Shifting into neutral
Discussion in 'Technical' started by 1pos93, Mar 30, 2016.
  1. 1pos93
    1pos93 New Member
    Tucson, AZ
    2007 Big Dog K9
    I have a 2007 Big Dog K-9 with about 27,000 miles on it. I've had it since December 2014. Had all the fluids changed on it, everything is tip top. My problem is when the motor is running I am having a very hard time shifting into neutral, which makes it difficult when stuck in traffic and such and I am holding in the clutch for that long. When the engine is turned off, it shifts into neutral normally. A little hard but not that bad. What kind of adjustment can be made to fix this or what needs to be done? What is causing this? I should be able to shift into neutral much easier. Any help would be most appreciated.
    chubs likes this.
  2. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Your Introduction:dupe:
    Usually an introduction is your first post, you'll get a better response, do a search on clutch adjustment, many threads
    francoblay1, Twisted and dentdude36 like this.
  3. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    He says he's movin or something like that, blay blay blay:oldhardlaugh:I mean blah:crazybitch:
    HMAN, francoblay1, Peckerwood and 2 others like this.
  4. Sven
    Sven Well-Known Member
    building one
    Clutch steels usually warp and tag the next friction when the lever is pulled in, the N is hard to find because of the drag at both baskets still not separated enough where creep can happen or an ankle brace is needed after finding N when running. Change the warp plates. Lay all the steels in the palm of the hand and look for daylight between the steels.
    BadDawg Bill and francoblay1 like this.
  5. Knuckles
    Knuckles Active Member
    Littleton, Colorado
    '07 K9
    Switch to neutral while still rolling.
    Eduardo Hernandez and chubs like this.
  6. francoblay1
    francoblay1 The Spaniard
    L´Escala, 17130 Spain
    K9 (2006)
    Franco
    I was having lunch..... I eat too, you know... Wankers!
    chubs, BWG56, HMAN and 1 other person like this.
  7. francoblay1
    K9 (2006)
    Franco
    It´s the nature of the Beast... a quick couple blips on the throttle while pushing it up into N will do it just fine. "Practice makes Perfect" :oldthumbsup:
    Or, if your clutch is out of order, try this: http://www.bigdogbiker.com/threads/how-to-adjust-your-clutch-05-and-newer.2025/
    chubs, HMAN and dentdude36 like this.
  8. Wills67
    Wills67 Well-Known Member
    Texas Motor Speedway
    2004 Mastiff
    Mike
    Yup. I'm generally in neutral before I come to a stop. If not, I just sit there either holding the clutch or being "that guy" finding neutral, or not.... Just the way it is...
  9. mittens
    mittens Active Member
    Huntsville, AL
    2004 Chopper RT
    Harley
    I just wanted something differnt, and mine was not even that bad to find N.
    But now I have a N1 shift drum and its awesome, N all the way down. never any guesing
    chubs likes this.
  10. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    And there's no reason why the computer is not by your side while you eat, when we count on you, your MIA:oldhardlaugh:
    dentdude36 and francoblay1 like this.
  11. francoblay1
    K9 (2006)
    Franco
    Sir, Yes Sir! Your right Sir House Bitch!!!! :oldhardlaugh::oldhardlaugh::oldhardlaugh::oldhardlaugh:
    dentdude36 and chubs like this.
  12. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Tard:boing:
    dentdude36 likes this.
  13. chubs
    chubs Guru
    indiana
    2002 pitbull Prostreet --
    runky
    :oldhardlaugh::oldhardlaugh::oldhardlaugh:Ha Ha !! :oldlaugh: Ker said Tard !! :oldhardlaugh::oldhardlaugh::oldhardlaugh:
  14. Eduardo Hernandez
    Eduardo Hernandez New Member
    El Paso, Texas
    2007 Big Dog Mastiff
    Eduardo
    Man this thread is funny but informative. I am having an issue on downshifting. I can shift up with no problem but when I down shift it only drops one lower gear than the one its on. For example, if I am in 5th gear it'll drop too 4th easily but the rest I have to continue to attempt and at times it works and others it's not until last minute when I drop all the way to first. Any suggestions what this could be? Thanks in advance.
  15. Eduardo Hernandez
    El Paso, Texas
    Eduardo
    Also, I forgot to mention, when I shift up I used to be able to feel the gears click in but now it feels soft but still go in with no issues.
  16. bikeone
    bikeone Active Member
    Bavarian Forrest / Germany
    Big Dog Pit Bull / Suzuki 1100 Streetfighter
    Hans
    Check Clutch adjustment and oil in the baker rsd and primary.
    Tension of primary chain makes problems to find Neutral if its to strong adjusted..
    maybe after it will be smoother.
  17. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Sound more like you have a bearing going out. Pull the drain plug and see if there are any metal in the oil.
    Jwooky likes this.
  18. Eduardo Hernandez
    El Paso, Texas
    Eduardo
    I've done all this and it's good on shifting up but really can't feel the gears going in. On down shift, as mentioned on my initial post, it only down shifts one gear lower and the rest are a little difficult and at times won't happen until i kick them in.
  19. Brent Herridge
    Austin, TX
    2006 K9
    BrentH
    N1 shift drum ? I always wondered why all bikes didn't put N at the bottom instead of hiding it between 1st and 2nd.
    Who else has heard of this or has experience with it ?
  20. knothead
    knothead RIGID4LIFE
    Tennessee
    2 2004 big dog ridgebacks
    knothead
    Ive heard of it but dont know much about it as far as cost and all that has to be done to make it work...i got a friend that done it to his wifes bike...he didnt do it he had it done....i will check with him and see what it consist of
