Pushrod Adjustment Video
Discussion in 'How-To' started by PHATASS, Feb 18, 2011.
  1. Sven
    Sven Well-Known Member
    building one
    What they don't mention is a standard NASCAR valve setting procedure:
    Memorize the letters EOIC so the confusion is removed.
    EO = Exhaust Opens. Find where the exhaust begins to open then stop. Adjust the intake next to that exhaust.
    IC = Intake Closes. As so as you see the intake begin to close you stop. Adjust the exhaust for that cylinder only.
    Bungee cord the brake so the wheel does not turn; as the other cylinder's valve springs push the wheel backwards.
    Washer trick... The faster the event, the gain in HP.
    Signed,
    Another Pauly Prose
    francoblay1 likes this.
  2. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Gentlemen,
    I am still not happy with my valve train noise on the 117, it's much louder than the 107. I tried 18 flats 3 turns. The rear cylinder is louder than the front, not sure it quieted them up at all really.
    What's everyone else using? Should I try 3.5 then 4? Would 4 turns or 24 flats be Max?
    chubs likes this.
  3. francoblay1
    francoblay1 The Spaniard
    LĀ“Escala, 17130 Spain
    K9 (2006)
    Franco
    I (Andrew) did use 4 turns (24 flats) when he came over to do the TP to S&S conversion. I also recall reading somewhere about 24 flats.
    chubs likes this.
  4. Th3InfamousI
    Texas
    Well 24 flats is per S&S everyone else likes 18 it seems.
    BDM manual says 4 turns. I guess this lengthens the pushrod? Thus activating more of the hydraulic lifter and quieting the top end? Marv posted earlier the math arguing the 3.2 turns or 20 flats, can't argue with math which is dead middle of the lifter spring. I guess trying at 3.5 turns couldn't hurt.
    I could be thinking of this back asswards so hopefully someone can straighten out my thinking hah
    Again this is the rear cylinder only, front is much quieter.
    #44 Th3InfamousI, Apr 4, 2016
    chubs likes this.
  5. Ridgebackblues
    Ridgebackblues New Member
    Michigan
    2004 Ridgeback
    I think this question was already asked, but just to clarify... does the 107 also come stock with adjustable pushrods? Thanks!
    chubs likes this.
  6. Th3InfamousI
    Texas
    Yes all pushrods are adjustable.
    Difference is regular pushrods which require you to pull the rockers off or quickie pushrods which allow you to install them without removing the top rockers.
    A stock engine will almost always have the normal pushrods..quickies are aftermarket
    chubs likes this.
  7. Ridgebackblues
    Michigan
    2004 Ridgeback
    Thanks for the info... I wasn't sure because I had read some posts saying HD stock pushrods are non-adjustable. I'm a V8 guy so the only adjustable pushrod I've used is for "mock up" to identify the correct pushrod length in custom builds.
    Thinking my bike could use an adjustment. Just turned 15k miles, and notice some ticking during acceleration.
    chubs likes this.
  8. Th3InfamousI
    Texas
    Harley may have some none adjustable push rods on some stock builds I'm not 100% sure. but any S&S engine will be adjustable.
    Ridgebackblues and chubs like this.
