Quick Question
Discussion in 'General' started by MossBerg590, Jan 30, 2018.
  1. MossBerg590
    MossBerg590 Active Member
    Full Member
    Arizona
    06 Big Dog Ridgeback
    Tyler
    Throwing a little breather filter on the breather line from the rear head that usually goes to the air cleaner. Does it matter if it is facing up? Trying to fit it in where it won't rattle and looks nice and if Its facing up it looks pretty good.
  2. john sachs
    john sachs Active Member
    Deltona, Fl
    harleys
    Forget the filter, vent to the ground with a longer piece of hose after the black & white 1 way valve.
    John
    francoblay1 and TapioK like this.
  3. MossBerg590
    Full Member
    Arizona
    Tyler
    Do I need another check valve towards the bottom if I do that?
  4. SKOGDOG
    SKOGDOG One of the old ones.
    Supporting Member Full Member
    Pittsburg, Kansas
    2008 K9-2010 Bulldog Bagger
    Rick
    No--just route it down in the center so any oil drops will go to the ground.
  5. MossBerg590
    Full Member
    Arizona
    Tyler
    Ok cool, I'll get some longer hose then and go that route. Thanks
  6. pauly
    pauly Active Member
    Full Member
    Weeroona Island South Australia
    2008 Big Dog Mastiff, R80st.
    Paul
    What should be done with the smaller hose from the front cylinder John?
    Thanks
    Paul.
  7. john sachs
    Deltona, Fl
    harleys
  8. pauly
    pauly Active Member
    Full Member
    Paul
    Only just got your reply today John as I have been away working.
    Thank you much appreciated.
    Paul.
