Switching to Super G
Discussion in 'Fuel / Air' started by Spikes05, Mar 15, 2017.
  1. Spikes05
    Spikes05 Member
    Full Member
    Lodi California
    05 bulldog
    Jerome
    Hello everyone I need help with finding out the part number for the correct Super G intake manifold for my 117 ci motor can anyone help with this. Thank You JD.
    chubs likes this.
  2. Butch Cassidy
    Butch Cassidy Active Member
    Full Member
    Fate Texas
    2000 Bulldog
    BUTCH
    ... talk to Bob Maltz at xXx carbs..... 936-788-3245
    chubs likes this.
  3. pauldeepsea
    pauldeepsea Well-Known Member
    Full Member
    California
    Paul
    PROFLYER and chubs like this.
  4. Spikes05
    Spikes05 Member
    Full Member
    Lodi California
    05 bulldog
    Jerome
    Ok thanks for the info and advice.
    chubs likes this.
  5. pauldeepsea
    Full Member
    California
    Paul
    IMO . I would not do it again. The carbs look great still to this day I can't get it dialed in.. not worth the $. Bikes going on a dyno tomorrow and will post more info. Imho don't waste your $ with xxx. Ripoff! My stock e performed much better
    chubs likes this.
  6. Spikes05
    Spikes05 Member
    Full Member
    Lodi California
    05 bulldog
    Jerome
    I installed the bombsight center piece in my E carb and know it won't run right. I have an S&S dual runner and hooker darkside radius pipes that are stepped to 2.5" so I thought it would help me not have to go with the G setup but now it runs worse I used to have a slight hesitation once and awhile at cruising speeds but know it wants to stall out between 2000 and 3000 rpm. It had a really small main jet .072 and I changed it to a .078 I think I should have just started with changing the main jet. I think it's that center bombsight piece that is messing things up so I am going to remove it and see what happens. But I think that I still want to switch to the Super G setup but not the xxx tazz I have heard lots of good things about the Ultima R1.
    chubs likes this.
  7. pauldeepsea
    Full Member
    California
    Paul
    What is your intermediate jet size?
    chubs likes this.
  8. Spikes05
    Spikes05 Member
    Full Member
    Lodi California
    05 bulldog
    Jerome
    .031 the jets are what was recommended for the mean mothers pipes which is what I had previously had on the bike.
    chubs likes this.
  9. pauldeepsea
    Full Member
    California
    Paul
    You may want to try bumping up your intermediate jet. I had the same issue it would sputter between the 2600-3000 rpm. I am running a fairly large intermediate at .034 with a .68 main. The xxx is also modified with a setup similar to your bombsight centerpiece. Hopefully the shop I am taking it to can get it running great and I can post how great the xxx carb is. I know others love the xxx carb but I haven't been able to get mine running great.
  10. Spikes05
    Spikes05 Member
    Full Member
    Lodi California
    05 bulldog
    Jerome
    Is it still sputtering with the jets you got in there now? I think that you are going to find that the .068 main jet is way to lean I am pretty sure that you are going to have to bring down the intermediate jet and increase your main jet. What kind of air cleaner and pipes are you running?
    chubs likes this.
  11. pauldeepsea
    Full Member
    California
    Paul
    It is no longer sputtering, it seems to be running allot better with the .068 originally I started with a .072 main jet and bumped it down.
    chubs likes this.
  12. Spikes05
    Spikes05 Member
    Full Member
    Lodi California
    05 bulldog
    Jerome
    I'm to work on mine today and see what I can do to make it run better. Let me know what jet setup you have after the dyno tuning because that might help me figure out what direction I need to go.
    chubs likes this.
  13. pauldeepsea
    Full Member
    California
    Paul
    Will do.
    chubs likes this.
  14. awg
    awg Well-Known Member
    Full Member
    Ohio
    2008 Big Dog Chopper, 1980 Honda Passport, 1965 Honda Benly, 1967 Sears Sabre
    There you go!
    chubs likes this.
  15. pauldeepsea
    Full Member
    California
    Paul
    Dropped the bike off and they were trying to get me to shift to a mikuni carb. I have heard good things about mikuni but really want to stay with the s&s.
    chubs likes this.
  16. FrankBDPS
    FrankBDPS Well-Known Member
    Full Member
    North Lawrence,Ohio
    Frank
    Send you're carb to John Sachs and be done with it.
    Big D Florida likes this.
  17. pauldeepsea
    Full Member
    California
    Paul
    It's at a local shop hopefully it's only a minor adjustment.
  18. Spikes05
    Spikes05 Member
    Full Member
    Lodi California
    05 bulldog
    Jerome
    Mikuni carbs are supposed to be really good a lot of HD owners use them they are a flat slide 4 jet carb. I don't know how hard they are to tune. I have heard that it is as close as a carb can get to fuel injection. It costs between $500-$600 just for the carb and intake manifold let alone the labor if you want it installed then they will have to dyno it again and adjust the jets. So since you already have a good chunk invested in the xxx carb I would stay with it plus it's original equipment and mikuni's are Japanese.
  19. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    That's kinda depressing that was their response. New customer comes in with a chrome S&S and they immediately try and sell you a different thing.
    I have heard great stuff about Mikuni but just shows lack of interest to me by the shop. To work with what the customer has.
    I hope they do you right in end.
    BigDogRick and Unsprung like this.
  20. FrankBDPS
    Full Member
    North Lawrence,Ohio
    Frank
    Dosent Liferider have a Mikuni on his bike?
