Thunderheart Ignition Module??
Discussion in 'Ignition / Electronics / Batteries' started by xxcarpxx, May 28, 2015.
  1. KaptinAmerika
    KaptinAmerika Well-Known Member
    Full Member
    2006 Big Dog K9
    Curtis
    It will not work on an 03. 03s use a cam sensor this unit uses a crank sensor.
    xxcarpxx and francoblay1 like this.
  2. Chillin
    Chillin Active Member
    oVeRtHeRe
    shit! any idea which way to go??
  3. KaptinAmerika
    Full Member
    2006 Big Dog K9
    Curtis
    Do you need an 03 Ignition Module?
  4. Chillin
    oVeRtHeRe
    MIne works fine I want to go adjustable and single fire, more in the performance area
    before I go into cam changes
  5. KaptinAmerika
    Full Member
    2006 Big Dog K9
    Curtis
    I see, your only option then is to go with a cam chest module and get rid of the TH module.
    Its not difficult to do.
    There are several available and it depends on your budget and who you talk to.
    Some units that forum members here have had good success with are the Crane Hi4, the Daytona TwinTec and the DynaTek.
    There are also knock off versions like the PowerHouse module, that we have a had good success with, that are American Made but allot lower in price.
    The one thing to remember with Cam Chest modules is keep the heat down. Running the bike too lean or too hot in hotter climates will lead to early failure of the module.
    francoblay1 likes this.
  6. SEAL-rider
    SEAL-rider Active Member
    Del Mar, CA
    2005 Big Dog Chopper 600 cam, John Sachs Super G Carb, V&H Big Radius
    Spencer
    Did Thunderjet switch from a 90 degree arrow to the slot to an arrow on one end of the slot. I can't really see an arrow and am guessing. My slot is a bit chewed up.
