Quad Seal Replacement... Is it really involved?
Discussion in 'Technical' started by Irish Viking, Jul 14, 2018.
  1. Irish Viking
    Irish Viking Till Valhalla!
    Santa Fe, NM
    2010 K-9
    Liam
    Hi all,
    So, I may have to replace the quad seal in my transmission and I have a few questions:
    -Is it possible to simply remove the pulley spacer and replace the oil seal and quad seal...without having to replace the bearings.
    -If this is possible, is it okay to do this?
    -If it is okay to do this, I assume the process would be relatively easy after removing the front pulley???
    *I am trying to keep from having to get ultra-involved in some major disassembly of the transmission, but I don't want to taka any hazardous short-cuts.
    My next questions involve parts:
    -Where can I get the oil seal, quad seal and the pulley locking kit (263-000010-00)?
    Thanks for your inputs!
    Liam
  2. pauly
    pauly Active Member
    Weeroona Island South Australia
    2008 Big Dog Mastiff, R80st.
    Paul
  3. Irish Viking
    Santa Fe, NM
    2010 K-9
    Liam
  4. pauly
    pauly Active Member
    Paul
    You're welcome Liam.
    Paul.
  5. Irish Viking
    Santa Fe, NM
    2010 K-9
    Liam
    PacoPetty likes this.
  6. pauly
    pauly Active Member
    Paul
    I haven't changed my seal before but he used impact wrench to loosen the sprocket nut
    and to tighten it back up you might be able to lock it up by applying rear brake with
    the belt already on.
    If not then you will have to lock the pulley with the locking device.
    This is from workshop manual.
  7. pauly
    pauly Active Member
    Paul
    Pulley locking tool.
  8. Irish Viking
    Santa Fe, NM
    2010 K-9
    Liam
    Looks like I will need to replace the bearing as well!
    I think the bearing just went out. A metal-on-metal grinding sound.
  9. PacoPetty
    PacoPetty Well-Known Member
    Martinsville,VA
    2006 Bigdog Pitbull
    Andy
    Spoken like a true Marine!
