Slam Button
Discussion in 'General' started by awg, Nov 13, 2018.
  1. awg
    awg Well-Known Member
    Ohio
    2008 Big Dog Chopper, 2003 Pitbull, 2006 Mastiff
    Bought a used 03 Pitbull. Looking it over I noticed a slam button on the starter. What's the purpose? I know its to start the bike but why have one?
  2. DynoDave
    DynoDave Active Member
    Tucson, AZ
    2002 Big Dog Mastiff
    If your starter relay goes out you can still start the bike.
    pknowles likes this.
  3. Reddickracing
    Reddickracing Well-Known Member
    Louisiana
    2006 K9, 07 Streetbob
    Jeff
    I put one on my bike cause I couldn't get the bike to turn over half the time with the start button on handlebar until I got it figured out. Turns out the start button was wore and not making good contact. Its on there in case I need it again
    FukPK and pknowles like this.
  4. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    And if your EHC goes out while your on the road some where, you can put a jumper wire to your coil, and ignition module, and it might run.
    #4 Mr. Wright, Nov 13, 2018
  5. awg
    Ohio
    I see. Makes sense as a back up.
  6. liferider
    liferider Guru
    Louisiana
    Jonathan
    I put one on my H-D Ultra Classic and when I got to Sturgis 2018 it was the only way I could start it
  7. Sven
    Sven Well-Known Member
    building one
    Chopper = Remove as much as possible to lighten the bike.
    1. The wiring and cable is removed.
    2. The relay is removed.
    3. The starter switch is removed.
    4. Little things add up weight wise.
    5. Cleaner look.
    FukPK likes this.
  8. Coolbreezin
    Coolbreezin Active Member
    Northeast FL
    05 Ridgeback
    Pete
    Makes the baggers wonder why youre bending over to start yr bike...and that makes them jealous.
    Reddickracing likes this.
  9. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Up to the middle of 03, they didn't have compression releases, in these motors. It will start without activating them. Granted they went through a few starters back then. But also, the bike is programed to turn over a couple times, before it gives signal to the coil. When using the slam button, it will fire right away.
    I had an 03, with no compression releases, that we reprogrammed to fire right off, and it quit eating starters.
  10. awg
    Ohio
    So what purpose to have the bike turn over but not start?
  11. KnotSo
    KnotSo Admin
    Washington
    Sep 14, 2015
    FYI, from another in the know
    The "use" of the Slam Buttons in conjunction w/ the solenoid trigger wire still connected between the controller and starter solenoid, can cause a "back-feed" condition within the controllers and will typically burn out the start circuit within the modules.
    the slam button installs on the solenoid and just pushes the contactor down inside the solenoid, instead of the electromagnet doing it. If the starter kicks back it will not kick the slam button.
    Hence Pete saying
    I havent had that green wire connected for over a year now and all has been fine.
    http://www.bigdogbiker.com/threads/...leases-to-my-starter.73718/page-5#post-687254
  12. Butch Cassidy
    Butch Cassidy Active Member
    Fate Texas
    2000 Bulldog
    BUTCH
    Okay; I've looked and looked and ..... 'what is a slam button'...?
  13. KnotSo
    KnotSo Admin
    Washington
    SCOTTx88 likes this.
  14. Butch Cassidy
    Fate Texas
    2000 Bulldog
    BUTCH
    Thanks :) but I have a 2000 model. lol
  15. liferider
    liferider Guru
    Louisiana
    Jonathan
    I have one on my 2003 Chopper
  16. FrankBDPS
    FrankBDPS Well-Known Member
    North Lawrence,Ohio
    Frank
    I have one on my 2000 Pro Sport. Never been used.
  17. awg
    Ohio
    There you go!
  18. Nukeranger
    Nukeranger Nukeranger
    Luling, Louisiana
    Huw
    I installed mine years ago and it works fine on an 08 with 117. It would be only used if the start button doesn't work. It wouldn't be for everyday use. Just to get you around until you fix your normal start button.
    FukPK likes this.
  19. awg
    Ohio
    So you turn the key on like normal and push the slam button. And bike starts? Good backup.
    Reddickracing and pknowles like this.
  20. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Your over thinking it. Put one on and forget about it. It doesn't do anything different while it's on there. Someday you may have a problem, and you will be glad it's there.
    TapioK, tilemaster, SCOTTx88 and 3 others like this.
