Thoughts on Dyno Run
Discussion in 'Dyno Runs' started by Gchille, Mar 10, 2012.
  1. Gchille
    Gchille New Member
    Spring Branch, TX
    2006 Mastiff
    I just had my 2006 Mastiff (117 S&S) Dyno and it came in at 103.3 HP and 125.6 ft-lbs of Torque. The bike has 2828 miles and is new to me. It appears the only upgrade on the bike is Vance and Hines pipes. So I would like to get some thoughts on these numbers are they good or bad for this bike and what else could I do to improve the performance?
    G
  2. Nukeranger
    Nukeranger Nukeranger
    Supporting Member Full Member
    Luling, Louisiana
    Huw
    Looks like you have a strong motor there. The torque may be a tad high! But, so what. It just confirms all is good.
  3. moog5050
    moog5050 Active Member
    Webster, NY
    2008 Ridgeback
    Brian
    Reasonable but good numbers. Next steps for increasing HP would likely be a higher flow filter and then cam. I am throwing in an EFM autoclutch today. That should help performance without altering power. That's where my upgrades will end. (Not sure how many times I have said that. lol)
  4. Gchille
    Gchille New Member
    Spring Branch, TX
    2006 Mastiff
    I have heard a good Cam to go with is either a S&S or a Andrews. I was also told I should run about a 600 Cam any thoughts on this?
  5. Five Five
    Five Five Well-Known Member
    Southern California, The 714,
    2003 pit bull (sold) & 2006 K-9 (bought)
    Bill
    Decent numbers .... and should be plenty
  6. moog5050
    Webster, NY
    2008 Ridgeback
    Brian
    I am going with an S&S 585 because I don't want to change springs and bump compression which most of the experts recommend with a 600 or bigger. Should still be plenty. I want power, but not looking to race the sport bikes either.
  7. silver09
    silver09 Active Member
    Smackover, AR
    09 k9, custom rigid chopper, 09 hayabusa
    Tad
    Thats plenty of power to get you in Trouble:2thumbs: More power more problems is a good saying to remember.
  8. Rattler
    Rattler Member
    2006 Mastriff
    You can never have enough power!!!!!!!!
  9. aspen874
    aspen874 Well-Known Member
    Saint Louis, MO
    07 Mastiff 2010 Bulldog Bagger
    Stephen
    My suggestion would be XXX carb, Thunder Heart ignition and 585 or 600 cam depending on which springs are in your motor
  10. spadesluck
    spadesluck Active Member
    New Mexico
    05 Chopper DT
    Jason
    Those are great numbers compared to my stock 117. You put down 10 more horse and 20 more ft-lbs than me. Are the 2006's limited by EPA standards like my 05? Now you have a good starting point to go from.
  11. Brew
    Brew Troop Supporter
    Washington State
    08 Mastiff / 09 Softail Deluxe
    Rob
    Those are good numbers!
  12. Abaco21
    Abaco21 Active Member
    '07 Chopper! '03 Yamaha Warrior, '94 Suzuki RF900R
    Steve
    I can't believe you guys have gotten me seriously thinking about power upgrades, but you have! So... What would this pack of mods, say with the 585, do to fuel mileage?
    I wouldn't want to further reduce range on a tank of fuel. 120-130mi is short enough. (though I did get to see Ray's bitchin tank mod this week)
    The cam would cause it to drink more. But would the carb and ignition balance that through efficiency? Who's got history with such a package of mods?
    FYI, I've got an 07 Chopper
    Steve
  13. CCRainman
    CCRainman Well-Known Member
    Somewhere in Jersey
    09 Street Glide FLHX
    Abaco, believe it or not you get better gas mileage with the XXX. I was getting around mid to high twenties per gallon when when I went with the XXX i got anywhere fron high thirties to almost fifty per gallon. It all depends how much you twist your wrist.
  14. francoblay1
    francoblay1 The Spaniard
    Full Member
    LĀ“Escala, 17130 Spain
    K9 (2006)
    Franco
    The 05 models had restriction plates in the Intake and an E carb while the 06 no plates and a G Carb. Someone correct me if I am wrong?
  15. spadesluck
    New Mexico
    05 Chopper DT
    Jason
    Old thread, but yes you are correct.
  16. TCALZ06
    TCALZ06 Well-Known Member
    Chandler, AZ
    07 Big Dog K9
    Tom
    I have the S&S 600 cam, john sachs heads and carb,Thunderheart adj ignition and around town I'm in the high 20's on the highway running 75-80 in 6th I'm at 48mpg
    I mainly noticed a drop in town
  17. Thunderdog
    Thunderdog New Member
    Subiaco, AR
    '05 BDM Chopper
    Michael
    I have an 05 Chopper with no restrictor plates,and it has a G carb. I was told by Speeds Performance Plus in texas that 05's can come either way. Maybe depending on where they were sold.
  18. Raywood
    Raywood The Pirate
    Staff Member Founder Lifetime Supporting Member Supporting Member Full Member
    Rainbow, CA
    2014 KMW Regulator
    Ray
    After the 05s were introduced they came out with the option of installing the larger Carb
    Sent from my DROID RAZR using Tapatalk 2
