Rear Tire How To Change a 300 or others
Discussion in 'How-To' started by KaptinAmerika, Apr 29, 2010.
  1. Raywood
    Raywood The Pirate
    Staff Member Supporting Member Full Member
    Rainbow, CA
    2014 KMW Regulator
    Ray
    I've been told in the past to watch out for this too but never had any issues with sliding. :cheers:
  2. KaptinAmerika
    KaptinAmerika Well-Known Member
    Full Member
    2006 Big Dog K9
    Curtis
    C'mon guys help an idiot out here. Are you saying the manufacturer put a releasing agent on the tire or is it the tire installer telling you to be careful because they sprayed shit on the tire to get it on and were to busy to wipe it off?:confused:
  3. Raywood
    Raywood The Pirate
    Rainbow, CA
    2014 KMW Regulator
    Ray
    We need Micketoo to chime in here. He works for Cooper Tire that now owns Avon to give us the real scoop.
  4. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    #24 BWG56, Apr 29, 2010
  5. KaptinAmerika
    Full Member
    2006 Big Dog K9
    Curtis
    Okay got it, I suppose it could be an issue depending on the tire manufacturer I didn't see that as an issue on these particular Avon tires. Of course if you take it out right after the install in the rain then sure????
  6. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    #26 BWG56, Apr 29, 2010
  7. RRRUFF
    RRRUFF Well-Known Member
    Georgia
    2005 Big Dog Chopper
    Thanks Kaptin! I just finished installing my front tire. I used rim savers, never thought of the 5 gallon bucket. I will however invest in some decent tire irons before I try this again.
    Bdm4ever likes this.
  8. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    #28 BWG56, Jul 5, 2010
  9. scubaman15
    scubaman15 Well-Known Member
    New Kent Virginia
    2007 BDM Chopper- 2007 HD CVO
    That's real convenient that you have a tire machine :eek: I wonder how many of us have one in the garage :up::up::up: I would get stupid if I had one ...smoke a fatty anyone ???
  10. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    #30 BWG56, Jul 6, 2010
  11. scubaman15
    New Kent Virginia
    Good point ... yea I guess I could have bought a tire machine ,how much are they? ..I wish we lived closer ..a bit of trading hmmm , really I need a bigger garage !!! I was not smartin off ether just wishin my ridin buds had one of these ...cool :cheers: What creative use of the half tire rounds did you come up with ??? :lol:
  12. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    #32 BWG56, Jul 7, 2010
  13. scubaman15
    New Kent Virginia
    That is a very cool hose reel ...so cool that it might be good enough to be marketed?:2thumbs:
  14. erldawg
    erldawg Guru
    Full Member
    Raleigh, NC
    2008 K-9 EFI
    Earl
    Great How to kapn..:2thumbs:
    Yesterday I put on the rear tire. I used 2 - 15" tire irons and two rims savers. I think having 3 tire irons n 3 rim savers would have made the job easier.
    I saw this idea on the internet for making a tire bead beaker and it worked great taking the tire off and helping hold the side wall down while putting the tire on. I removed and installed the tire without any help. With that in mind I thought it would be an excellent addition to Kap's How To....:cheers:
    #34 erldawg, Aug 19, 2010
  15. erldawg
    erldawg Guru
    Full Member
    Raleigh, NC
    2008 K-9 EFI
    Earl
    Yesterday I put on the rear tire. I used 2 - 15" tire irons and two rims savers with plenty of spray cleaner for lube. I think having 3 tire irons n 3 rim savers would have made the job easier.
    I saw this idea on the internet for making a tire bead beaker and it worked great taking the tire off and helping hold the side wall down while putting the tire on. I took at 2x4 and lag bolted a 2.5' extension at the third point. The bottom of the extension I cut at 22 degrees. I was able to remove and install the tire without any help. With that in mind I thought it would be an excellent addition to Kap's How To....:cheers:
  16. Tim
    Tim Guru
    Staff Member Owner/Founder Troop Supporter Calendar Participant
    Austin, TX
    '07 K-9
    Tim
    I like this!!!
  17. Kunami61
    Kunami61 Member
    Lubbock, TX
    2008 Mastiff
    Mike
    Okay, I don't have a manual, and I am putting on my rear tire and what is the best way to measure to center the axle and how much play does the belt have?
  18. cdogg556
    cdogg556 Guru
    Full Member
    Folsom, Ca.
    John
    Changed my tire and followed your instructions and it was really easy, thanks:2thumbs:
  19. KaptinAmerika
    Full Member
    2006 Big Dog K9
    Curtis
    Very trick erldawg. I am going to revise it a bit and make one myself.
  20. kitymilk
    kitymilk New Member
    Belton, Texas
    2007 Big Dog Pittbull
    Splenda
    I just want to extend my appreciation for taking the time to share your knowledge on this issue. Though i am new to this board, i am not new to the value they hold. I know it takes more time than anticipated to put a thread together containing the information this one does. I joined this particular board today. I also know the value of the search button. So in less than 5 min. I joined the board, hit the search button, and discover why in the hell i am having a hard time getting my back tire off my pitbull. Hoping to have this project done 2 days ago...maybe it will happen today.
