SAS-99 on 2003 BD Chopper
Discussion in 'Metal Fab' started by raeggis, May 18, 2017.
  1. raeggis
    raeggis Member
    Norway
    Big Dog chopper 2003
    raeggis
    Regarding the assembly of sas-99 on 2003 Big Dog chopper. Pin bolt on gearbox destroys assembly. Can i replace the pin bolt with 3/8 "* 1" unc machine screw?
    SEAL-rider and chubs like this.
  2. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    I don't think anyone has done this as everyone said it didn't fit.
    Pin Bolt on the transmission? Not sure I know what you are talking about never seen a Pin Bolt on a BigDog other than the Brake Caliper
    #2 Th3InfamousI, May 18, 2017
    chubs likes this.
  3. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Picture please.
    raeggis and chubs like this.
  4. raeggis
    raeggis Member
    Norway
    raeggis
    It's the bolt on the bottom of the right side I describe on transmission. Possible wrong name on this (pin bolt)
    chubs likes this.
  5. Th3InfamousI
    Texas
    It's just a hex bolt, yes? I'm not sure what you would replace it with that would be more low profile?
    chubs likes this.
  6. raeggis
    raeggis Member
    Norway
    raeggis
    I want low profile om that bolt, so i Will try to use Hexagon Socket Countersunk Screw. Screenshot_20170518-223526.png
    chubs likes this.
  7. Th3InfamousI
    Texas
    Except the hole isn't counterbored to accept this kind of bolt. You won't get much of a bite.
    How many do you need to swap out? To get it to fit?
    chubs likes this.
  8. raeggis
    raeggis Member
    Norway
    raeggis
    I will try this anyway. The head of the screw must be at the same level as the underside of the mounting plate.
    chubs likes this.
  9. raeggis
    raeggis Member
    Norway
    raeggis
    Is there anyone who can describe the problem. Will cylinders hit the gear box plate? IMG_20170601_223541.png
    chubs likes this.
  10. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Still not sure on what your doing. can you get a picture of where it goes.
    chubs likes this.
  11. Th3InfamousI
    Texas
    This unit goes in place of the shocks.
    I am nearly certain the tubes are much too big to fit regardless of bolts. We already run slim shocks on Big dogs and these air rides were made for Harley softails which can accept a larger Diameter shock.
    I believe the diameter of the shock body is going to be too large that the shock eyelets won't bolt up.
    I had an old thread on this unit and I think someone tried it and won't fit.
    chubs likes this.
  12. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Ok, I see.
  13. raeggis
    raeggis Member
    Norway
    raeggis
    I apologize for late response, but now sas-99 is mounted on my mc. Pictures show sample assembly. I will come with more pictures later.
  14. Th3InfamousI
    Texas
    Well that's neat I'm Curious what you had to do there
  15. raeggis
    raeggis Member
    Norway
    raeggis
    What was needed was to remove nut and bolt number 5 on the right side under transmission mount plate (see picture number 2) . New lining must be rotated in metal pulley.
    #15 raeggis, Aug 31, 2017
  16. Th3InfamousI
    Texas
    We're you able to replace the bolt or just now only have 5 bolts holding your transmission on?
  17. raeggis
    raeggis Member
    Norway
    raeggis
    I remowed this bolt
