speed wobbles
Discussion in 'Help Wanted' started by Fitzy, Nov 30, 2010.
  1. Fitzy
    Fitzy Member
    Australia, sunshine coast
    08 Mutt,Dakota digital,Vance &Hines big radius pipes,oil cooler,Kp filter
    Fitzy
    Has anyone ever experienced speed wobbles on these bikes, i am interested to find out. I went for a ride today and found that any thing over 95mph the bike got the wobbles ,tyre presure front and rear wheel seem ok, on the straight it happens a little but in a turn there was nearly one less big dog biker today last time i rode it on the same road it was fine the only thing i changed on the bike was i mounted a tool bag on the front frame could this be the problem or do all these bikes handle a bit shabby at higher speed.
    THANKS.
  2. PurpleDog
    PurpleDog Well-Known Member
    Raleigh, NC
    '07 K-9; '09 Coyote
    Jim
    You shouldn't be getting a high speed wobble. I don't think the tool bag has anything to do with it - unless you have lead or some heavy Kangaroos in it maybe....:D
    I haven't taken the wifes Coyote to those speeds (similar to the Mutt) but I have the K9 plenty. I'd check your alignment and fall-away for starters. How many miles on it - bearings good I presume along with fork oil serviced as needed?
  3. BigDogBro1
    BigDogBro1 Made in the USA
    Near Hell MI
    07 Bulldog, full chrome, Pergy w/gold leaf paint, V&H BR pipes, Gator & Ostrich seats
    I get some wooble on a expressway sweeping turn at high speed when I hit a bump or expansion joint. All has been checked..fork fall away, tire pressures, etc. After having the fallaway retightened the wooble is nearly gone now. Now that I know about it I prepare for it. Check your front wheel bearings as well.
    #3 BigDogBro1, Nov 30, 2010
  4. Mickeetwo
    Mickeetwo Guru
    Texarkana, AR
    Alan
    I've had my K9 in triple digits many times and on occasion there is a slight wobble, nothing major or scary just a slight wobble if I hit a bump in the road.
  5. lee
    lee Well-Known Member
    Bristol, England
    2005 Big Dog custom build and Buell custom build
    I get it. Could be any of a number of things as already suggested - wheel alingment, tyre balancing, worn tyres, tyre pressure, front end etc. Check all these things
  6. milo
    milo New Member
    2010 Bulldog
    I got a wobble on my K-9 at about 120. I get it on my 2010 Bulldog at 100. You just get used to it.
  7. barhopper
    barhopper Another round please
    So Cal
    04 RSD Bulldog
    Not here. Been over 100 a few times and was just holding on hard to not be blown off the bike.
  8. Maxim_es
    Maxim_es Active Member
    South Dakota
    2010 K9 EFI
    I'd have to say mine is doing that, and has been since I got it. Not the best feeling in the world, especially after falling victim to a crash from it last year. Tire pressures are all good, bearings better be new, and only 560ish miles on so far. Too cold now to troubleshoot, but I'm going to test the fall-away and try tightening a little like BigDogBro1 to see if that helps. Also have dyna-beads ready to use next year incase it is a tire balance issue. Not sure what else to do other than hang on tight and hope, which isn't the most fun way to ride all the time.
  9. Raywood
    Raywood The Pirate
    Staff Member Supporting Member Calendar Participant
    Rainbow, CA
    2014 KMW Regulator
    Ray
    After doing what Lee recommended making sure the alignment is true then "square up" the front end.
    Loosen up (slightly) everything on front end from lower triple tree down. Then have while sitting on it and keeping it square have some one push you into a wall and when the front end compresses lock up the rear brake. Not front one though. Then have someone tighten everything up and let it go then go over it with a torque wrench. We have torgue values posted on here and you can search them out.
    On my long summer trip Kaptain Amerika and I were over 120 many times and pretty much averaged 95 on the whole trip after doing both our bikes this way.
    francoblay1 likes this.
  10. Five Five
    Five Five Well-Known Member
    Southern California, The 714,
    2003 pit bull (sold) & 2006 K-9 (bought)
    Bill
    Barhopper ..... the reason it blows you off your scoot is because your 7 ft tall and your chest is like a wind sail ...... you need one of those large profile windsheilds for your scoot...
    :roll::roll::roll::roll:
    I will get 1st round this time
    "five"
  11. lee
    Bristol, England
    never heard of that before :cheers:
  12. rutro123
    rutro123 Active Member
    South Jersey
    08 Big Dog K-9
    Ray
    ive had it happen on my k-9 on a long right at about 100 right after a little bump. scary feeling
  13. Krash-08Mutt
    Krash-08Mutt Member
    San Antonio, Texas
    2008 Mutt
    Krash
    I've had my mutt well north of 100 and i have never had a problem.
  14. BBChopper
    BBChopper Supports 2 Disabled Vets
    Fellsmere Fl,
    2005 BDM Choppa "Wild Fire", 2011 Electra Glide Ultra Limited "Swamp Rat"
    Pablo
    No wobble here at 120 plus, mabe it's you knee's knockin???:up:
  15. stlmikie
    stlmikie I wish I had more money.
    St. Peters
    03 Mastif
    Mike
    Mine gets the wobble. It is worse in a turn. I've gotten used to it but it stil scares fellow riders.
  16. 1wildwillie
    1wildwillie Member
    florida
    2005 bd ridgeback 2004 harley softail
    that little wobble smooths out after you get it over 100 :)
  17. Fitzy
    Fitzy Member
    Fitzy
    Thanks for your help the mutt has 2000 miles on it ill check the fall away and see how i go seems strange i did the same ride a week before at same speeds with no problem maybe somthings came loose.
  18. chopsteak
    chopsteak Active Member
    CAstle Hayne, NC
    BD Ridgeback
    I was in Myrtle Beach for the spring rally and there were about30 bikes which pulled onto 31. Everyone opened it up and so did I. That was really the only time I have "stretched" it out. My buddy on a road king blew a head gasket trying to keep up with me. Not trying to blow my horn but i did wax every Harley in that group. I went into 6th gear very close to redline and had a slight side to siderocking motion. very minimal and a slow rock back and forth. No wobble and nothing shaking in the bars. I don't have any idea how fast I was going but I remember hitting 6th gear when the speedo had just buried. I do however get a bad wobble in a turn right or left 60mph and up. It gets hairy. My 2 sometimes.
  19. surferdude
    surferdude dry docked
    Cottonwood Arizona
    05 Bigdog Ridgeback
    I don't want to find out if my 05 Ridgeback will wobble. I only had it up to 96 mph and it was solid. Jake how about your Ridgeback ... any wobbling? :confused: :job: :up:
  20. KnotSo
    Western Washington, the State
    This has happened three times, twice going over the pass on a high speed right hander, third time also on a corner, all three times the road had some imperfections in it, all around triple digits and with full camp gear strapped down.
    Spooky for sure:cheers:
