Primary oiloz
Discussion in 'Transmission / Drive' started by Woody1127, Jul 31, 2016.
  1. Woody1127
    Woody1127 Member
    Indiana
    2006 K9
    Scott
    how much primary oil do I use? I thought the manual said 32oz but I drained 64
    chubs likes this.
  2. Matheny 514
    Matheny 514 Active Member
    Auburn, Alabama
    2005 Big Dog Ridgeback
    Justin
    The manual does specify 32oz in the primary. First paragraph of the attached picture.
    cdogg556, Woody1127 and chubs like this.
  3. Mr. Wright
    Mr. Wright Guru
    Supporting Member Full Member
    Salem, Missouri
    Shannon
    Check your transmission oil and make sure it didn't suck it out of there.
  4. Little-Boo
    Little-Boo Well-Known Member
    Troop Supporter Supporting Member
    McAllen, Texas
    2013 Tri-Gluide, 2006 Mastiff, several Mods to many to list
    Carlos
    You should also check the Engine oil level. If it's low you may have a bad seal at the Sprocket Shaft.
    Carlos :old2:
  5. Woody1127
    Woody1127 Member
    Indiana
    2006 K9
    Scott
    You are right on. My tranny is empty. Now what do I do?
    chubs likes this.
  6. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    The seal is bad between the trans and the primary. You'll need to pull the primary and replace the seals. Do you have a manual?
    chubs likes this.
  7. Woody1127
    Woody1127 Member
    Indiana
    2006 K9
    Scott
    Yes,I have a PDF of it. So I can just use a puller to get the out? Do you where I can buy new seals from? Thanks for your help.
    chubs likes this.
