Still on the hunt for a cable and software for an '07 K9
Discussion in 'Ignition / Electronics / Batteries' started by mainstream01, Sep 29, 2017.
  1. mainstream01
    mainstream01 Member
    Holts Summit, Missouri
    2007 K-9
    Tim
    I've been looking for a cable and software for the Thunderheart box for, an 07 K9 for awhile. Has anyone found such an animal? More than one set of eyes would help me track down this unicorn..
    #1 mainstream01, Sep 29, 2017
  2. mainstream01
    mainstream01 Member
    2007 K-9
    Tim
    For the Thunderheart box.. Carburetor style..
  3. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
  4. mainstream01
    mainstream01 Member
    2007 K-9
    Tim
    Yep.. I've got the RIP kit and I'm looking for the cable and software that comes with the control module.. My module doesn't have the easy click adjustment, just a port for the cable..
  5. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    I don't think thunderheart licenses the software except to dealers it's locked.
    There is a programmable ignition which has 6 or 7 different preset ignition curves. That you can buy from thunderheart directly.
    Just curious why you want to change it anyways?
  6. mainstream01
    mainstream01 Member
    2007 K-9
    Tim
    Unless I buy a whole new control box and the software and the cable is included..
  7. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    You need to buy the programmable ignition if you want to change timing n the rev limiter. Or you can write your own also if you have the know how. DOC does have a hopped up program for his bike but you'll have to talk to Jeff
  8. mainstream01
    mainstream01 Member
    2007 K-9
    Tim
    I'd like to know exactly what the presets are for my module and get real time data log.. My rev limits according to the tach are lower than the 5300 average presets.. I'd also like to know what the advanced timing presets are, because I've had the carbs jetted, adjusted the carb in all manners, bumped up the octane levels. And it still falls on its face for split seconds, and has a semi dead spot between cruising and acceleration.. And it's not the carb pump adjustment either..
  9. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Position Rev Limit RPM
    0 5984
    1 5984
    2 5984
    3 5984
    4 5984
    5 5984
    6 5984
    7 5984
    8 6240
    9 6240
    A 6240
    B 6240
    C 6240
    D 6240
    E 6240
    F 6240
  10. mainstream01
    mainstream01 Member
    2007 K-9
    Tim
    Which position does it go in again?
  11. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    You don't have a programmable ignition, but if you did, just turn the white dial to your selection
  12. HMAN
    HMAN Just like to ride
    Ks
    Harry
    A looong while back I was chatting with Doug of CA Jones, and he said he had a cable, maybe... He wasnt sure IF he could even unlock or change any settings. There were so many "ifs", I figured its easier to just buy a new programmable ignition.
  13. mainstream01
    mainstream01 Member
    2007 K-9
    Tim
    Why not.. I guess.. it's the only thing electrical left that I haven't replaced..
  14. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    If you expecting big gains from changing the program, your in for a let down. The only way to see a difference is if you have it dyno tuned to see the read out.
  15. pknowles
    pknowles semi-retired...---... GURU C7Z06...---...
    virginia
    paul
    I think the latest is you still can't program a locked unit... heavy on the "you".
    dentdude36 likes this.
  16. HMAN
    Ks
    Harry
    Are you running the super G? If so, is it the newer or older model? The older ones had a drilled .040 air bleed. The new ones have changeable air bleed jets. My 04 is an older model and will NOT dial in. A Mikuni 48 is on my short list. Jmo
