Syn in Primary?
Discussion in 'Fluids!!' started by francoblay1, Jul 18, 2014.
Do you use Syn Oil in the Primary?
  1. Never used it
    26 vote(s)
    54.2%
  2. Always used it (no problems)
    12 vote(s)
    25.0%
  3. I had problems in the past
    5 vote(s)
    10.4%
  4. I had NO problems in the past but stopped using it
    5 vote(s)
    10.4%
Multiple votes are allowed.
  1. Mr. Wright
    Mr. Wright Guru
    Supporting Member Full Member
    Salem, Missouri
    Shannon
    A little silicone spray now and then, but I'm afraid if I add oil, it wil just make a mess.
    JoeHawkins, harley74 and francoblay1 like this.
  2. Nukeranger
    Nukeranger Nukeranger
    Luling, Louisiana
    Huw
    Yeah, you don't want to add oil to your setup. It can get on those little lights and cause them to burn out quicker!
    francoblay1 likes this.
  3. liferider
    liferider Guru
    Full Member
    Louisiana
    Jonathan
    In my Ultra I run royal purple true synthetic
  4. JR03CHOPPER
    JR03CHOPPER Well-Known Member
    Full Member
    Orlando, FL
    2003 Big Dog Chopper, 2007 Big Dog K9
    JR
    I was asked this not long ago. I color coded mine so I knew what was leaking by the color. Royal Purple Motor Oil (Purple of course), Red Line HD Trans Fluid with Shockproof (Pepto Bismol), and Red Line Gear Oil for the Primary (Green). Like oil leaks for Dummies. See the color, know where to look.
    JoeHawkins likes this.
  5. headshothills
    headshothills Member
    Scottsdale, AZ
    08 BD K-9
    Chris
    ATF - Per Baker's Note...Not running King Kong... But it looks like Spectro or ATF works... Pick your poison..
    Q: What kind of oil should I use in my primary?
    A: BAKER recommends Spectro Heavy Duty Primary Chaincase Fluid (85W) for all 1980-up stock clutches and mild performance aftermarket clutches. Although we recommend using Dexron III ATF with our King Kong Klutch due to the added friction modifiers found in the Automatic Transmission Fluid.
