Dragonslave
Mine are threaded in the frame.
Who ya gonna find to loan a legI can assure you that the your ridgeback being a hardtail like my pitbull is nut and bolted also if you got a new kickstand make sure the mounting plate /bracket is the same there are two different ones the hard tail mounts are straight and don't have any curve on them and also the hardtails must have a shin between the kickstand bracket and the frame when I got a new kickstand I had to switch bracket and get longer bolts
No K9 motor mount is built to the frame.I wonder how much of a difference there is between the 2. If I were to make this flush like it should be, will holes for engine still line up? Isn't this the same frame(besides swingarm) as the K9?
Sent from my SAMSUNG-SM-G870A using Tapatalk
