Tappet Screen Mistake Could Cost Me Big $$$
Discussion in 'General' started by mofaster, Jul 16, 2011.
  1. mofaster
    mofaster Member
    Arizona
    2006 Mastiff
    I changed the oil on my 06 Mastiff, and like an idiot put in the tappet screen upside down. Rode for a while, then started to hear a strange noise coming from the engine. rechecked the fluid, seemed to have an air bubble in it or something, refiled a bit. Noise still there. Then I decided to look at the screen, it was upside down, and the screen bent up pretty good.
    So, I'm thinking I did some damage to the engine, and now have to take it in to get looked at. Only have 3500 miles on the bike. I am always so careful with everything, so pissed at myself. Followed GasMan's DIY.
    Anyone with ideas what I could of screwed up, and what this might cost me?
    Thanks.
    chubs likes this.
  2. MARV
    MARV Well-Known Member
    CENTRAL JERSEY
    05 CHOP
    SUL
    noise travels
    could be a loose mount, bolt, vent tube, primary chain, etc.....
    get a mechanic stethoscope and try to pinpoint before you pay someone to do it for you.
    chubs likes this.
  3. mofaster
    mofaster Member
    Arizona
    2006 Mastiff
    Interesting thing to, is the noise doesn't start until like 20 seconds after the bike is running..and almost sounds like a bearing...
    #3 mofaster, Jul 16, 2011
    chubs likes this.
  4. BBChopper
    BBChopper Supports 2 Disabled Vets
    Fellsmere Fl,
    2005 BDM Choppa "Wild Fire", 2011 Electra Glide Ultra Limited "Swamp Rat"
    Pablo
    Cut down Pool Cue works too, small end!:2thumbs:
    chubs likes this.
  5. mofaster
    mofaster Member
    Arizona
    2006 Mastiff
    Got one, I'm so perplexed, now the noise seems to have gone away after letting it idel for a bit....
    If it was something major, wouldn't it be static? Always there? From the beginning?
    Wondering with the new tappet, new oil, etc, it's all lubricated now, etc.
    Sad part is talked to my local "BD" dealer, and he said no luck getting engine parts....
    Oh, and I do have a mechanic's scope, when it comes back (pulling my hair out), I will try to listening more carefully.
    chubs likes this.
  6. Brew
    Brew Troop Supporter
    Washington State
    08 Mastiff / 09 Softail Deluxe
    Rob
    You can get engine parts from S&S or one of our vendors/dealers on this site. Not sure why your dealer said that, might want to visit a different parts supplier... Just saying
    chubs and BadDawg Bill like this.
  7. lee
    lee Well-Known Member
    Bristol, England
    2005 Big Dog custom build and Buell custom build
    that could have been your problem right there - may not have pumped up properly perhaps
    chubs likes this.
  8. john sachs
    john sachs Active Member
    Deltona, Fl
    harleys
    It would seem to me that IF the upsidedown screen,and spring assembly, affected anything, :angry: the first thing you would hear would be lifter noise.
    Doubt that's you problem. :up:
    John
    chubs likes this.
  9. mofaster
    mofaster Member
    Arizona
    2006 Mastiff
    I hope that you are right John, thanks. If it did effect the lifters, what would be the fix, or could it effect other parts of the Rocker Box?
    Also, I always get confused, but when we say lifters we are talking about the pushrods, correct?
    Problem is I can't tell if it is lifter noise or not, I'm taking it in tomorrow for the tech's to take a listen and look.
    Thank you all.
    Kelli's Ride
    #9 mofaster, Jul 17, 2011
    chubs likes this.
  10. Brew
    Washington State
    Rob
    One thought, you did put the correct oil filter on the pup correct?
    chubs likes this.
  11. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    from bottom up:
    cam
    lifter
    pushrod
    rocker arm
    valve
    chubs likes this.
  12. Nukeranger
    Nukeranger Nukeranger
    Luling, Louisiana
    Huw
    Mofaster, I still recommend you call S&S and tell them what happened to you. It can't hurt and they have a lot of experience depending on who you talk to.
    chubs likes this.
  13. john sachs
    Deltona, Fl
    harleys
    All that screen and spring do, is act as another filter (to the lifters) if any crap gets in the oil before being filtered out by your oil filter. The only harm that can be done by installing it wrong, would be if it got crushed, it could possibly block off the oil supply to the lifters.
    The lifters are the hydraullic units with the wheels on them that ride on the cam. Very sensitive to oil supply/oil pressure.:eek:
    How long did you run the motor like that?
    John
    BadDawg Bill and chubs like this.
  14. mofaster
    mofaster Member
    Arizona
    2006 Mastiff
    John, that is what happened, when I removed it, it was crushed up a bit. I went out on 1 10 mile ride, before I started to hear the noise.
    QUESTION: How big of a deal is it if the lifters where damaged, as far as replacing, getting parts, pretty straight forward to replace for a tech. I'm not as concerned about the price, as I am about bigger issues, like engine, etc.?
    Never got any indication of a oil pressure light at all, bike sounds solid, power was fine riding home, starts, other than the noise after about 20 seconds after it's starts. Only been started a few times to try and diagnose the noise.
    #14 mofaster, Jul 18, 2011
    chubs likes this.
  15. Ironmikey
    Ironmikey Member
    Sierra Vista, AZ. 85635
    2004 HD Dyna Low Rider; 2012 HD Custom Super Glide; 2006 Big Dog K9
    Mike
    I wish I was smart enough to just FIND the cotton-pick in' filter on my '06 K9. Flathead screw lower left side of engine (next to a hex bolt?). That's what I was told stopping by a CA shop visiting my sons. Unscrewing it back home in AZ I found a spring inside a tubular plunger-looking tube about the size of a 22 cal. Bullet with a flat end and beveled edge. No screen. A pictures worth a thousand words...and the one in the online owner's manual is indistinct from chrome glare (or even with my glasses I can't tell exactly where it's at). Directions please? Flushed and changed oil but tappets / rockets still sound loud. Buying a mechanics steth tonight. Thanks.
    chubs likes this.
  16. Hirter6Pack
    Hirter6Pack Not Quite A Guru
    Saint Joseph Mo
    2004 Mastiff
    Rick
  17. Nཛ͢ཀཇཧ༏ཧי
    Nཛ͢ཀཇཧ༏ཧי ... .... .- .. -.
    Springfield, Missouri
    2007 K-9
    Shain
  18. BadDawg Bill
    Deltona fl
    Deplorable BadDawg Bill
    I would say your lifters collapsed and made the noise. Once corrected they should refill and be ok. I wouldn't sweat it...
    Srodden and chubs like this.
  19. Ironmikey
    Ironmikey Member
    Mike
    Thanks! Had the brilliant flash of rare inspiration to google it with the right words (Boolean logic was never my strong suit) under videos and Voila'.
    But man you're fast! Thanks! And we obviously have the same sleep pattern. Went out and cleaned it right after watching the video just now - clean as a whistle . Can't check tappet noise cuz my neighbors aren't as enamored with low rolling thunder as I am late at night.
  20. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    I don't think I would be going back to him:panic:
    chubs likes this.
