Trailer tie-down
Discussion in 'Help Wanted' started by FLCRO, Feb 20, 2018.
  1. FLCRO
    FLCRO Member
    Cocoa Beach, FL
    '07 Chopper
    Chad
    Well, uncle sam has told me that I'm moving back to the great state of Florida. Going to trailer the chopper on an open uhaul trailer from C Springs. Had a couple questions for you guys:
    1) anyone have any pics/suggestions on the points to tie down the bike?
    2) would like your $0.02 on what ratchet straps to get. Will harbor freight work for one trip, what brand should I get, are Powertye worth the $$$, etc.
    Appreciate everyone's thoughts!
    Thanks!
  2. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    Do yourself a favor, rent a closed trailer. Uhaul sells some decent ratchet straps as well, just make sure to pick up some strap protectors as well.
    dentdude36 likes this.
  3. HMAN
    HMAN Well-Known Member
    fk it
    Forget the straps and put in a bikerbar.
    liferider, Unsprung and dentdude36 like this.
  4. 1BADK9
    1BADK9 Limited Edition Member
    NW Florida
    2007 K9 LE #78
    Brooks
    Never seen the biker bar, pretty damn cool though.
    Tim and Reddickracing like this.
  5. KnotSo
    Western Washington, the State
    Powertye's are worth the money if you will be using more than a few times. Don't trailer my bike but due tie down sand rails and the atv's, the Powertyes are the best.
    Thank You for Your Service.
  6. bdm7250
    bdm7250 Guru
    Doug
    He's renting a trailer, might be frowned upon by Uhaul..
    Biker Babe, HMAN and BWG56 like this.
  7. FLCRO
    FLCRO Member
    Cocoa Beach, FL
    '07 Chopper
    Chad
    Correct- just renting a trailer, so don’t think I have any options besides tie down straps....
  8. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Get one of these from HF, its free standing and use 2" rachet straps on the triple trees to the trailer and 1" ratchet straps on the rear to keep it from bouncing side to side, pull the front forks down half the distance of the travel on the tubes :old2:
    https://www.harborfreight.com/1800-lb-capacity-motorcycle-standwheel-chock-61670.html
    #8 BWG56, Feb 20, 2018
    toomanybikes likes this.
  9. 1BADK9
    NW Florida
    2007 K9 LE #78
    Brooks
    I tie off my front wheel so it can't roll, then a strap across the triple tree on each side with the fuzzy protectors, that would probably suffice, but I add another strap on each side down low around the frame just to be sure.
  10. toomanybikes
    toomanybikes not enough time 4 riding
    Sterling, VA
    2006 Big Dog Mastiff, 1992 Yamaha FJ1200. 2012 Screamin' Eagle Street Glide, 2014 HD Breakout
    Stephen, but I will answer to Steve
  11. Reddickracing
    Reddickracing Active Member
    Louisiana
    2006 K9, 07 Streetbob
    Jeff
    Pretty dang cool, hadn't seen that before
  12. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Strapping around the triple trees put to much stress on the forks and seals. Not to mention, the rub marks it will leave. Get you a wheel chock and screw it down in the trailer, they won't notice the holes. Next, put the straps around the frame at the battery box, and angle them slightly forward.
    Yes the bar Kevin got is the cat's meow, and some day when I'm rich and famous, I'll get one too, but the way I described will hold it really good.
    Reddickracing and wewjr71 like this.
  13. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Looking at the picture, I forgot to mention the one's on the lower frame pulling backward, to take the stress off the forks.
  14. Dogbone
    Dogbone IF LIFE SUCKS, GO RIDE
    san angelo texas
    06 K9
    and dont forget to strap the seat down or remove it and put in the back seat of your vehicle. seen way to many fly off. OH and get the tie-downs that have the safety latches so they cant bounce loose
    #14 Dogbone, Feb 21, 2018
    Mr. Wright likes this.
  15. Dogbone
    san angelo texas
    06 K9
  16. FLCRO
    FLCRO Member
    Cocoa Beach, FL
    '07 Chopper
    Chad
    ok- bit the bullet and ordered the 2" powertyes today (with sheepskin)
    Ker- the utility trailer I'm renting has a motorcycle chock in it. I'm assuming that would suffice and wouldn't need the freestanding wheel chock from HF?
    Shannon- as they say, a picture is worth a thousand words. Hadn't seen that method before- thanks!
  17. FLCRO
    FLCRO Member
    Cocoa Beach, FL
    '07 Chopper
    Chad
    Dogbone-
    thanks for the pictures. that set-up looks bombproof. Where are the black tie downs tied to? Handlebars? Does that compress the suspension?
  18. FLCRO
    FLCRO Member
    Cocoa Beach, FL
    '07 Chopper
    Chad
    Also, once the bike is strapped down, should the kickstand stay down or up?
  19. Dogbone
    san angelo texas
    06 K9
    they are just at the first triple tree plate and they are just snug. the one down low keeps it stable. just liked the extra security.
    with the low fender on the front, i made my own wheel caulk as the others that flip up will hit my fender. the strap in the middle is wrapped around the seat bracket and snug. Only two are really tight. Low front and rear tire.
  20. Jersey Big Mike
    Jersey Big Mike Well-Known Member
    Murrell's Inlet, SC
    08 K-9, 02 BMC 918ST
    Mike
    I've moved a bike a lot in a trailer -- hell first on lived on the bed of my f150 with a custom cap.
    Now some will disagree with me here but I am a firm believe that ALL straps should pull down and forward in the direction of the chock.
    Rear straps as well.
    I usually use 2 sets in the front - I set to handlebars/fork with softies and a second set to the pegs.
    In the rear I will use the rear pegs or thru the wheel but still go forward.
    I've seen strap failure and for me the last thing I want is that front coming loose. If everything pulls in the same direction the bike will stay in the chock even when a front strap snaps.
    Now that you have the softies to protect the bars/bike, put them in your tool bag -- that way if you even have to be towed by AAA or something, you have them, or even by friend -- ratchet straps are easy to locate in an emergency on the road -- the softies not as much.
    I've used mine when AAA towed me and the buy had never heard of them -- Made his boss buy them for all the trucks (they did a lot of motorcycle towing)
    Since you can't/arent using an enclosed trailer you might want to think about a bike cover for while its on the trailer, even a blanket on the bike and a tarp across the trailer will protect the bike better for that long trip. You can always use some 1x2 zip tied (well) to the trailer frame to hold the tarp away from the bike.
