speed wobbles
Discussion in 'Help Wanted' started by Fitzy, Nov 30, 2010.
  1. what?
    what? Active Member
    Central NJ
    2008 big dog pitbull
    Bill
    had it up to 100+ a few times and never had the wobble. these roads in NJ can sometimes be like riding on the moon..............and with a rigid frame i try to avoid this unless i am familiar with the road i am riding on.
    IMO these bikes are not the best at cornering.
    hows the meat on the tires...balance wise that is? Somebody else mentioned the cold......tires do need time to heat up.
  2. BigDogBro1
    BigDogBro1 Made in the USA
    Near Hell MI
    07 Bulldog, full chrome, Pergy w/gold leaf paint, V&H BR pipes, Gator & Ostrich seats
    No matter...I wouldn't want to ride any other!
    I think it's somewhat of a suspension issue. I might drop the tail a 1/2" from stock this spring and give it a try.
    #22 BigDogBro1, Dec 11, 2010
  3. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    A windsheild will help with some down force on the front end and keep the big pressure off your chest, however I know, I know its not kool:whoop:
    francoblay1 likes this.
  4. Brew
    Brew Troop Supporter
    Washington State
    08 Mastiff / 09 Softail Deluxe
    Rob
    I have the same issue, usually happens in a turn while going down the highway crossing a mid span on a curved road. I've gotten use to it and know it's going to happen so no worries. It did scare the crap out of me the first time it ever happened though...
  5. TEXASDOG
    TEXASDOG TexasDog
    Austin, Texas
    2002 big dog mastiff, 1994 Dyna Lowrider, 2001 Superglide
    Crude Family
    I recently raised the back end on my Mastiff about a half an inch and it got rid of the wobbles at about 90 and it handles much better in the curves. Plus it doesn't bottom out as much.
  6. Unsprung
    Ruskin, FL
    Gerald
    Hope there’s another way cause I don’t want to raise it any...:rolleyes:
    bigkelk9 likes this.
  7. francoblay1
    francoblay1 The Spaniard
    L´Escala, 17130 Spain
    K9 (2006)
    Franco
    I has taken you 7 years to find out about it???? :smash:
    cdogg556, kickstart and bigkelk9 like this.
  8. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    That was back in 10', now I don't give a shit:D or a Rats a$$:oldlaugh:
    francoblay1, bdm7250 and dentdude36 like this.
  9. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    That's not what it says at all..
    Usually the wall to the compress the front end allows you to tighten it all down while it's square.
    All I can say about this is check the bottom neck bearing to make sure the neck is not out of round.
    francoblay1 and TapioK like this.
  10. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    His head is egg shaped so why would his neck be round;)
    dentdude36 likes this.
  11. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    Some are slower than others Franco! :D :)
    francoblay1 and dentdude36 like this.
  12. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    And they will never experience this Death wobble which they speak of.
  13. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    "Slower learner's" ya hoser! :oldhardlaugh:
  14. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    [​IMG]My bus was a 4 seater, if we all sat in the back, the driver would do wheelies, Yee Haw
    cdogg556 likes this.
  15. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    :oldhardlaugh::oldhardlaugh::oldhardlaugh:
  16. francoblay1
    K9 (2006)
    Franco
    :oldhardlaugh::oldhardlaugh::oldhardlaugh::oldhardlaugh::oldhardlaugh::oldhardlaugh::oldhardlaugh::oldhardlaugh::oldhardlaugh::oldhardlaugh::oldhardlaugh::oldhardlaugh::oldhardlaugh:
    cdogg556, BWG56 and dentdude36 like this.
  17. TapioK
    TapioK Well-Known Member
    Naples, FL / Finland
    Tapio
    There is a lot of sense on Raywoods method, Push all the tolerances omn same direction, if you will. I have been riding with JR behind BBChopper, Ray ,speedo needle bottoming out. No wobble on those bikes. What little I had time to observe
    These frames are long, front is long, tolerances while making them were what they were, I bet the designer didn’t think about speed either.
    Remember those bikes on -70’s. The rear light of my Kawi mach3 looked 3 feet wide when speeding in dark, CB 750 started wobbling from weirdest reasons... where you sat, wich way and how much you leaned on seat..... sensitive beasts. On straight Honda calmed down when you were lying on top of it, face on speedo and legs on rear blinkers
    #37 TapioK, Nov 29, 2017
    francoblay1 and HMAN like this.
  18. Brandon Downey
    Brandon Downey Active Member
    Anderson, IN
    2007 Big Dog Mastiff
    Brandon
    I see it's an old thread, however after reading through it all I have never heard of fall-away. What is that?
  19. Brandon Downey
    Anderson, IN
    Brandon
    Ok thank you, I will check it out.
  20. Psycho
    Psycho Psycho
    Las Vegas, Nevada ... via ... Mesa, Arizona
    2005 BDM Chopper RT, 2005 Mean Streak
    Bruce
    I know the feeling from the 70's very well myself ... Almost had my last ride on my H1 riding it home after purchase !!!
    TapioK likes this.
