I have read many a post stating to follow the procedure to reset your EFI if you disconnect your battery. The procedure being to turn on the key, press the run button and then turn off the key for 15 secs. But if you have the WP kit installed, the run/off switch becomes a toggles switch (no longer two separate inputs as before the WP install) and the bike is already set to run as soon as you turn the key on.
So how exactly do you perform a reset with the WP kit installed? Do you turn the key on and then off for 15 secs? Because if you hit the run button after turning the key on, the run button now acts as a kill button which now has changed the sequence to reset your EFI. Just thinking out loud.
