Tank modification
Discussion in 'Metal Fab' started by Raywood, Apr 14, 2010.
  1. Raywood
    Raywood The Pirate
    Rainbow, CA
    2014 KMW Regulator
    Ray
    Well after years I'm finally getting my tank done. My brother has split it and we are cutting out the strips to enlarge it and get it done. Will be completing it by tomorrow then primer it and head out of here on Thursday morning heading back to Washington. Now won't have to stop every 90 minutes! :D
    First we pulled it, drained it, flushed it and then cut it open. We then cut the new pieces of 16ga and welded them in. Then when we got the tunnel tacked back in we put it on the bike to see if we had clearance at the bars and trees. Everything fits fine and looks good. Here are some pics:
    Draining the remaining fuel in the tank
    [​IMG] [​IMG]
    Here we marked a line down the middle for our cut line. The other two lines would be the projected piece that we would add to the tank about 3" wide at the top.
    [​IMG] [​IMG]
    Next was to flood the tank with argon to inert the inside so it wouldn't blow up on us. Worked great as we will find out later.
    [​IMG] [​IMG]
    Cutting continues as we remove the tunnel under the tank
    [​IMG] [​IMG]
    Turns out that my tank vent tub had broke away again from the screw I put in the cap bung to hold it in. It was making a lot of noise so first thing I did was cut the SOB out of there! See all the liner material I pulled out!
    [​IMG] [​IMG]
    Next was to cut the bung out. I would be relocating it when we put it back in
    [​IMG] [​IMG]
    Now it was time to clean out the inside of the tank. I could just peel out the lining. This tank was five years old now and there was no pieces of liner clogging the petcock screen but I was able to just grab portions of it and pull it free
    [​IMG] [​IMG]
    Now I had some dirty work to do and that was sanding out all of the inside. I took a sanding wheel to all of it and what I couldn't get with this I used a wire brush which I had to use on the tunnel. Real messy
    [​IMG] [​IMG]
    While I was at it my brother had me sand off all the paint and bondo around all the cut lines where he would be welding. This ensured a clean surface plus keep from burning.
    [​IMG] [​IMG]
    It was dirty and really made a mess but I survived. We had our shop girl cleaning up after us, really she was sweeping up the broken glass from our Beam & Cokes. We seem to always be dropping them
    [​IMG] [​IMG]
    Here my brother is welding/filling in the vent tube plug with I won't be using any more. Then we put the tunnel back in the underside of the tank and prepared to tach weld it in
    [​IMG] [​IMG]
    Moving right along my brother cuts out the wedge that will fill the top part of the tank. We cut this out of 16ga sheet which matched the tank. This would open up the tank real nice and make it fit better on the bike
    [​IMG] [​IMG]
    Once we had the tunnel and top wedge piece tacked in we were ready to throw it on the bike and see how it looked and to ensure we had clearance with the bars and trees
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    Back on the table and it was time to start welding it up but before my brother would do this he had to go and cut notches out of all the tack welds. Something about a hot weld meeting a colder spot on the tank. He cut then welded, then cut and then welded over and over
    [​IMG] [​IMG]
    cutting & patching
    [​IMG] [​IMG]
    Before closing in the top we inspected the inside using a bore scope. My brother cut out any welds he was suspect of and re-welded them. Look Ma no vent tube!
    [​IMG] [​IMG]
    Using a piece of stock paper we cut out a template for the front gas cap opeing. We transfered this to the sheet metal and cut it out and then tacked it in place.
    [​IMG] [​IMG]
    To shape it I grabbed the bottom of it while my brother applied heat to it and we bent it down like butter and he tacked it as we went following the shape of the tank. Worked great
    [​IMG] [​IMG]
    The rest was just cutting out some more pieces to close up some of the opening and then get them welded in
    [​IMG] [​IMG]
    Now it was time to figure out where I wanted the bung to go in. So we set it back on the bike and using my gas cap I rotated the bars around and decided to move it up and to the right. This way when I'm gassing up I can ensure I get a full tank of gas
    [​IMG] [​IMG]
    Here is my brother posing with the tank he just modified. He also insisted on appling some bondo to the top for my ride home. I just wanted to shoot a layer of paint on it seeing as I was stripping it as soon as I got home for sealing and piant. But he insisted and layed some bondo on it he pulled off his shelf, problem was it was over 5 yrs old and it never hardened. He even used a heat gun on it so finally after attempting to sand it off which only blotched it up more he just shot a coat of black paint on it. Doesn't look like much but it's a good 5 gls now
    [​IMG] [​IMG]
    Inspecting the final product.
