TP to S&S Conversion . Have you...
Discussion in 'Motor' started by francoblay1, Feb 27, 2015.
  1. My bike came with S&S
    49 vote(s)
    45.0%
  2. Yes, I did the conversion
    17 vote(s)
    15.6%
  3. No, I am still with the TP
    39 vote(s)
    35.8%
  4. Why should I do the conversion ???
    7 vote(s)
    6.4%
Multiple votes are allowed.
  1. francoblay1
    francoblay1 The Spaniard
    L´Escala, 17130 Spain
    K9 (2006)
    Franco
    I thought it would be interesting to know how many of us did the conversion or are still running on TP parts.
    So here a Poll. (It is multiple choice)
    #1 francoblay1, Feb 27, 2015
  2. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    believe '06 was the last year. mine and shanes '07's both have S&S
    francoblay1, Big D Florida and chubs like this.
  3. Fibersnake
    Fibersnake Banjo Playing PsychoBilly
    Eastern Panhandle of West Virginia
    2005 BD Mastiff 2009 Buell 1125R
    Mine has the TP Rocker Boxes with S&S rockers and other stuff in it. When I had them check under warranty, they found the guides worn to limits and changed out everything with new springs, roller rockers, guides, etc but kept the TP Boxes since they were still good. Items that were changed were S&S. Still going strong after 8 years and over 25K since then.
    francoblay1 and chubs like this.
  4. FrankBDPS
    FrankBDPS Well-Known Member
    North Lawrence,Ohio
    Frank
    So what year did they start using them?
    chubs likes this.
  5. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    i believe it was '05. there is no confusing the TP with the S&S. the TP is a flat topped with only (4) allen screws holding the covers. the S&S are a much more sculpted cover that is held in place with (6) allen screws.
  6. KaptinAmerika
    KaptinAmerika Well-Known Member
    2006 Big Dog K9
    Curtis
    That's interesting.
    My understanding is it is the misalignment caused by the boxes that is the issue.
    How many miles were on her when they did the warranty work?
    chubs likes this.
  7. FrankBDPS
    North Lawrence,Ohio
    Frank
    Could the misalignment be caused by the rocker arms? Would the TP and S&S rockerarms be interchangeable in the TP boxes?
    chubs likes this.
  8. john sachs
    john sachs Active Member
    Deltona, Fl
    harleys
    The misalignment is caused because the valve stem protrusion in the S&S heads is far greater than the protrusion that the TP rocker boxes are set up for.
    The TP rocker arm shafts will work with the S&S rocker arms. I wouldn't gamble with the TP rocker arms. If you're using cams under .600" lift, by all means use non-roller S&S rocker arms. :eek:
    John
  9. KnotSo
    Western Washington, the State
    My Mastiff is an early 2006 and is all S&S, rock stock and no issues
    chubs likes this.
  10. Mickeetwo
    Mickeetwo Guru
    Texarkana, AR
    Alan
    I'm still running the TP's.....30,000 miles and still ticking along. If I had the cheddar I'd change them out to S&S. I've wanting to do the swap for about 7 years now, just never seem to have the money. I'm sure it will bite me in the butt one day.
  11. diver1
    diver1 Member
    Montgomery AL
    2006 K-9
    Bill
    Did the conversion at 39,000 miles. Had top end rebuilt and added 585 cam. At 42,000 miles now and bike runs great.
  12. Mickeetwo
    Mickeetwo Guru
    Texarkana, AR
    Alan
    What made you change them out to S&S at 39,000? How was your heads when you made the swap?
    francoblay1 likes this.
  13. diver1
    diver1 Member
    Montgomery AL
    2006 K-9
    Bill
    Started spraying oil through the gaskets at about 35,000 miles especially at interstate speeds 75-85mph. I had been told that it was the TP boxes by several people. I went ahead and had the top end rebuilt and bored out while it was in the shop. It was NOT cheap but I'm glad now.
    My opinion is if it ain't broke don't fix it. If you change out the boxes you know you will want to do more.
  14. Mickeetwo
    Mickeetwo Guru
    Texarkana, AR
    Alan
    I know what you mean about doing more. I want the 585 cam and I need to change out my lifters. Diamond cut would be nice and on and on.....
    francoblay1, SEAL-rider and chubs like this.
  15. KaptinAmerika
    2006 Big Dog K9
    Curtis
    Should we do a 585 cam group buy?
    chubs and francoblay1 like this.
  16. francoblay1
    K9 (2006)
    Franco
    chubs likes this.
  17. Dawggydawg
    Dawggydawg Member
    Bethalto Illinois 62010
    05 Big Dog Mastiff, 2016 Harley Davidson Street Glide Special
    Mark
    I am on the fence with changing out the rocker boxes to S&S. Mine are leaking and have been since I picked up the bike last year. I purchased a used set of TP boxes last August because the chrome on mine was bubbling and lifting and didn't realize there is a problem with the TP boxes. That's my fault for not keeping up on the forum. I talked to Curtis today and would like to go with S&S but if the little lady in my life finds out I am going to drop another 1K on it this spring I am literally going to be in the "dog house"! I just called and talked to the shop near me in St. Louis that I'm planning on taking the bike here to soon and he just assured me the TP boxes are fine if you change out the guides. So here again, I am confused as to what I should do. Any and all comment/suggestions are welcome.
  18. john sachs
    Deltona, Fl
    harleys
    TP boxes fine ??? :argue: LOL
    Only to let the new guides wear again. :bang:
    Big D Florida and francoblay1 like this.
  19. Trainguy
    Trainguy Chromeoholic
    Area 51
    K9 Karata 4" OP, V&H 2-1 S&S air+585, xo grips&pegs K&P oil & duel coolers, Ness, all chrome w/blk
    DJ
    francoblay1 and Big D Florida like this.
  20. Viking
    Viking Biker
    Florida
    Silly post, and you of all people should know better.
