Thunderjet Tuning
Discussion in 'Fuel / Air' started by alhall88, May 24, 2009.
  1. alhall88
    alhall88 UAW
    Petersburg, Michigan
    Yeah I'm going to start again in a couple days because I need more jets. S&S does not make any jets between 33 and 36 and I should be running a 34 or 35. I called Zippers and they have those special sizes. According to Zippers I should be at a 34 or 35 int. with a 74 main. I'm starting to get some old weber carb deja vu going on
  2. MARV
    MARV Well-Known Member
    CENTRAL JERSEY
    05 CHOP
    SUL
    no leaks?
  3. avdhunter
    avdhunter Active Member
    Monroe, La
    09 Ridgeback
    Louie
    Yea Al and those 34,35 & 36 are twice as much .... or they were when i found em! good luck man!
  4. alhall88
    alhall88 UAW
    None I could find, I thought the same thing. I think I just need to stop thinking S&S tuning. I haven't even put the meter on it because I need to get rid of the flat spot first.
  5. MARV
    CENTRAL JERSEY
    05 CHOP
    SUL
    being the machinist Al is, surprised he doesnt drill his own. :up:
  6. alhall88
    alhall88 UAW
    I thought about it because I still have 2 small drill bit sets from when I had the weber carb and I had to drill my own jets then. But I want to be able to switch back if I had to. My jet supply is running low due to cheapskate friends keep using mine up.
  7. Chopper Dave
    Chopper Dave SIICK!!!
    Michigan
    2011 Ultra Limited
    Dave
    Al...what size jets do you need? to drill....my dad gave me a pack of jets from his G carb(I would have to see what sizes are in that pack he gave me) he had on his Harley...plus I also I the high end jet kit....give me a call and let me know and I will send you those jets.....
    Wolfman Dan likes this.
  8. alhall88
    alhall88 UAW
    Thanks Dave for the offer but I have them coming already but if I need more I 'll give you a shout.
  9. Chopper Dave
    Michigan
    2011 Ultra Limited
    Dave
    sounds good Al!:cheers:
  10. lee
    lee Well-Known Member
    Bristol, England
    2005 Big Dog custom build and Buell custom build
    you'll get there Al
  11. alhall88
    alhall88 UAW
    Well I did about 8 different jet changes today but I finally think I got it. This thing is really waking up now. I'm also more inline with what zippers suggests. I am now running a 33 slow jet, 74 main jet, and a 135 (.053) air bleed and a 120 thunder jet. I think I was underestimating the impact the airbleed has on the main jet. For example I needed a 80 main jet with a 155 (.061) airbleed. Just by dropping the air bleed I was able to drop down to a 74 main but then I had to up the thunderjet from a 100 to a 120. Now I can do some great 2000 rpm roll on's. I coast in second gear up to 2000 rpm's and punch it full throttle and break the rear tire loose. I can't get back on the dyno till the 16th of June so I'll wait till then and see if my lean condition at high rpm's is fixed. Hell I might have even picked up a couple pony's.
  12. Chopper Dave
    Michigan
    2011 Ultra Limited
    Dave
    good to hear Al! hope you got the right recipe:up: :cheers:
  13. MARV
    CENTRAL JERSEY
    05 CHOP
    SUL
    sounds great! :up:
    did you get the LM-1 on her yet?
  14. alhall88
    alhall88 UAW
    Yeah but I'm going to kill myself with that fucker, I cant keep the bike rolling at 5000 rpm's and keep watching the meter. I think it works fine on the low and midrange but its tough keepin your eye on it while getting on it, and you need to maintain those rpm's for a few seconds till the air fuel levels out. I think when I get back to work I'll invest in the recorder as well. That way all I have to do is ride it all around then I can download the data after.
  15. Raywood
    Raywood The Pirate
    Staff Member Supporting Member Calendar Participant
    Rainbow, CA
    2014 KMW Regulator
    Ray
    :cheers: :2thumbs: :cheers:
  16. lee
    Bristol, England
    good work Al. I know what you mean about the LM unit too! Lethal. I tried to record onto a SD card but no joy. No idea how that works. Probably wouldn't have been much use anyway because I don't have the rpm cable.
  17. alhall88
    alhall88 UAW
    Mines a little older unit s no SD card, but the internal memory can hold 45 minutes of data. But like you said unless you can associate the air fuel readings with engine rpm's the data is useless. You have to buy the "aux box" for the LM-1 that costs another $249.00 and then find places to hold 2 boxes when you ride.
  18. outdoorsman26
    outdoorsman26 Well-Known Member
    madison, WI
    2007 mastiff
    matt
    how did this all turn out for you?? I am currently doing this mod to my carb and was wondering what jets you settled on??
  19. outdoorsman26
    madison, WI
    2007 mastiff
    matt
    just seen that AL hasn't been on here in a while does anyone know what jets they are running in there carb with the thunder jet?? I have stock motor w/600 cam and V&H pipes, thanks
  20. Wolfman Dan
    Wolfman Dan New Member
    St. Louis, MO
    1973 Harley Davidson ElectraGlide FLH
    Dan
    Hey Al, I'm curious if you are still on this forum. I know this thread is old, but I'm getting ready to install a S&S Super E already modified with a Thunder Jet. Could use all the advice I can get. I also have a Kuryakyn Super Charger Air Intake on mine. There is very little information about this combo. Any advice?
