RIP problems still.
Discussion in 'Technical' started by prodiver, Sep 9, 2017.
  1. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    :disappointed:
    BadDawg Bill and BWG56 like this.
  2. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Go to work:troll:
  3. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    Don't you have grass to cut or sumthin..:skep:
    BWG56 likes this.
  4. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    That's exactly what I'm gonna do today:oldhardlaugh::oldhardlaugh:
    bdm7250 likes this.
  5. BadDawg Bill
    Deltona fl
    Deplorable BadDawg Bill
    I feel your pain and wish I had an answer for you. I totally rewired mine old school and never had another electrical problem but all the other stuff (leaking front forks, bad wheel bearings, neck bearings, leaking trans, rough shifting etc) drove me nuts so I sold mine. Dogs are like beautiful women. You need to spend a lot of time and money on them or they don't preform and I'm too old for that shit.
    Big D Florida and chubs like this.
  6. prodiver
    prodiver Member
    Harley, Big Dog
    I have been riding a wrenching on Harleys for more the 50 years and I have never had a bike that is such a pia as this one. Bought it new in 06 and have had nothing but problems since.
    Big D Florida likes this.
  7. bdm7250
    bdm7250 Guru
    Doug
    Ditch the RIP, go with the ESC, you won't regret it.. You'll be lookin at your dog with new found love. :old2:
    cdogg556 likes this.
  8. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    I think he has a short:yesnod:
    bdm7250 likes this.
  9. DBO.B
    DBO.B New Member
    Germany, Bavaria
    Big Dog Chopper 2005
    Dietmar
    Hey. I do not know if I understood the case correctly. It seems that I had / have a similar issue with my new PIP Kit II from Big Dog Motorcycle, but I found out maybe sth that can help. When I changed the old EHC on my Chopper '05 (it was instable) to the new RIP KIT Version 2 from BDM, first nothing happens when turning the key switch. The issue was a small cable that was installed directly between the ignition switch and the original cabeling that reduces the power to 50% (6V). After I took this out there was power to all and the bike runs stable, but NO FUNCTION TO HEADLIGHT CONTROL and NO NEUTRAL LED. What I found out last week is : the cableing of the old backbone harness for headlight (high beam and low beam) should be connected to the pin 38 and 39 (see page 6-51 of service manual sector B PIN Identification) the old plug from backbone harness has very small visible numbers graved on the plug side. The measured connections (cabeling) shows that low Beam and high beam are well connected to position 38 and 39 in that plug BUT!!! The numbers for the positions on the plug ARE NOT THE POSITIONS ON THE HARNESS - in my case the positions are mirrored. Means position 38 and 39 in the old backbone harness plug connects when plugged to the harness to positions 45 and 46 (and 46 is an empty pin). That is the reason why my high beam control had no function. Same with my neutral LED. Maybe it is necessary to control cable by cable and pin to pin connection - just as an idea.... good luck
    Gesendet von iPad mit Tapatalk
  10. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    Just give up Douggy, nobody wants to listen anyway, just let them figure it out the hard way, spending countless hrs beating their heads against the wall trying to figure it out and then once you think you've found the issue, bam! It's back again! :oldbang: :cry: I was the same way and went through all the other bullshit, bypassing my EHC and all, finally got tired of being towed home and said fuck it and got the ESC from Doc, :old2: the rest is history!:chopper::chopper::chopper:
    BWG56 and bdm7250 like this.
  11. bdm7250
    bdm7250 Guru
    Doug
    Yup...fuk it, I'm goin riding on my thoroughly reliable mastiff..:chopper::chopper:
    BWG56 and cdogg556 like this.
  12. bdm7250
    bdm7250 Guru
    Doug
    Shouldn't talk about cdoggy that way..:oldsmile:
  13. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    I am wif ya on that one! :yesnod: Enjoy your worry free ride on that reliable Bad Ass Mastiff brudda! :whoop::whoop::whoop::chopper::chopper::chopper:
    bdm7250 likes this.
  14. bdm7250
    bdm7250 Guru
    Doug
    Thanks John, you as well...it certainly is nice not having that looming concern of being stuck on the side of the road, isn't it..:)
  15. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    [​IMG][​IMG] [​IMG]
  16. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    I often wonder what the obsession is on keeping the EHC on their bikes? It's just strange when so many of us have dumped the EHC and moved on successfully! And then all they do is bitch about what a piece of shit the bike is! Just mind boggling.
    BadDawg Bill, bdm7250 and BWG56 like this.
  17. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Easy boys, if we all had the same ESC, the roads would be over crowded with Big Dogs.:oldsmile:
    kickstart, bdm7250 and cdogg556 like this.
  18. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    You know what, your right! Then our bikes wouldn't be so special at all would they! :D ;)
  19. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Yeah Buddy:old2::whoop::chopper:
    bdm7250 likes this.
  20. bdm7250
    bdm7250 Guru
    Doug
    The world has many mysteries, this is but one of them. We have overcome our electrical problems with our bikes and offered up the same solution to others, it is their choice what they do. The bitching about how shitty BD's are is very easily ignored by me. :yesnod:
    BWG56 likes this.
