TP to S&S Conversion . Have you...
Discussion in 'Motor' started by francoblay1, Feb 27, 2015.
  1. My bike came with S&S
    45 vote(s)
    45.0%
  2. Yes, I did the conversion
    15 vote(s)
    15.0%
  3. No, I am still with the TP
    36 vote(s)
    36.0%
  4. Why should I do the conversion ???
    6 vote(s)
    6.0%
Multiple votes are allowed.
  1. mittens
    mittens Active Member
    Huntsville, AL
    2004 Chopper RT
    Harley
    I have a 107, and I am still not sure what cam I have in it.. ha but it seams to pull good up top!
  2. KaptinAmerika
    KaptinAmerika Well-Known Member
    2006 Big Dog K9
    Curtis
    As long as it wasn't changed already you can call S&S, give them your engine case number and they will tell you what it was built out with.
  3. francoblay1
    francoblay1 The Spaniard
    L´Escala, 17130 Spain
    K9 (2006)
    Franco
    Hummm....... Sorry Curtis, but it´s not that easy... S&S will tell you that BDM were doing their own things.... I could not find out till I opened the motor... they (S&S) told me 546 maybe... I did find a Comp-Cams 569 in there.
  4. KaptinAmerika
    2006 Big Dog K9
    Curtis
    On the later 117s yes. On the older 107s they will.
    francoblay1 and Big D Florida like this.
  5. francoblay1
    K9 (2006)
    Franco
    True. :flag:
  6. MadMarx
    MadMarx Active Member
    NH
    2006 Big Dog Mastiff, 2010 Buell XB12Ss
    Mark
    Ok... I have an '06 Mastiff with TP rocker boxes.
    I'm leaking oil out of the rear one.
    I purchased S&S rocker boxes already.
    1 - what else do I need to buy before I start the project?
    2 - is there any chance it already has the 585 cam?
    3 - where should I get the 585 cam?
  7. francoblay1
    K9 (2006)
    Franco
    Mark,
    If you are the original owner and the motor has not been touched, there is no way you already have the 585. I bet you will have a 569 in there.
    $155 [ame=http://www.amazon.com/Cycle-585V-Camshaft-33-5109/dp/B000GZV3KA/ref=sr_1_cc_5?s=aps&ie=UTF8&qid=1426319936&sr=1-5-catcorr&keywords=s%26s+585+cams]Amazon.com: S&S Cycle 585V Camshaft 33-5109: Automotive[/ame]
    $155 S&S Cycle 585V Camshaft 33-5109
    I would contact the reputable vendors in this Forum.... I got it cheaper than that, but that was two years ago.
    Since you doing the Rocker Boxes conversion, I would put new lifters too, I got the Fueling brand.
    Big D Florida and cdogg556 like this.
  8. mittens
    Huntsville, AL
    2004 Chopper RT
    Harley
    So I assume like anything do the cam swap then re tune /jet th carb and you done?
  9. john sachs
    john sachs Active Member
    Deltona, Fl
    harleys
    How many miles on the motor with the TP boxes ?
    John
  10. MadMarx
    NH
    Mark
    Low miles, 12,500
  11. john sachs
    Deltona, Fl
    harleys
    With 12,000 mi. you need to check your valve guides for excessive wear/play.
    John
  12. MadMarx
    NH
    Mark
    :cheers:Ok thanks for the info!
  13. JR03CHOPPER
    JR03CHOPPER Well-Known Member
    Orlando, FL
    2003 Big Dog Chopper, 2007 Big Dog K9
    JR
    Slight Hijack...sorry Franco
    John...I was looking forward to finally meeting you during Bike Week. Any chance you'll be coming up for Leesburg?
    francoblay1 likes this.
  14. john sachs
    Deltona, Fl
    harleys
    I arrived at my buddies house in Debary 3/10 early (9:00 am) so we could make the Hamster ride leaving from the White Eagle bar at 11:30. About 60 bikes, 90 mile ride ending at a home on Lake Harris. :2thumbs: Only time I was around town, was Thursday, visiting several shops I do heads for, the Speedway , Destination, and the Cabbage Patch.
    Wednesday and Friday, just riding the back roads, including Gator Joe's.
    Possibly going to Leesburg. Not sure at this time as my son and daughter-in-law are racing at the PDRA race in Rockingham in April, and wifey wants me and her to go to the race. I'll let you know if we're going to Leesburg.
    John
  15. Jwooky
    Jwooky Well-Known Member
    Oxford, MI
    2008 Mastiff EFI
    JJ
    What ever happen with this idea?
  16. KaptinAmerika
    2006 Big Dog K9
    Curtis
    I throw them out there but no one follows up.
  17. francoblay1
    K9 (2006)
    Franco
    BUMP.
    chubs likes this.
  18. Olde Man
    Olde Man Member
    Fort Wayne, IN
    2006 K-9
    John
    I put a 2 pc .100 thick aluminum spacer between the cylinder heads and the TP rocker boxes. It raises them to allow for the valve protrusion that John Sachs mentioned in his first post. This spacer moves the center line of the roller rocker tip about .060" to the outboard side of the valve stem fixing the geometry problem. I have been running them for 20,000 miles to determine if there were any other problems. The thing that I would consider would be to install lash caps on the valves to bring the push rods back to proper length. I used the existing metal gasket between the head and spacer and then used very thin smear of high temp rtv between the spacer and rocker box. Essentially I glued the spacer and rocker box together. Use the RTV sparingly. You do not want this stuff floating around in the motor. The use of the existing metal gasket allows for the expansion of the jugs. To appreciate the geometry of this hold up two fingers in the peace sign. As you move higher up the v the farther apart your fingers are.
    I can't speak about any other wear problems with the TP's or about the use of lash caps if desired. I would expect that John Sachs would chime in on those issues.
    Your rocker bolts will not have the same engagement. You will need some of them to be longer.
    This is the 1st One Piece Prototype
    Checking the Geometry and Wipe Pattern
    john sachs and chubs like this.
  19. dentdude36
    dentdude36 Guru
    Suburbs of Buffalo NY
    2007 K9
    Kevin
    my 06 came with s&s rocker boxes
    BWG56, chubs and francoblay1 like this.
  20. francoblay1
    K9 (2006)
    Franco
    That´s way to complicated for a guy like myself..... I just got a Big Dog Tech from NY to come over to Spain and he done the conversion to full S&S in my own garage. That was cool! :old2:
    But, RESPECT!.... I wish I could do all this stuff myself! :cheers:
    :chopper:
    Big D Florida, chubs and dentdude36 like this.
