Speedometer mount
Discussion in 'Metal Fab' started by Mike manson, Feb 18, 2018.
  1. Mike manson
    Mike manson Well-Known Member
    Full Member
    Erie pa
    2005 bigdog ridgeback
    Mike
    I bought Dakota digital 5000 series the mount that you use your it won’t work because my riser are to close together somehow I gotta use one bracket to mount im stumped here are some pics maybe you can help[​IMG]
  2. Mike manson
    Full Member
    Erie pa
    Mike
    [​IMG] it will under mount under bars have enough room just gotta come up with a bracket
  3. pauldeepsea
    pauldeepsea Well-Known Member
    Full Member
    California
    Paul
    How much clearance is it off?
    If it’s close I would sand down the edges of the mount. You could use painters tape and sand and smooth the edges to squeeze it in
  4. Mike manson
    Full Member
    Erie pa
    Mike
    If I do that then the wires are in the way
  5. Mike manson
    Full Member
    Erie pa
    Mike
    [​IMG] you think if I buy this then drill new hole it would be ok with just one bolt
  6. pauldeepsea
    Full Member
    California
    Paul
    I don’t think one bolt will hold it there is allot of vibration through the bars.
  7. Mike manson
    Full Member
    Erie pa
    Mike
    Can u grind on chrome
  8. pauldeepsea
    Full Member
    California
    Paul
    You can, cover it with painters tape first.
    I wonder if you could drill a hole through the backing plate and route the wire through it
  9. Mike manson
    Full Member
    Erie pa
    Mike
    [​IMG] this is clamp
  10. Mike manson
    Full Member
    Erie pa
    Mike
    The part is made from aluminum then chromed I believe but I was gonna hit with a clear coat when I was done
