Throttle Grip Slack? (not cable) - Is This Righ??
Discussion in 'General' started by mofaster, Oct 14, 2017.
  1. mofaster
    mofaster Member
    Arizona
    2006 Mastiff
    So, I'm an idiot and I took apart the housing to take a peek inside at the run/off switch since I really have to push it several times and maneuver my thumb around to find the "sweet spot" for it to engage and start. Anyway, when I put everything back together, I was a little unsure on whether I had this slack in the throttle grip prior to removing. I'm losing my mind and can't remember, so I was hoping you guys could tell me if that looks right. If I did try to make it will no slack, that seems to bind up the throttle (stick), so I assume its ok the way it is...but, again, any insight is appreciated. Thanks!!
    Hirter6Pack likes this.
  2. dentdude36
    dentdude36 Guru
    Suburbs of Buffalo NY
    2007 K9
    Kevin
    That's normal make sure the slack is even in the cables and there isn't any slop, the slop in cables can cause the control to loosen up don't ask me how I know thato_O
    bdm7250 and Hirter6Pack like this.
  3. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    Hey..how do you know that? :willynilly:
  4. dentdude36
    dentdude36 Guru
    2007 K9
    Kevin
  5. bdm7250
    bdm7250 Guru
    Doug
    dentdude36 likes this.
  6. heybaylor
    heybaylor Active Member
    East Texas
    Fatboy,Sportster,CX500, 2001 Pitbulll
    Carl
    a little slack is good, also a little in the cables is good.
    I always say " cut me a little slack"
    chubs likes this.
  7. mofaster
    mofaster Member
    Arizona
    2006 Mastiff
    Thank everyone for your input!
  8. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    Slack in and out is good, just a little though just like you have, :old2: now slack in the cables is a whole different story! :oldnono: I had too much in my cables and the cable housing slipped out of the socket and the result was a stuck trottle! :oldeek: Yea that will get the heart rate up! :whoop::oldlaugh: I pulled in the clutch and snapped the throttle a few times and it went back in, :oldsmile: but lesson learned there, too much slack in the cable is not a good thing! :oldnono: Haha! :oldlaugh:
  9. kickstart
    kickstart Well-Known Member
    TN
    52 Pan,05 Bulldog, 07 K9
    Pat
    It sounds like something might be binding when you say if you tighten the screws it gets tight. You might want to take everything apart and check because the screws might come loose and leave the building.
