Side Cover Recall Kit Question
Discussion in 'How-To' started by Brandon Downey, Dec 5, 2017.
  1. Brandon Downey
    Brandon Downey Active Member
    Anderson, IN
    2007 Big Dog Mastiff
    Brandon
    So I received my side cover recall kit today and there is a black 4-5" long gasket in the kit. Where is this supposed to go?
  2. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Below the right side cover on the edge of the rear section of the belt guard
    bigkelk9 likes this.
  3. Brandon Downey
    Anderson, IN
    Brandon
    Thank you! There weren't any instructions and a search on here turned up nada.
    bigkelk9 and BWG56 like this.
  4. Unsprung
    Ruskin, FL
    Gerald
    What’s that?
    #4 Unsprung, Dec 5, 2017
  5. Brandon Downey
    Anderson, IN
    Brandon
    It replaces the wellnuts and bolts that hold the side covers in place.
    chubs, dentdude36 and bigkelk9 like this.
  6. bigkelk9
    bigkelk9 Well-Known Member
    07 big dog k9
    Kel
    Guess mine has been done, I've always wondered why a few guys have bolts and nuts holding them things on.. them little push tab things are handy..
    chubs likes this.
  7. Brandon Downey
    Anderson, IN
    Brandon
    Yeah I am definitely looking forward to NOT have to wrestle the bolts out of the wellnuts anymore. 3 of my 4 were junk and so then the challenge became how to reach the wellnut with needle nose plyers to hold them from spinning. I finally got them all out and remembered I had read something on here about pins. Gave Derek and Donna a shout and here we go! Problem solved. Unfortunately in changing the wellnuts out and installing the red rubber mounting pieces, I discovered that 2 more of my 4 side cover mounting holes were cracked. I was however able to get the new pieces in without further damaging them. So now the test will be how they hold up with the mounting hardware in place.
    chubs likes this.
  8. Brandon Downey
    Anderson, IN
    Brandon
    Noted on the dab of lithium grease. Thanks.
    chubs likes this.
  9. Brandon Downey
    Anderson, IN
    Brandon
    You planning on keeping the side covers?
  10. Brandon Downey
    Anderson, IN
    Brandon
    I wouldn't say I need them lol. But was thinking about putting together an extra set of tins and side covers and having them painted. Then I could essentially have two different bikes by switching out the tins. That of course would be a long term project and I still have a few higher priority things to tend to first.
    chubs likes this.
  11. Brandon Downey
    Anderson, IN
    Brandon
    That's a good question. I saw Donna and Derek have new side covers for $250 and a new front fender for $185. Haven't found a new tank or rear fender yet, but seems the other dog tanks go for around $500 and the rear fenders around $100. So approximately somewhere in the $1,000 range.
    chubs likes this.
  12. Brandon Downey
    Anderson, IN
    Brandon
    Cool thanks.
  13. PROFLYER
    PROFLYER SWOLE
    Denver, CO
    06 K9, 06 Mastiff (wife's)
    Sutton
    Some 2-part epoxy on the inside of the cover where the cracks are will strengthen it. My old ones were cracked, and before I knew big dog would replaced them under warranty (this was years ago), I took them to a body shop buddy and he put some masking tape on the paint side of the holes and then put down a good glob of epoxy and let it cure. Once it was cured he drilled out the holes for the rubber grommets you show above (some of the epoxy had worked it way into the hole) and reinstalled them. They held like that for a few years before I had BD replace them.
  14. bigkelk9
    07 big dog k9
    Kel
    Already painted black? How much u want for em?
  15. bigkelk9
    07 big dog k9
    Kel
    Not trying to step on ur toes, but the k9 side covers are specific to the k9 is why I asked Kevin is all..
  16. Brandon Downey
    Anderson, IN
    Brandon
    No worries, man. My plan isn't something I can put into affect right now anyways.
  17. bigkelk9
    07 big dog k9
    Kel
    It's that same deep gloss black that both of our bikes are?? How much u want?
  18. bigkelk9
    07 big dog k9
    Kel
    I mean it' Gunna be a minute before I buy em unless someone else jumps on an first..
  19. Unsprung
    Ruskin, FL
    Gerald
    Thanks Brandon, already done on my 08 too or maybe an 08 upgrade. Glad to have it in either case.
    dentdude36 likes this.
  20. bigkelk9
    07 big dog k9
    Kel
    And thanks for half a s answering my question Kev.. geez. Take u damn Yankees back to school for reading lessons.. lmao.. Just upped the price eh..:eek:
