Switching to Super G
Discussion in 'Fuel / Air' started by Spikes05, Mar 15, 2017.
  1. Th3InfamousI
    Supporting Member Full Member
    Texas
    04 Ridgeback & 07 K9
    He does and loves it...although his mileage went in the shitter with it though. Not sure I'd be a fan of that.
    Big D Florida and chubs like this.
  2. Spikes05
    Spikes05 Member
    Lodi California
    05 bulldog
    Jerome
    I agree 100% that was bs and I hope that they put the effort to tune his carb and not try to run a game on him to sell him a mikuni.
    chubs and Unsprung like this.
  3. Butch Cassidy
    Butch Cassidy Active Member
    Full Member
    Fate Texas
    2000 Bulldog
    BUTCH
    My xXx is great ! but I did not get the Tazz .... no need for me. My rpms will never get that high for very long.....
    chubs likes this.
  4. Spikes05
    Spikes05 Member
    Lodi California
    05 bulldog
    Jerome
    Our other friend is having trouble getting his xxx dialed in what jets are you running?
    chubs likes this.
  5. FrankBDPS
    FrankBDPS Well-Known Member
    Full Member
    North Lawrence,Ohio
    Frank
    No the mileage sucks as it is but it takes fuel to make horsepower.
  6. pauldeepsea
    pauldeepsea Well-Known Member
    Full Member
    California
    Paul
    They were definitely going to work the s&s to dial it in. Just wanted to show me some other options. Unless there is something completely messed up with the carb the xxx is staying.
    chubs likes this.
  7. Th3InfamousI
    Texas
    I get 35-43 mpg i don't think that sucks.
    chubs likes this.
  8. T.Byrd
    T.Byrd Well-Known Member
    Full Member
    KY
    2006 Harley Davidon Ele. Glide Classic
    Tom
    I'd stick with the XXX. Go to s&s web page they tell you how to ajust and what jets to change when u r having problems. That's what I did when I went to the G. I also vented mine.Look at my post its on here somewhere.
  9. pauldeepsea
    Full Member
    California
    Paul
    I plan on it, I have changed jets and it runs better, no stumble. The issues I am having is irratic idle.. yes I have sprayed for leaks and no change in idle. The problem I was having with the idle is that if I parked it in neutral the idle would drop to about 5-600 rpms and the bike would sometimes cut out, unless I crack the throttle. The other 2 issues were plugs burning irratic front was lean, rear was black rich. Also if I jam on the throttle from idle I would spray a shit ton of gas out of the air filter. I have reset the carb over and over, adjusted the fuel mixture and the accelerator pump with no luck. It's going up on the dyno and getting adjusted and hope this will tweak it where it needs to be. I will post the results and the fix once I get the info.
    Unsprung, chubs and Srodden like this.
  10. Spikes05
    Spikes05 Member
    Lodi California
    05 bulldog
    Jerome
    Is your bike an 05 model? If so the 05 models have restricter plates in between the intake manifold and the heads and that will cause problems when try to push more air and fuel through the intake than it can handle because of the restricter plates. But if you have a G setup this should not happen unless they left the restricter plates in when they installed the G setup.
    chubs likes this.
  11. Spikes05
    Spikes05 Member
    Lodi California
    05 bulldog
    Jerome
    What do you mean vented your carb? Did you change your air bleed?
    chubs likes this.
  12. FrankBDPS
    Full Member
    North Lawrence,Ohio
    Frank
    Nope that's pretty good. I'd settle for that but we ride in different parts of the country. It's very seldom I get on the bike and run out a full tank of fuel in one ride.
  13. liferider
    liferider Guru
    Full Member
    Louisiana
    Jonathan
    IMG_8297.PNG Before you buy look hard at a Mikuni 47!!!! It woke my dog UP!!!!
    chubs likes this.
  14. pauldeepsea
    Full Member
    California
    Paul
    My bike is a big bear 06 sled. It has a super e
    chubs likes this.
  15. Big D Florida
    Troop Supporter Supporting Member Full Member
  16. pauldeepsea
    Full Member
    California
    Paul
    Bike is done and going over to pick it up. I will post the info when I get back with the results. After discussing it briefly on the phone with the shop it was only minor adjustments in the jetting and setup. Will find out more when I discuss in person. Hopefully this will help you.
    Unfortunately I got pretty frustrated and decided to pay someone else to get it setup. Normally I like to do my own work but I am at the point I just want to ride.
    Unsprung and chubs like this.
  17. Th3InfamousI
    Texas
    Well that's fantastic.
    Nothing wrong with getting a Dyno tune. That is better than anyone can do just reading plugs.
  18. Spikes05
    Spikes05 Member
    Lodi California
    05 bulldog
    Jerome
    Hey sometimes we all get to that point and a dyno tune if done right with the air gas analyzer means your bike should be set up as good as it can be. The performance should be awesome. Can't wait to her all about it.
    Unsprung likes this.
  19. SEAL-rider
    SEAL-rider Active Member
    Del Mar, CA
    2005 Big Dog Chopper 600 cam, John Sachs Super G Carb, V&H Big Radius
    Spencer
    G manifold is size 398 manifold #16-2596 with extra vacuum fitting. This manifold assumes you have removed the restrictor plates and are not using spacers. I got this part# from S&S.
    #39 SEAL-rider, Mar 17, 2017
  20. Spikes05
    Spikes05 Member
    Lodi California
    05 bulldog
    Jerome
    Ok thanks, does it still have the map sensing for the IST ignition? When you say extra vacuum port do you mean it has 2? I found a 398 16-2602 do you think it would work its for or from an American ironhorse. They ran 111",117",124" motors in there bikes.
