Not if I can help it. Your quote "why pay somebody else to fuck up your bike" is a favorite of mine. Thanks again.
  14. Raywood
    Raywood The Pirate
    Rainbow, CA
    2014 KMW Regulator
    Ray
    Just a note: Raising your intermediate to correct a problem at 3000 rpm will fuck all your regular riding as you spend most of your time in the intermediate. An S&S carb has an air bleed that is used to delay the main jet coming on to correct your situation. Go to a larger airbleed. :cheers:
  15. BadBrad
    Brad
    Ray, Did you finally get dried out? I went from a 76/31 to a 78/33. That's the first I've heard about changing the air bleed to correct a problem on the carb. Up till now, all the threads I read where carbs were "spitting/coughing" at approx. 70 mph was due to the intermediate not being big enough. Right now, it's running great! I'll have to read up some more on the S&S. Thanks for the info.
  16. ROD
    ROD New Member
    BIGDOG MASTIFF, HARLEY BAGGER
    To stop my caugh 40 and 74 with a yost 48 air at 5000 to 10,000 elevation.
    rod
  17. Exotic
    Exotic Member
    Richmond, VA
    06 Big Dog K9
    06-K9 0-100 Ft above Sea Level
    Big Radius 2 into 2 baffles cut to 4.75 inches
    K&N with High Flow Cone
    31-Intermediate
    76-Main
    Air Bleed- Stock
    Runs Perfectly! :whoop:
  18. Baldielox
    Baldielox Active Member
    Virginia
    2008 Pitbull, 2005 Sportster
    08 Pitbull
    31/78
  19. T.Byrd
    T.Byrd Well-Known Member
    KY
    2006 Harley Davidon Ele. Glide Classic
    Tom
    05 Chopper DT. 117, with Mean Mother 2 Pipes no bafflels, Wimmer Dual Runner Intake, XXX G Carb. with 33 inter. and 78 Main.
  20. francoblay1
    francoblay1 The Spaniard
    LĀ“Escala, 17130 Spain
    K9 (2006)
    Franco
    06 K9 @ Sea Level
    31/76
    48 Air Bleed
    xXx Booster kit
    D&M cone, Vertical
    Stock exhaust with NO Baffles.
    soon will have the BR 2-2 with BCT Baffles, TH programmable Ignition & 585 cam installed. Just need the time to do it. I will update once all is in place! :D
    #20 francoblay1, Feb 23, 2013
