starter, battery or something else?
Discussion in 'General' started by what?, Nov 30, 2017.
  1. what?
    what? Active Member
    NJ
    2008 big dog pitbull
    Bill
    was out riding yesterday (100+ miles) and was on and off the bike with no issues. last stop i went to start the bike and there was a loud click. motor wouldn't turn over at all. tried again and no click, with the speedo/tach flashing like crazy. had limited tools so could only trouble shoot so much. battery seemed to have juice and all connections were tight. one thing i noticed was the rubber sleeve on the starter ground was all dry rotted but the wire was intact.
    the bike ran fine all day until that last stop. before i started pulling stuff off the bike i wanted to see if anyone has thoughts on this. I'll start by load testing the battery, then probably get into the starter.
    thanks
  2. dentdude36
    dentdude36 Guru
    Suburbs of Buffalo NY
    2007 K9
    Kevin
    How old is the battery? Hey it running and see if the battery is charging properly
    BWG56 likes this.
  3. what?
    what? Active Member
    NJ
    Bill
    has to be a few years old at least. usually keep it on a trickle charge if its sitting for a long time. would the battery just crap out like that?
    the battery wasn't draining down when i hit start. the starter would just click, if it did that at all.
  4. dentdude36
    dentdude36 Guru
    2007 K9
    Kevin
    Yea a battery can go anytime and it sounds like it's older so I'd start there
    Forsaken likes this.
  5. wewjr71
    wewjr71 Member
    Bristow,VA.
    06 Pittbull, 16 Breakout,16 sportster 48
    william
    check all your connections also,make sure there tight
  6. BWG56
    BWG56 Guru
    Big Dog
    Ker
    I
    #6 BWG56, Dec 1, 2017
  7. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Sure will.
    Earlier this year I had a one year old battery I rode it around the weekend before no signs of anything and next weekend went to start it and click click..
    #7 Th3InfamousI, Dec 1, 2017
  8. Little-Boo
    Little-Boo Well-Known Member
    Troop Supporter Supporting Member
    McAllen, Texas
    2009 Sporty Trike Converted, 2013 Tri-Gluide, 2006 Mastiff, several Mods to many to list
    Carlos
    Check your CB or reset it just in case. It is possible the bike was running on battery only till you killed it. I say that because if your CB is tripped the VR is not charging your battery at all. I took the CB out a long time ago and replaced it with a 40amp fuse. The Fuse won't trip it just blows and easy to replace or find out if the VR is working or nor. The CB will trip and you will only find out when you battery is dead or close to being dead. The Trickle Charger probably kept your battery going when you used it on short runs. My :2cents:
    Carlos :chopper:
  9. Kobi
    Kobi Member
    Josephville MO
    2008 Ridgeback, 2004 CVO Deuce
    Kurt
    My 08 Ridgeback has done that a few times to me too, hot or cold. The last time it did that i pushed down on the rear compression release rubber cap and then it cranked over great. I'm thinking the compression release stuck and that cylinder was on it's compression stroke and just too much for the starter? Mine was a cold start this last time. I was reading these releases stick at times. My bike gets little use, 08 with 2200 miles. I pushed on the release button a few days later and seemed to stick a bit when pushed(did not try to start the bike), front release did not have that sticky feel to it. I'm going to put some WD40 in it over the winter and see if it helps.
    Olde Man likes this.
  10. Rottweiler
    Rottweiler Active Member
    Elizabethtown, PA.
    2004 Chopper, 2014 HD Road King CVO, 1985 FXWG
    Todd
    Are you sure that starter ground is a ground and not a Pos. wire? Yes load test that Battery first. The loud click sound came from the starter area correct?
    Good luck let us know what you find.
  11. dentdude36
    dentdude36 Guru
    2007 K9
    Kevin
    I would assume in your case it's just carboned up and sticking up the wd40 would probably cure that
  12. what?
    what? Active Member
    NJ
    Bill
    I mentioned the wire because it is clad with rubber. Or used to be. It all fell apart and was wondering if water may have gotten down inside the starter or just dirt in general. I put over a hundred miles (140) before it crapped out on me. On and off the bike and restarted multiple times without issue. I’ll get into it this weekend. if I see if it’s not the battery, then I’ll work back from there. Going to the bike show in NY this weekend so let’s hope a different bike doesn’t catch my eye there. Thanks a ton guys for the responses
