Thunderheart Ignition Module??
Discussion in 'Ignition / Electronics / Batteries' started by xxcarpxx, May 28, 2015.
  1. FrankBDPS
    FrankBDPS Well-Known Member
    Full Member
    North Lawrence,Ohio
    Frank
    So what makes you think you're ehc is fried?
  2. xxcarpxx
    xxcarpxx Member
    Cullman Alabama
    07 BDM Chopper
    The black spot between A and B is an arc burn....
    #22 xxcarpxx, Jun 21, 2015
  3. FrankBDPS
    Full Member
    North Lawrence,Ohio
    Frank
    Ouch! That just sucks.
  4. awg
    awg Well-Known Member
    Full Member
    Ohio
    2008 Big Dog Chopper, 1980 Honda Passport, 1965 Honda Benly, 1967 Sears Sabre
    I thought awhile back someone on here was gonna redo the EHC that would be more dependable. Anyone here of this?
  5. xxcarpxx
    xxcarpxx Member
    Cullman Alabama
    07 BDM Chopper
    Yes it does...it left me and my girl stranded in a thunder storm... now I'm hoping the EHC was my only problem.... I hope to have the RIP kit finished tomorrow or the next day....
  6. francoblay1
    francoblay1 The Spaniard
    Full Member
    L´Escala, 17130 Spain
    K9 (2006)
    Franco
    So, how this story ended up?
    and... I have a question which I am still unsure about it... had different answers in the past...
    The stock TH Ignition Module... at how many degrees advance BDM did lock it?
    Does someone knows it for sure?
    Cheers.
    cdogg556 likes this.
  7. xxcarpxx
    xxcarpxx Member
    Cullman Alabama
    07 BDM Chopper
    Franco... As you know, I installed the RIP Kit... After a few test runs, I sat the TH to setting 3.. It seamed to have a little more trouble staring up... Performance wise, I couldn't really tell much difference.. I have it set back to the F setting, due to it seems to start easier for me.... So, I'll run it there and see how things turn out..
    francoblay1 likes this.
  8. ray gregoire
    ray gregoire New Member
    oregon
    2007 k9, 1999 yamaha roadstar, 2007 Yamaha Roadstar, 2014 Yamaha bolt
    ray
    Hey there. I'm a new dog rider. I picked up an 07 k9 and was riding it the other day....i ride pretty hard and fast... and was getting on it then suddenly it crapped out at high high rpms...I'm sure i hit the rev limmiter. The problem is that now it rides fine upto about 3,000 rpms and craps. If i twist the throttle too aggressively or hit 3k if feels like the timing is retarding. runs great up to that point. Did I blow something? is there a reset switch or do i need to get a new unit. Thanks.
    gunz
  9. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Rev limiter is at 6000 or 6500 RPM you actually hit that? Your teeth still there? Not sure what the point is of running it up that high unless you got monies for rebuilds.
    I think the most I have hit was 5k.
    BWG56 likes this.
  10. cdogg556
    cdogg556 Guru
    Full Member
    Folsom, Ca.
    John
    I hit the rev limiter before mine crapped out, I was in second gear and did not shift quick enough and with the 585 cam it revs fast! Before I knew it I hit the rev limiter at 6250 or so and it shut it down, kinda weird that mine screwed up after that also.
    Oh, and Ray, you might want to do an intro before the intro police nail you! Lol! You'll get a better response to your question also.
    BWG56 likes this.
  11. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Oh My, :nonod::nonod: you get a new toy and ya[​IMG] :oldlaugh:
    francoblay1 and cdogg556 like this.
  12. cdogg556
    cdogg556 Guru
    Full Member
    Folsom, Ca.
    John
    Hey I don't want any carbon build up from lugging the engine! Lol![​IMG][​IMG]
    francoblay1 and BWG56 like this.
  13. ray gregoire
    oregon
    ray
    Ok...so...The k9 has two speeds "off" and "Bat out of hell!" I prefer the later. I'm thinking of disconnecting the Battery and completely dischargeing the system. Maybe it will reset to the 6200 rev. Thought?
  14. francoblay1
    Full Member
    K9 (2006)
    Franco
    Check THIS out! :oldthumbsup:
    BWG56 and cdogg556 like this.
  15. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
  16. cdogg556
    cdogg556 Guru
    Full Member
    Folsom, Ca.
    John
    Well, I tried to warn ya![​IMG][​IMG]
    xxcarpxx, francoblay1 and BWG56 like this.
  17. ray gregoire
    oregon
    ray
    Ok thanks, I'll get on that.
  18. ray gregoire
    oregon
    ray
    So where do we post an intro? this sites kind of funny.
  19. francoblay1
    Full Member
    K9 (2006)
    Franco
    If you click on that link I sent b4 it will take you to the Introductions page... there just click on "Post new Thread" button.
    And here FORUMS you will see all the sub-forums.
  20. Chillin
    Chillin Active Member
    oVeRtHeRe
    Will this "upgrade" work on an 03 chopper, question, question
    I have the software for the 5012 module, I got it from a Big Dog Dealer... BUT
    it doesn't see my old module
