Rear Wheel Removal
Discussion in 'Wheels' started by Electraglide1800, Dec 27, 2016.
  1. Electraglide1800
    oxford england
    2005 Big Dog Chopper, 2012 FLHTCUSE6, 2014 Indian Chieftain.
    Rod.
    Hi all,
    I'm trying to remove the 250 rear wheel from my 2005 BD Chopper and am stumped. I've removed the plates, bolts and belt tensioners along with the brake caliper and am now stuck. I've searched the posts on here and the internet but unfortunately any links which have been posted can no longer be found (too old perhaps?) I have a 2005 service/workshop manual which might as well go in the bin for all the information in doesn't contain.
    Any help would be most appreciated especially an exploded diagram along with ideas for correct alignment on reassembly.
    Thanks in advance for responses.
    chubs likes this.
  2. pknowles
    pknowles Getting better by the day...---... GURU
    virginia
    , 2012 CVO Streetglide, 07k9 MAKIN IT MY OWN
    paul
    did you try sticking a Phillips screwdriver in the axle and tap it lightly?
    chubs likes this.
  3. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Where are you stuck? axle removal?
    chubs likes this.
  4. Electraglide1800
    oxford england
    Rod.
    Yes, stuck at the spindle removal, due to there being a bolt on each end of the spindle I ain't sure whether it knocks through from left to right or vice versa. I don't want to set about hitting it too hard until I have all the info.
    chubs likes this.
  5. pknowles
    virginia
    paul
    Stick a wrench into each end and unscrew the bolt then the axle comes out.
    chubs likes this.
  6. Electraglide1800
    oxford england
    Rod.
    I've hit it lightly and then it feels as though it's bottomed out. Don't want to hit too hard as I can't work out whether it comes out left to right or vice versa as it has the bolts both sides.
    chubs likes this.
  7. Electraglide1800
    oxford england
    Rod.
    I've got both the bolts out but then I can't work out whether it's left to right, vice versa or don't matter. I've hit it so far but it feels like it's bottomed out.
    chubs likes this.
  8. pknowles
    virginia
    paul
    Sounds like your squish tube may be stuck. Soak it with some pb blaster and see if it moves
    chubs likes this.
  9. Electraglide1800
    oxford england
    Rod.
    I'll give it a soak
    chubs likes this.
  10. Raywood
    Raywood The Pirate
    Staff Member Supporting Member Calendar Participant
    Rainbow, CA
    2014 KMW Regulator
    Ray
    Are you sure you removed all belt tensioners. Usually two per side.
    Axle comes out drive side
    chubs likes this.
  11. Electraglide1800
    oxford england
    Rod.
    Well success, it's out. My next question is this; on the side where the brake caliper bracket sits, two thin spacers fell out. One of these spacers has a shoulder and I didn't see which way the shoulder has to face and it was or whether it was between the bracket and the wheel or the bracket and the frame.....
    chubs likes this.
  12. Electraglide1800
    oxford england
    Rod.
    All removed and now the wheel is out too...
    chubs likes this.
  13. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    The spacer with the shoulder goes toward/against the bearing in the hub
    chubs likes this.
  14. Electraglide1800
    oxford england
    Rod.
    Cheers Dude and thanks to all for their advice.....
    BWG56 and chubs like this.
  15. Ricky Massey
    Ricky Massey Member
    Ofallon mo
    2002 Bid Dog Mastiff
    Rick
    What was holding it together?
    chubs likes this.
  16. Electraglide1800
    oxford england
    Rod.
    Basically corrosion. Took some severe hammering to shift it.
    Ricky Massey, chubs and BWG56 like this.
