Pushrod Adjustment Video
Discussion in 'How-To' started by PHATASS, Feb 18, 2011.
  1. chacha
    chacha Chaff Your EHC!!
    2001 Nightrain, 2014 Indian Vintage, 2006 Bulldog (sold)
    Mister Fucking Wonderful
    Phatass -- Great video man! This should allow alot more folks to take care of their own adjustments -- saving them some bucks on labor.
    Well done :cheers:
    chubs likes this.
  2. PHATASS
    PHATASS Active Member
    Suisun California
    07 Big Dog K9, 13 Kawasaki Vaquero, 07 Honda Sabre 1100
    Brian
    Thank's chacha!
    chubs likes this.
  3. rca1952
    rca1952 Member
    02 ProSport
    Brian, when does one know if he need to adjust the pushrods?
    chubs likes this.
  4. PHATASS
    Suisun California
    Brian
    Haven't found a recommended time frame so most usually adjust the pushrods when thier valve train noise becomes excessive, normally around the rocker boxes.
    chubs likes this.
  5. 05 old dog
    05 old dog Well-Known Member
    liberal kansas
    05 bulldog
    billy
    alright...phatass just did this VERY simple adjustment and am totally amazed how quiet the motor is now...i actually heard my own thoughts while riding...well almost the 4 inch karata is pretty loud...any way thanks for the vid...very easy to do just allow the time for lifter bleed down...by the way i went 20 flats...very pleased...thanks again.
    chubs likes this.
  6. PHATASS
    Suisun California
    Brian
    Glad I could help :cheers:
    chubs and phatchopper300 like this.
  7. Sven
    Sven Well-Known Member
    building one
    "If I may add..."
    1. Wear increases gap. When should I reset my lifters? Depends on your oil changes. H-D comes with non-adjust rods. Are you saying they are noisy after thousands of miles, or did the wear bring the valve to open less from wear. That is the question about adjusting.
    2. If you spin 3 turns, you'll have the valves opened less than full extension.
    a. Intake opens late = Bottom end torque. Loss of O/A performance.
    b. Exhaust opens late = You are wasting time feeling for the diminishing return is about diminished you keep the valve closed longer = No top end/mid range is hurt some.
    3. Same noise quiets with solid type lifters = A wider [valve lash] gap mean 3 spins, not (4 spins out), will obviously quiet the valve noise; as does with rocker arm adjuster or shim bucket type(s).
    4. EOIC:
    a. Exhaust Opens ~ Watching this lifter move all the way up = STOP! Or, as soon as the exhaust begins to close, you stop. You stick a block into the brake lever. This drags the crank from moving the lifter back down like you saw on the well presented video.
    b. Intake Closes ~ This is the same principal, you watch the intake just begin to close, you need to STOP right there. Do not let it close any more. This is where the lowest point of the heel of the cam is set so you now set the exhaust valve.
    c. Learn to say, "EOIC" so you can look at what valve is doing what on the move? "Did my?"
    5. Now you can walk up to any OTTO engine and do your thing in the garage.
    a. I am going to say, 'flat rate' move.
    b. Notice how PHAT went from moving or watching the one pushrod, he moves to the opposite cylinder?
    c. This is so universal, EOIC means also, "My valve next to me is now look at the bike as one cylinder. I am still EO-EYE-SEA'inn [it in a ocean] of the same adjustments.
    Conclusion:
    Q. Do I set my other valve right next to me when I EOIC?
    A. Yes. If the engine was a single cylinder, would that not be the same concept of cam heel placement? Then, yes to verify the first yes.
    Q. If I can turn the crank twice, can I set all valves in a 'flat rate' move?
    A. Yes. That is speedy move or if you grasp the concept.
    Q. Then, I could have set my other intake too?
    A. Yes you could have.
    Q. You mean, I could have turned the crank 2 less times?
    A. Yes you can. Now you know what 'flat rate' means.
  8. Deathstar88
    Deathstar88 Active Member
    Poconos , PA
    2003 Pitbull
    what about the pushrod seals? should the seals be replaced as well?
    chubs likes this.
  9. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    if you are talking about the o-rings, you would have to remove the pushrods to do that and that is another whole can of worms. they would only be replaced if they are leaking.
    chubs likes this.
  10. tatajoe
    tatajoe Member
    Douglas Arizona
    06 mastiff, 2010 HD Road Glide
    Jose
    Way to go PHATASS, you've made things alot easier for me, great job!!!
    chubs likes this.
  11. tatajoe
    tatajoe Member
    Douglas Arizona
    Jose
    GREAT JOB on that video PHATASS!!! I too thank you SIR for making it easier for us.
    chubs likes this.
  12. PHATASS
    Suisun California
    Brian
    Doing your own maintenance makes owning one of these machines just a little more rewarding :cheers:
  13. spinalfever
    spinalfever New Member
    07 K-9
    Leaking oil
    Thank you for the amazing video but I have a problem. I did the adjustment everything seem to go fine went for a test ride and noticed when I got back I appear to be leaking oil out of my exhaust. Any thoughts please
    chubs likes this.
  14. chacha
    Nothing in pushrod adjustment would result in oil coming out of your exhaust.
    Is the oil coming at the very end of the pipe? 2 into 1 pipe?
    chubs likes this.
  15. Advodka
    Advodka Active Member
    Florence S.C.
    2005 Big Dog Mastiff, 2010 Street Glide
    Are you sure it's oil and not fuel mixed with your exhaust?
    chubs likes this.
  16. spinalfever
    07 K-9
    It really looked like it was coming out of where the exhaust meets the head and then running down the outer part of the pipe. I will recheck that here in about an hour and post my results. If you guys will please follow my next post I will also move this over to the help wanted section.
    chubs likes this.
  17. chacha
    pictures will help.
    chubs likes this.
  18. francoblay1
    francoblay1 The Spaniard
    L“Escala, 17130 Spain
    K9 (2006)
    Franco
  19. miket@wattsenterprises
    Midway UT
    2008 Pitbull
    Mike
    when I try to open the video it comes up as error. Did you remove it?
    chubs likes this.
  20. Srodden
    Srodden Well-Known Member
    Flint, Michigan
    2011 mastiff, 2013 deluxe
    Scott
    francoblay1, dentdude36 and chubs like this.
