Stock speedo rubber buttons
Discussion in 'Customizing & Add-ons' started by Mr. Wright, Aug 9, 2017.
  1. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Alright, their almost here. I finally got around to getting the mold made for the rubber buttons.
    I did a test pattern with 9 buttons, and will do the rest once we get them right.
    Sorry, I didn't take a picture of the other plate.
    Anyway, I took it over the my rubber man, and he ran a couple test runs.
    I have a small problem at this point. The rubber he uses, is a bit stiff. He has some softer stuff, but it's red.
    When I put it on the speedo, it will push the reset, but I'm afraid it will break the glass. So I'm going to adjust the mold a bit and try again tomorrow. Getting a softer black rubber will be to expensive, so if this doesn't work, the buttons will have to be red.
    I'll keep you posted.
  2. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Hard rubber problem...man...haha
  3. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    It
    It will squish, just not very easily.
  4. kickstart
    kickstart Well-Known Member
    TN
    52 Pan,05 Bulldog, 07 K9
    Pat
    Hell, I forgot all about this. Don't forget to send me the sample back.
  5. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Will do.
  6. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    I was just sitting here trying to figure out how he separates the buttons out of the sheet. And if I have to cut each one out with a pair of scissors, their going to cost more.
  7. Psycho
    Psycho PSYCHO
    Mesa, Arizona
    2005 BDM Chopper RT, 2005 Mean Streak
    Bruce
    You might try to reduce the flange thickness of the larger diameter that meets the glass by 30 - 40 percent, as it would help with the compression ratio ... just a thought. Seems that that flange should be more of a seal to the glass rather than a support flange. GREAT JOB THOUGH !:cheers:
    #7 Psycho, Aug 9, 2017
  8. HMAN
    HMAN Well-Known Member
    fk it
    I seem to remember some threads on the old site that delt with replacing the glass? After looking at my 04 speedo, I dont see anyway to disassemble it? Any threads left that speak to that....Ive searched but come up empty....tia. My button is ok but lens is cracked.
  9. awg
    awg Well-Known Member
    2004 Big Dog Chopper
    Can you paint the red buttons black?
  10. BWG56
    BWG56 Guru
    Big Dog
    Ker
    What do you recommend doing to eliminate the same problem from happening to the new buttons?
  11. awg
    Hmm.....how about a magic marker?
  12. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    I thought of that, but I'm going to shorten the inside first. thanks
  13. Matheny 514
    Matheny 514 Active Member
    Auburn, Alabama
    2005 Big Dog Ridgeback
    Justin
    Great job Shannon, excited to see the end result :old2:
  14. Doggin it
    Doggin it Active Member
    Lakemoor,Illinois.
    2007 Bulldog 2005 HD Classic
    Cliff
    You are amazing.
  15. awg
    There you go!
  16. Th3InfamousI
    Texas
    I don't think that's the goal. Rubber will crack after a few years no matter what. Just creating to have a source of buttons for folks so they don't have nothing showing.
    I love the analog speedometer myself
  17. bruce
    bruce Active Member
    fawn grove, pa
    2006 BIGDOG K-9
    Bruce
    I used a rubber cap that goes on a cars brake caliper bleeder and wheel cyl. I glued it on with weather stripping glue. it has been on now for a couple years and works fine. there are different types of these caps, I used the one with a rim all around the edge - it almost looks just like what is being made here on it post.
  18. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    After talking to the rubber man today, I'm redesigning it a little bit. So I welded up the mold and re-machining it. Hope to have it back to him tomorrow for testing.
    Rottweiler likes this.
  19. BWG56
    BWG56 Guru
    Big Dog
    Ker
    Goal? the problem is not cracking, its the reset stick wearing thru the top of the button.
    The analog was always bouncing +/-5mph and they die anyway
    #19 BWG56, Aug 9, 2017
  20. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Second test run works great. Don't get in a hurry yet, I still need to finish out the mold for a production run. I do not have a price yet. When they are available, you will be able to order them from the Kaptin for the same price I'll have them for.
    Instruction on mounting them.
    1. When your old button come off, it may leave a small piece in the hole. If you try to dig it out, you may crack you glass, so just take a small pick, and push it to the inside.
    2. clean the glass, then take a tooth pick or paper clip, and put a small amount of black silicone on the button, being careful not to get any in the center hole.
    3. Press in place.
    I'll let you know when they are available.
    Dusty.B, cdogg556 and Forsaken like this.