    [​IMG] [​IMG]
    Finished minutes before my 680 mile trip North, infact the paint was still wet when I put the tank on. But I can now go 180 between gas stops!!! Now for some fine paint job of a "Pin-Up" girl on top of it.
    #1 Raywood, Apr 14, 2010
  2. Little-Boo
    Little-Boo Well-Known Member
    Lifetime Supporting Member Supporting Member Troop Supporter
    McAllen, Texas
    2006 Mastiff, several Mods to many to list
    Carlos
    Looks good Ray, :2thumbs:
    Carlos :whoop:
  3. ALDog
    ALDog Active Member
    Hunstville, AL
    2008 Ridgeback
    Carl
    Nice work Ray. How many gallons do you think it will be now???? :up:
  4. Five Five
    Five Five Well-Known Member
    Southern California, The 714,
    2003 pit bull (sold) & 2006 K-9 (bought)
    Bill
    Shit Ray....your deep into the project....i'm saying whoa !!!!
    **handshake** to you and your brother and shop helper too
    keep us posted...
    if you get a chance e-mail me some pictures of your brothers bike i didn't get a chance to see it when i was out there....
    bill@myperea.com
  5. KnotSo
    KnotSo Admin
    Washington
    Perhaps when you ride alone, yet when with others, you will still be stoppin:D
    Still, good job on the tank. Now, who is gonna paint it with a special lady on the side?:hi::2thumbs:
    Say, did ya get the brothers BBC wired up?:D:roll::roll::roll:
  6. RubWhore
    RubWhore Asshole Extraordinaire
    Behind The Still In Backwoods Mississippi
    2010 Homemade K9
    WyldeBill
    How much wider did you make the Tank??? Looks really good!!!
  7. TCALZ06
    TCALZ06 Well-Known Member
    Chandler, AZ
    07 Big Dog K9
    Tom
    Looks Great Ray. I just bought a spare tank for something like this in the future. great pics!!!!
  8. BorgerBigDog
    BorgerBigDog BORN TEXAN
    Borger Texas
    06 Ridgeback,06 Proper Chopper,85 Yamaha Maxim chopped
    Rob
    QUESTION How many other people would ride hundreds of miles from home with his bike being the only ride back home decide to do a MAJOR project like that?
    ANSWER ONE and we all know him as RAYWOOD :roll::roll:YOU ARE THE MAN :up:
  9. chacha
    chacha Chaff Your EHC!!
    2001 Nightrain, 2014 Indian Vintage, 2006 Bulldog (sold)
    Mister Fucking Wonderful
    Brilliant!
  10. jimizee028
    jimizee028 TRUE COLORS COLLISION
    BALTIMORGUE
    big dog chopper 2007
    JIMI
    Good job so far men....what will you do about the cables that will hit the side of the tank from the handlebars??????
  11. lee
    lee Well-Known Member
    Bristol, England
    2005 Big Dog custom build and Buell custom build
    nice work Ray - nothing like a bit of custom fab work to warm the cockles - you gonna pressure test it? Are you also going to reline it?
  12. erldawg
    erldawg Guru
    Raleigh, NC
    2008 K-9 EFI
    Earl
    Looking good Ray! :2thumbs:
    Was that a vent tube u cut out?
  13. RADAMS445
    RADAMS445 RADICAL
    2006 mastiff - 06 sportster-magna v65
    R.J.
    Fabrication is the name of the game! Sweet work with an extra topping of skill! :cheers:
  14. CuDaMaN
    CuDaMaN Member
    Rockville, md.
    2008 Ridgeback
    Greg
    [​IMG][​IMG]
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    V
    Oh yeah.......................................and the tanks nice too.........
  15. narow37
    narow37 Angry Southern White Man
    Sherman, TX
    2007 Big Dog K9
    Shane
    looks good Ray. I know you've been wanting to do this for a long time.
  16. Mach_1
    Mach_1 Active Member
    Rockwall, Texas
    2006 K-9
    I look forward to stopping every 90 minutes in fact most times i want to stop sooner because my ass hurts :roll::roll:
  17. linx
    linx Active Member
    NashVegas, Tennessee
    2006 Big Dog K9
    Rob
    It's gonna look nice for sure. You're more of a go-getter than I am.
  18. linx
    linx Active Member
    2006 Big Dog K9
    Rob
    Pictures aren't working now. Something to do with the server change?
  19. GymRat
    GymRat Member
    Colorado
    2005 BD Chopper
    John
    I can't see the pictures
  20. Daddycool
    Daddycool Active Member
    Broken Arrow, Ok.
    2005 Big dog Chopper
    Marc
    me neither
