R.I.P. Gen II EHC kit installed
Discussion in 'How-To' started by 2007EZ, Dec 24, 2015.
  1. 2007EZ
    2007EZ Member
    Houston, TX
    2007 Big Dog K9
    Install took about 2 hours and was a true plug and play.
    Cons:
    1. Wires are longer than original.
    2. Horn connection came off during install.
    3. Difficult to fit all wires in the original location.
    4. Wires going in to new EHC has a plastic housing. (see pictures)
    Tomtang aka Reptilejim and chubs like this.
  2. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Good job:old2:
    Does the Rip GenII have the upgraded ceramic headlight socket? and do they offer a low charging light option?
    On the last pic, what is the JST connector for coming out of the backbone?
  3. Diesel Dan
    Diesel Dan Active Member
    Sierra Nevada mountains.Extreme NORTH CALIFORNIA M
    2004 Big Dog RidgeBack 2006 Yamaha Raptor
    Danny
    Yeah......your gonna have a few tiny issue's...BUT the RIP kit is SUPERIOR in every way to the original EHC nightmare....I installed my RIP kit last winter and had a few small issues.......I called Curtis and me and him worked right threw it, I contacted Jason and spoke directly with him and Matt Moore, and told them my issue"s and they were great to deal with.........Have not had 1 single issue with it since....I think it is a great product...My bike starts every time now:)........
  4. awg
    awg Well-Known Member
    Full Member
    Ohio
    2008 Big Dog Chopper, 1980 Honda Passport, 1965 Honda Benly, 1967 Sears Sabre
    Looks like a clean install. So you pulled out the old harness from the back bone and put the new harness in? Everything works like before?
    chubs likes this.
  5. 2007EZ
    2007EZ Member
    Houston, TX
    2007 Big Dog K9
    The new kit does not have a separate connection for the headlight, it utilizes the existing wires. About the low charge light option I am not sure if that is part of the new Gen II.
    You caught me on the last pic...I was ready to take a picture of the install and forgot to connect the ignition wire. :(
    chubs likes this.
  6. 2007EZ
    2007EZ Member
    Houston, TX
    2007 Big Dog K9
    It is a clean install. Just take time to route the wires to where it fits best on the bike. I have not been able to do a full test yet...I broke the starter after the install. I ordered the new starter front mount from Curtis and should finish the putting everything back together this Saturday, then I will test all the components to make sure that it is running correctly and controls work. I ordered the replacement EHC since my micro controller locked up. My bike would drive about two blocks then shut off. I went through every connection, and troubleshot the entire charging system before sending the EHC out for testing.
    chubs likes this.
  7. roadie1389
    roadie1389 Active Member
    Full Member
    Wylie, Texas
    I heard that they where looking to keep the existing backbone harness. I got a Gen II for my Chopper and had the complete harness.
    No it does not replace the headlamp pigtail. It uses all the stock setups.
    No it does not have the charge monitor.
    Yes it uses all stock connectors and functions. Hazzards, self cancel signals, low beam out indicator.
    One thing i did not like is the starter will turn over when the key is on but the run/stop is in stop position. That i did not like at all.
    awg, 2007EZ and chubs like this.
  8. 2007EZ
    2007EZ Member
    Houston, TX
    2007 Big Dog K9
    Rebuilt the starter today and put everything back together. Today was the first time that I was able to take the bike out for a ride without it shutting off after two blocks. The bike rode great! I still have some issues that need to be resolved with the install.
    1. Speedometer does not work.
    2. Annunciator ring for RPM lights has a constant weird flicker.
    3. Left turn signal indicator doesn't work.
    4. Starter button works intermittently. If I push the button just right it will start, but could only turn over once. This is the same symptom that caused my starter to lock up in the first place.
    5. When I turn on the key the headlights are on high beam.
    6. The "Engine Stop" or "Off" doesn't shut off the bike.
    The issues that I am experiencing are new after the install. I called the guys at KMW and left a message. I am looking to get the last few issues resolved and take the bike out for a much needed ride!
  9. KaptinAmerika
    KaptinAmerika Well-Known Member
    Full Member
    2006 Big Dog K9
    Curtis
    Eric is one of my customers and I have him working directly with me so we can get his issues resolved asap.
  10. awg
    Full Member
    Ohio
    Good job.
    chubs likes this.
  11. 2007EZ
    2007EZ Member
    Houston, TX
    2007 Big Dog K9
    Thanks for the call today Curtis, you have been extremely helpful with troubleshooting and diagnosing the old EHC, starter parts/rebuild, and getting the new Gen II up and running. I took the bike out for a 15 mile ride and all issues mentioned above are resolved. The issues were only present on the initial start-up and ride. Every time I have started the bike since everything has worked correctly. Could be the bike was pissed since it hasn't been rode in over 6 months. :)
    #11 2007EZ, Dec 30, 2015
    chubs, Bdm4ever and Srodden like this.
  12. Jersey Big Mike
    Jersey Big Mike Well-Known Member
    Full Member
    Murrell's Inlet, SC
    08 K-9, 02 BMC 918ST
    Mike
    As usual, Curtis is the man!
    Srodden, chubs and Bdm4ever like this.
  13. awg
    Full Member
    Ohio
    Like I said.....good job.
  14. KaptinAmerika
    Full Member
    2006 Big Dog K9
    Curtis
    Thanks guys, slowing down lately though.
    Both hips have gone bone on bone so I am facing a hip resurface or hip replacement x 2 in the coming months.
    At the very least though the web site will stay running and I will endeavor to provide parts in a timely manner.
    SEAL-rider, Srodden, BWG56 and 3 others like this.
  15. chubs
    chubs Guru
    Full Member
    indiana
    2002 pitbull Prostreet --
    runky
    :hi: Don't rush the recovery, take it slow and easy. everyone here want's to keep ya around a while!:yesnod::old2::old2::chopper:
    dentdude36, Srodden and Bdm4ever like this.
  16. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Damn, good luck, this gettin old sux the big one:oldrant::moped:
    dentdude36 and chubs like this.
  17. miket@wattsenterprises
    Midway UT
    2008 Pitbull
    Mike
    Eric, why did you go with the gen 2 RIP rather than DOC's or the wire plus replacemnt for your ehc.
    BTW wher in Houston do you live, I am from Sugarland
    Mike T
    chubs likes this.
  18. 2007EZ
    2007EZ Member
    Houston, TX
    2007 Big Dog K9
    I went with the R.I.P Gen II kit because of Curtis at WSW, it was his recommendation, since it was new on the market. Curtis was always helpful and answered every questions I asked about troubleshooting the bike. I learned a lot during the process. I went through all the troubleshooting steps before sending out the EHC to Curtis before testing. Another thing that I liked is that the Gen II is a true plug-and-play and required no modification to fit. In previous postings I mentioned a few things that could be improved upon with this new kit. Overall I am please with how simple the install was, and that my bike is back up an running.
    Also, I live in NW Houston.
    chubs likes this.
  19. Bdm4ever
    Bdm4ever Well-Known Member
    Something Like K9
    Tony
    Great Job Eric. Glad your bike is running good now. Safe Trails.. :chopper:
    BWG56, francoblay1 and chubs like this.
  20. miket@wattsenterprises
    Midway UT
    2008 Pitbull
    Mike
    Eric, I am installing a gen 2 RIP kit on my 2008 Pitbull tomorrow, Any advise for me after you did the same install.
    Thanks
    Mike T
    chubs likes this.
