Replacement Gas Tank Caps (1999 Pro Sport)
Discussion in 'General' started by Soul Man, Feb 16, 2017.
  1. Soul Man
    Soul Man Member
    Florida
    1999 ProSport
    Greg
    My gas caps got stuck. Took the tanks off and was able to get the caps off, but now need new caps (old ones got destroyed in removing them).
    I have split tanks, one normal and one reverse threaded cap.
    Would http://www.motorcycle-superstore.com/42205/i/drag-specialties-chrome-screw-in-gas-caps this be the correct replacement?? Looks like they come individually. Do I order one vented and one non-vented (with vented being standard threaded and non-vented reverse threaded or vice-versa????)
    While tanks are off I'm going to clean and seal with the Caswell kit...
    chubs likes this.
  2. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    With the bike on the kick stand, the left side is lower, so you don't want that cap to vent. Yes, you do want the right one to vent.
    chubs likes this.
  3. Soul Man
    Soul Man Member
    Florida
    1999 ProSport
    Greg
    Think I figured it out, vented for the Right hand cap and non-vented for the left (with left hand threads)....
    chubs likes this.
  4. Soul Man
    Soul Man Member
    Florida
    1999 ProSport
    Greg
    Thanks Mr Wright, must have been typing as you replied. Going to order them now ;-)
    chubs and Mr. Wright like this.
  5. FrankBDPS
    FrankBDPS Well-Known Member
    North Lawrence,Ohio
    Frank
    Greg, post some pics of you're bike when you get it back together. Good luck with you're tanks.
    chubs likes this.
  6. Big Dog 44
    Big Dog 44 Member
    Austin, Tx
    2003 Mastiff
    Frank
    Will these gas caps also work on 03 Mastiff?
    Sent from my XT1585 using Tapatalk
  7. FrankBDPS
    North Lawrence,Ohio
    Frank
    If you're bike has twin tanks yes they would work.
  8. Big Dog 44
    Big Dog 44 Member
    Austin, Tx
    2003 Mastiff
    Frank
    Thanks
  9. Big Dog 44
    Big Dog 44 Member
    Austin, Tx
    2003 Mastiff
    Frank
    With those stock style gas caps, will they work with paint protectors? Or do paint protectors need to come off? For them to work?
  10. FrankBDPS
    North Lawrence,Ohio
    Frank
  11. HMAN
    HMAN Well-Known Member
    fk it
    It would appear that these caps require the paint savers to be removed. Once they are out, most HD caps will fit. Paint savers used smaller threads and dia cap. Paint savers a bitch to remove tho. They are JB Welded in!
  12. Big Dog 44
    Big Dog 44 Member
    Austin, Tx
    2003 Mastiff
    Frank
    Any suggestions on removal?
  13. HMAN
    fk it
    Do a search for paint saver removal tool. They make a plastic one, but several have made some aluminum ones that work well. A heat gun will soften the jb weld a bit, but make sure there are no fumes...!
  14. Big Dog 44
    Big Dog 44 Member
    Austin, Tx
    2003 Mastiff
    Frank
    Thanks
