starting problems
Discussion in 'Ignition / Electronics / Batteries' started by 1baddawg, Jun 10, 2012.
  1. Brew
    Brew Troop Supporter
    Washington State
    08 Mastiff / 09 Softail Deluxe
    Rob
    PM Bigdogpartsking he's sold some PCBs in the past. He might have one for you...
  2. Nukeranger
    Nukeranger Nukeranger
    Luling, Louisiana
    Huw
    :2thumbs:I agree but thinking out loud myself - when I retire, I should start making PCBs. The last time I made any was in 1978, or 9, I think.:D
  3. Dakotabos
    Dakotabos Well-Known Member
    Calendar Participant Supporting Member
    Outside Rapid City SD
    2004 Big Dog Chopper (Wired Old School)
    OK this statement Im going to get shit for.....
    It may be the wrong slam button. It may be pushing it too deep and gets hung up. The outside cap fits but the plunger (When you push it) goes too far and gets hung up. The spring inside will wear out and wont return the plunger
    Sorry no other way to put that except :eek:
    I have always started my bike that way (Hit the Stop, Hit the Run, Hit start)
    But now instead of hitting start (PCBoard bad) I hit the slam button
  4. Slick-Dog
    Slick-Dog Active Member
    Grove,Oklahoma
    03 RTChopper 07 K9 PDM KIT
    Steve
    I thought the same damn thing to!! They both look the same :)
  5. Srodden
    Srodden Well-Known Member
    Flint, Michigan
    2011 mastiff, 2013 deluxe
    Scott
    I could use a right hand pcb too mine works but there is no clicky clicky for blinker and have to push hard.
  6. Raywood
    Raywood The Pirate
    Rainbow, CA
    2014 KMW Regulator
    Ray
    Won't work cause the right side has the black lead coming off for the brake light
  7. 1baddawg
    1baddawg Member
    2004 bid dog chopper
    Thanks
    Thanks to all who replied, I'm sure I will be looking for more help soon. Also I am looking for a service manual for my bike
  8. 1baddawg
    1baddawg Member
    ok I can push the whole start / stop button in and it closes the circuit and fired up, then shut down. Now no spark at the the spark plugs at all. Would the open circiut on the start button mess up the EHC in not allowing the plugs not to get spark to them ?
  9. Tarzan
    Tarzan New Member
    2004 Big Dog Ridgeback
    Does anyone know where I can purchase a slam button for my starter? My right side circuit board has quit running. Right now I have ran a new hot wire straight to my starter coil that I hold momentarily to start the bike. It works, but I'd like something better. A new circuit board would be awesome.
    chubs likes this.
  10. boomer4444
    boomer4444 Active Member
    dysart ia
    2005 Ridgeback
    jason
    pretty sure wild steed worx would have them, they are listed under vendors on the main page, site sponsers and great people todo business with, u wont find more knowledgeable people about our bikes!!
  11. Rufus1
    Rufus1 Member
    illinois
    2004 BigDog Mastiff
    Shawn
    I have a 2004 mastiff that had the same starting issues. It came down to the bolts on the battery leads were loose. You can grab the battery cable to see if loose, seemed tight. Put a wrench to it turned less than a quarter turn. It would then start. I have used the blue thread lock it helps. But I carry a 10 mm wrench just in case. It use to take two three tries to start. In my case I put smaller jets in and now it starts on first try. The other day I pushed start button every thing went dead. Battery tender got unplugged. Charged battery all is good. I know you checked the ground. But would check the positives side as well. I thing I learned from here start simple. I was going to try that starter jump button. Never got it. At this time I don't think I personally need it.
  12. Nukeranger
    Luling, Louisiana
    Huw
