spitting and sputtering at 3200 - up RPM
Discussion in 'Fuel / Air' started by Champballkiller, Sep 12, 2016.
  1. Champballkiller
    Champballkiller New Member
    Lincolnton, NC
    2006 Big Dog Ridgeback
    2005 Ridgeback 117 Super G Vance& Hines Big Shots Spike air cleaner #78 main jet RIP Upgrade
    Bike spits and sputters at high RPM (3000 - up) good power up to that point. Anybody got any suggestions.
    chubs likes this.
  2. Brew
    Brew Troop Supporter
    Washington State
    08 Mastiff / 09 Softail Deluxe
    Rob
    Which way is your cone pointed? If forward that could be the cause, a lot of folks point their spikes up!
    francoblay1 and chubs like this.
  3. Brew
    Washington State
    Rob
    Mine is pointed forward also and runs fine. I'm running a 31 and 78 for jets.
  4. HMAN
    HMAN Well-Known Member
    Ks
    Check the rubber caps on top of the carb. They dry rot and leak.
    francoblay1, chubs and dentdude36 like this.
  5. blacktopper
    blacktopper Active Member
    Pittsburg Kansas 66762
    07 K 9, 08 Ridgeback, 10 K9
    Did you recently clean and oil your air filter?
    chubs likes this.
  6. Champballkiller
    Lincolnton, NC
    Thanks for the replies.... the spike is pointed forward and the bowl vent removed. I will check the caps. Have not recently cleaned the air filter. I have adjusted the carb and it doesn't pop and backfire on decel or anything like that. I just can't get it to wind up with full power before i shift. Could the ignition box have an issue?
    chubs likes this.
  7. Champballkiller
    Lincolnton, NC
    Problem started after the bike was put back together after having the tank painted over the winter. I cleaned the screen on the petcock before putting it back in. I am getting plenty of fuel. I even mixed some 100 octane in with the 93 non ethenol to see if running cleaner fuel would help. I changed the plugs tonight too and I will see if that helps tomorrow. I will also turn the spike up.
  8. Champballkiller
    Lincolnton, NC
    I had a flush cap that wasn't venting. I just installed a new cap from shoveheadkicker that vents properly, but have only test rode it twice since then. I think that might have caused some problems. I'm going to look at the vent caps tomorrow for sure.
    chubs likes this.
  9. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    I had a spike on my 05 Bulldog and could never get it to run pointing forward, it would do the same thing up to 3000 rpm or so and then sputter and cough, just ran like crap, turn it vertical and it worked great, just didn't look good to me so it came off, went to the stock Big Dog and it looked and ran great. :old2:
    chubs likes this.
  10. blacktopper
    Just for a test clean the air filter with the solvent provided by k&n rinse it and let it dry and put it back on the bike with no oil on it and take it out for a short test ride.
    chubs likes this.
  11. Champballkiller
    Lincolnton, NC
    Thanks for the help so far guys. I have changed the direction of the spike, adjusted the carb, cleaned the air filter, replaced the rubber vacuum cap on top of the carb, and replaced the plugs. The problem has moved down to the 2400 - 2800 rpm range now. Please help if you can, I've ran out of ideas. No matter whether I ease up through that rpm range or run hard through it, it still runs bad at that spot. could my ignition box be going bad? I only have a week to get this fixed. I'm headed to Myrtle Beach Bike Rally this weekend.
    chubs likes this.
  12. Champballkiller
    Lincolnton, NC
    yes sir. did that when I first put the spike on. Bike ran fine this spring. Just started having problems after the bike sat a while.
    chubs likes this.
  13. nobbyjohn
    nobbyjohn Active Member
    bishop,calif
    2004BDridgeback&07-k9
    vernon
    Hey guys I'm having about the same problem,the lower gears as you wind it up it has a flat spot but if you crank it up it doesn't miss.I recently added the spiked air cleaner, the problem that really concerns me is the front cylinder is running lean. I have a triple XXX carburetor and is the bowl vent plug on the inside of the carb .totally confused,which is a normal way of life for me!!!!
    chubs likes this.
  14. francoblay1
    francoblay1 The Spaniard
    L´Escala, 17130 Spain
    K9 (2006)
    Franco
    #14 francoblay1, Apr 18, 2017
  15. BWG56
    BWG56 You all know I'm a liar
    Big Dog, SpyderF3
    Ker
    I wonder if it isn't as simple as bad gas if it sat. :oldconfused:
    chubs likes this.
  16. francoblay1
    K9 (2006)
    Franco
    My bike has been sitting for a year with a full tank... I might go to pick her up in a month or so... should I change the gas?
    I don´t think I will, it´s too expensive to just throw it away!!!!
    bdm7250 and chubs like this.
  17. Dakotabos
    Dakotabos Admin
    Staff Member Supporting Member Calendar Participant
    Outside Rapid City SD
    2004 Big Dog Chopper (Wired Old School)
    Simple stuff first. Read your plugs 1st. SECOND... Pull jets and check them. Id start with main jet. My .02 cents
    chubs likes this.
  18. nobbyjohn
    bishop,calif
    vernon
    Thank you for the information,do you have an idea why just the front cylinder is running lean????
    chubs likes this.
  19. BWG56
    Big Dog, SpyderF3
    Ker
    Does your gas over there have ethanol in it? and did you add any stabilizer to the gas?
    chubs likes this.
  20. francoblay1
    K9 (2006)
    Franco
    Not sure if these guys have seen this... check last post on page 1.
    chubs likes this.
