Thunder heart ignition module
Discussion in 'Ignition / Electronics / Batteries' started by easy riders, Jan 11, 2011.
  1. easy riders
    easy riders Member
    Netherlands Antilles (Curacao)
    Pitbull 2007
    Errol
    Hi Guys,
    blessings for these new year.
    question: I buy a Thunder heart ignition module and I want to configure the settings with the program that connect to the module.
    do any one know what are the settings. I have a pitbull 2007
    thx,
  2. V
    V Guru
    Are you buying a replacement programable module? If so it comes with the information and CD to custom tune your own configuration or you can use the stock timing settings it has pre-programed which you chnage with a very small screw driver on the module.
    If you are using a Big Dog stock module I don't believe you can change the settings or reprogram it.
    V
  3. Little-Boo
    Little-Boo Well-Known Member
    Troop Supporter Supporting Member
    McAllen, Texas
    2013 Tri-Gluide, 2006 Mastiff, several Mods to many to list
    Carlos
  4. Germanbiker
    Germanbiker Active Member
    08 Pitbull / 13 MV Agusta Brutale RR
    Is the performance worth the money??
  5. Coolbreeze
    Coolbreeze Active Member
    Mogadore, Ohio
    04 Big Dog Boxer/94 1200 Sportster
    Its a good idea if you have done some motor work.
  6. easy riders
    easy riders Member
    Pitbull 2007
    Errol
    thx all for the information I gone to make some test on saturday.
    Germanbiker it is worth the money, the stock one is a pain in the ass.
  7. V
    V Guru
    No regrets on mine. Pulls better than the stock on the upper RPM'S:2thumbs:
  8. Mariakas
    Mariakas New Member
    FLHRSI(06)
    Ignition module
    Question: guys, is it possible to change (upgrade) ignition module without EHC elimination :confused:.?? Thanx in advance.
  9. V
    V Guru
    On the 05 and later models the upgrdae is no problem. Your bike being a 04 most lilkley has a cam pick up igntion and if so you have many more options to pick from than the 05 and later bikes. So yes you can change your igntion with out changin the EHC. Anybody else want to chime in here thats done so? V
  10. Mariakas
    Mariakas New Member
    FLHRSI(06)
    Good news, thank you V..!! :whoop:
