SAS-99 Simplified Air Suspension ?
Discussion in 'Brakes / Suspension' started by 05chop, Nov 18, 2007.
  1. 05chop
    05chop Well-Known Member
    wyoming
    05 DT Chopper & 2010 Street Glide
    #1 05chop, Nov 18, 2007
    chubs likes this.
  2. 05chop
    wyoming
    cool who did the picture?thanks
    chubs likes this.
  3. hoat
    hoat Well-Known Member
    If you get the wiring iagram you may even be able to link it up to the stock bdm controls. The BDM one works well.
    chubs likes this.
  4. slowrower
    slowrower 2007 Mastiff
    Longwood, Florida
    BDM 2007 Mastiff
    I would be interested BDChop to hear how well it works and how you installed it like what other parts did you have to buy, can it be integrated into the BDM controller so it works like the BDM air setup. Be nice to get a response from someone that rode for a bit with no air, them added air. That system does look clean and easy to install. :up:
    chubs likes this.
  5. Tim
    Tim a.k.a. BubbleHead
    Staff Member Owner/Founder Troop Supporter Calendar Participant
    Austin, TX
    '07 K-9
    Tim
    That is a sweet set-up.
    chubs likes this.
  6. kickstart
    kickstart Well-Known Member
    TN
    52 Pan,05 Bulldog, 07 K9
    Pat
    There was a thread a while back saying that the all in one units were not the way to go because of replacement costs where the BD had seperate components which made repairs cheaper and pluged into the existing system.
    chubs likes this.
  7. 05chop
    wyoming
    YeaI like the idea that you can wire into your bdm harness.I looked over at club chopper for more info and got lost looking.:eek: 05chop
    chubs likes this.
  8. TCALZ06
    TCALZ06 Well-Known Member
    Chandler, AZ
    07 Big Dog K9
    Tom
    do all of the kits go underneath the bike in the stock location?
    chubs likes this.
  9. 05chop
    wyoming
    Yes most kits i have looked at do.Some hang down like the legends.Never have seen one on a bigdog except for the oem.05chop :cheers:
    chubs likes this.
  10. hoat
    Here are some shots of my air ride the first one is showing you the gage
    lowered I can get my little half inch finger in there
    Raised that is 1 1/8 inch socket plus about 1/4
    last is the best I could do to get some of the compressor shots in there
    when you take the shocks off of the bike you are supposed to let the wheel travel the full range of motion and make sure that you are hitting the bump stops if it hits something else then install the supplied spacers for the bump stops. I did put the spacers in anyway!!!
    pic of the shocks and the fittings that need to be removed and re tightened before installation or they will leak
    chubs likes this.
  11. 05chop
    wyoming
    Hoat the spacers your talking about do they go behind the bump stops?Does the air shock bleed down after setting for a while?
    chubs likes this.
  12. hoat
    Yeah the spacers go behind the bump stops and the unit does not blead down that much maybe 5 psi a week but I am usually out there more often
    chubs likes this.
  13. Sinister Dog
    Sinister Dog Member
    Houston, TX.
    06 Big Dog K9
    Charles aka Cal
    I have been looking for air suspension kit for my o6 k9. what kit do you have and what are the best one out there for big dog? HOAT....I like your gauge set up for the air suspension. :cheers:
    chubs likes this.
  14. scubaman15
    scubaman15 Well-Known Member
    New Kent Virginia
    2007 BDM Chopper- 2007 HD CVO
    wow talk about resurrecting a post 12-06-07 way to keep it alive:2thumbs::2thumbs:
    chubs likes this.
  15. leandean99
    leandean99 Member
    Groves, Tx
    big dog k-9
    Dino
    SINISTER DOG
    did u ever find an air suspension kit for your 06 k-9? didnt look like anyone answered your question on a kit. thanks
    chubs likes this.
  16. ronson1977
    ronson1977 Member
    South Shore MA
    2007 ZX-10R SE, 2008 Mastiff LE
    I'm interested as well. I'd like to get rid of that gross gap over the 300 on my Mastiff.
    chubs likes this.
  17. 05chop
    wyoming
    Went with the OEM BD Air ride never had any problems except if you forget to air it up won’t turn
    dentdude36 likes this.
  18. Brandon Downey
    Brandon Downey Active Member
    Anderson, IN
    2007 Big Dog Mastiff
    Brandon
    Under the battery tray.
    BWG56 and dentdude36 like this.
  19. Brandon Downey
    Anderson, IN
    Brandon
    Let me know if you need any pics.
  20. pknowles
    pknowles Getting better by the day...---... GURU
    virginia
    , 2012 CVO Streetglide, 07k9 MAKIN IT MY OWN
    paul
    Do yourself a favor. Upgrade the fittings before you do the install
