Thinking of adding an oil cooler.
Discussion in 'Fluids!!' started by liferider, Jun 17, 2012.
  1. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    They do look badass.
    I really don't see them being an functionally good in hot temps much if your lucky a -10 degrees MAX. I actually think the cooler temps you might see the negative impacts of an oil cooler more pronounced. I believe ambient temp is more important. Like riding in 30-50 degree temps, that oil will cool off more than it will cool down with just the air flow versus outside temps of 95-105.
    chubs likes this.
  2. francoblay1
    francoblay1 The Spaniard
    LĀ“Escala, 17130 Spain
    K9 (2006)
    Franco
    :iagree: Shame they are so F***g expensive!!!
    chubs and PacoPetty like this.
  3. Mickeetwo
    Mickeetwo Guru
    Texarkana, AR
    Alan
    I'm with Brooks on this one. Who cares how they work....they look good :D
    PacoPetty likes this.
  4. Knuckles
    Knuckles Active Member
    Littleton, Colorado
    '07 K9
    You still have more surface area and extra lines to offer additional cooling.
  5. Knuckles
    Littleton, Colorado
    '07 K9
    In cold weather you put a cover over them. Leather wrap that blocks the air flow.....kind of like trucks that partially cover the radiator in winter.
  6. NZBigDog
    NZBigDog Member
    Rotorua, NZ
    2002 Mastiff
    Jas
    When you call it a "stash tube", does this mean we can actually open them and use them?
    How does it open
  7. pknowles
    pknowles Getting better by the day...---... GURU
    virginia
    , 2012 CVO Streetglide, 07k9 MAKIN IT MY OWN
    paul
    caps screw off
  8. liferider
    liferider Guru
    Louisiana
    Jonathan
    Here how it looks
  9. JeffM
    JeffM Active Member
    Australia
    Big Dog K-9 2008
    Jeff
    If you ask me....................and you didn't.
    I recon they look ugly, takes away from the smooth lines that the K9 has.
    Also something else to bloody polish and get bugs stuck in.
    Unless you live in Death Valley, oil coolers are a waste of $.
    Sure some motors like to run cooler than others, but i think you will find it has more to do with fuel mixture than motor temp.
    IMO anyway.
  10. mark whitrock
    mark whitrock Active Member
    2007 K-9
    Jet it right and run full syn oil and there is no need for a cooler...
  11. francoblay1
    K9 (2006)
    Franco
    Well... I have installed TWO... they DO L:eek::eek:K GOOD! :D
    :2thumbs:
  12. DRBarnhart
    DRBarnhart Insert title here...
    The Northcoast
    '07 K-9, '90 Fat Boy, & '72 BMW R60/5
    Dennis
    :iagree:
    Dennis
    chubs likes this.
  13. liferider
    liferider Guru
    Louisiana
    Jonathan
    apparently you have never been hung up in traffic on Lazzel st in Sturgis during the rally! yes some of us live in the deep south and 100+ degree days are very common. In 2012 we had 100+ degree days for over 60 days streight here in Louisiana. And yes I rode my dog!
  14. PacoPetty
    PacoPetty Active Member
    Martinsville,VA
    2006 Bigdog Pitbull
    Andy
    They are bad ass! I am looking at buying that same kit for my bike and I was wondering what everyone thought about them. The consensus seems to be split right down the middle and for $589 I am going to have to think about it a lot.
    chubs likes this.
  15. JR03CHOPPER
    JR03CHOPPER Well-Known Member
    Orlando, FL
    2003 Big Dog Chopper, 2007 Big Dog K9
    JR
    They made a difference on my 03...and jetting the carb right does not make a difference. The guy that posted about air flow...no offense...does not understand "combustion" happens in the motor. Duh. Not in the oil cooler. If you take a boiling pot of water and take it off the heat...it stops boiling. Just sayin'.
    DrRx, chubs and PacoPetty like this.
