Tappets adjustments
Discussion in 'Motor' started by Raywood, May 12, 2010.
  1. Raywood
    Raywood The Pirate
    Staff Member Lifetime Supporting Member Full Member Supporting Member
    Rainbow, CA
    2014 KMW Regulator
    Ray
    This is the best explanation yet I've heard on tappet adjustments. S&S Cycles on Facebook is posting some great articles. They sent me some great information yesterday on carb tuning that I will post once the gallery gets back to normal.
    But just want to add this article they wrote today with an illistration: S&S Cycle, Inc.: Push Rod Adjustment | Facebook
    This may be a bit hard to read but I'll get it emailed to me from S&S and post a larger version of it here along with the carb adjustment and post them in the How To section.
    Big D Florida likes this.
  2. BadBrad
    BadBrad 2005 Pitbull
    Brooklyn, MS....Why? Is there another Brooklyn?
    2005 Pitbull / EHC-less
    Brad
    Thanks for the post Ray. But let me ask, how is this different from any previous posting on how to adjust pushrods? The only thing I see that is different is the explanation of limited travel vs non limited travel tappets. Don't most all our dogs have non limited travel tappets?:confused:
  3. V
    V Guru
    It a good re-explanation with good pics that even I can understand. Thanks Richard oh i mean Ray :D:2thumbs:
  4. pisssed
    pisssed pisssed
    Central, NC
    02 BOXER (wrenchin & ridin)
    pisssed
    Sticky please
  5. Raywood
    Raywood The Pirate
    Rainbow, CA
    2014 KMW Regulator
    Ray
    For one it explains better how to find TDC on the rear lifters. Easy with the front by looking at the flywheel marking but the rear is a pain and this explains it better than either manual. And it tells you how to tell if you have limiters which neither manual tells you.
    Sticky it is
  6. outdoorsman26
    outdoorsman26 Well-Known Member
    madison, WI
    2007 mastiff
    matt
    thanks ray all ways thinkin!!!
  7. Brew
    Brew Troop Supporter
    Washington State
    08 Mastiff / 09 Softail Deluxe
    Rob
    Thanks outdoorsman for pointing this out. I was going off the old tread. This new one is a bit different. Thanks for posting the how-to Ray...:2thumbs:
  8. joshdell
    joshdell New Member
    Rowlett, TX.
    2003 Pit Bull
    pushrod covers
    I just got done with the adjustments but my pushrod covers are have pits in them and I would like to replace them. Can I remove the lifter from the pushrod and get the covers off to replace them?
  9. chacha
    chacha Chaff Your EHC!!
    Calendar Participant Full Member
    2001 Nightrain, 2014 Indian Vintage, 2006 Bulldog (sold)
    Mister Fucking Wonderful
    Joshdell wrote;
    Nope. If you have the stock pushrods, they have to come out of the top, so you'd need to pull the cover of the rocker boxes, pull the rockers, pull the rods, replace your covers, then put it back together. Easy enough, but takes some time and gaskets.
  10. oldmutt
    oldmutt Active Member
    Central New Jersey
    08 Mutt
    Mike
    Does anyone know when S&S switched over to the Travel Limiter Spacer?
  11. V
    V Guru
    As Cha Cha said to remove the pushrods you have to pull the top boxes. Another route you can go is with the quickee pushrods from S&S. It requires cutting out your existing pushrods with a bolt cutter or the like (sounds bad but it isn't) The quickie push rods have more thread on them allowing the pushrod to be removed/installed with out pulling the top end componets. It would also you allow you to change cams or pull the lifter blocks later with out pulling the top appart. You can check them out on S&S website. Other manufactueres make them as well.
  12. nine lives
    nine lives Active Member
    Reading PA
    2006 big dog mastiff 1992 harley softail 1996 Kawaski gpz 1100 1983 YamahaIT 490 1997 Kawaski KX 500
    Here is what I don't get. Why don't they say what year got what tappets or how did they decide what motor gets the standard or limited travel? Maybe, enee menee minee moe?
  13. nine lives
    Reading PA
    Non Limited Travel Tappets
    Ok, just incase anyone is interested, I re-adjusted my push rods (I think this is the forth time in 10,000 miles) Anyway, as per the latest adjustment form from S&S I found my tappets to be the non-limited travel. Did a 4 turn from zero and seem to be pretty quiet on a short 10 mile run, already had a 4 turn adjustment at some point, maybe have to keep re-adjusting until full break in.
  14. okred696
    okred696 Member
    OKLA
    Big Dog 07 K9 Limited Edition #41 HD 2012 SE Roadglide (Black and White) 1987 HD Softail S@S 117 6
    RED
    Somethings not right. Once you acheive zero lash you should only go 4 rounds or 24 flats. If you did that twice you are going to have lifter to tight. It has .200 travel or cushion internally and when properly adjusted should be in the middle of its travel. Approxmately at .100 this compensates for wear over time and allows for a quite valvetrain. You might want to call S@S or ask Big Dog Tech01 just to make sure.
