Primary Leak
Discussion in 'General' started by Tomtang, Nov 29, 2017.
  1. Tomtang
    Tomtang Member
    Shreveport.Louisiana
    97 Goldwing and.06 black ridgeback
    Marvin
    I've had a primary Leak for some time now. Few years back phatchopper helped me with removing my.inner and outer primary. At that time I replaced all gaskets and torqued everything back to specs. Lasted awhile then started again. I really kinda worn out with it. Thinking terribly about an open primary. Maybe I'll repair it again before I pull the trigger!! Any suggestions?
  2. HMAN
    HMAN Well-Known Member
    fk it
    I found some old school brown liquid gasket maker at O'Reillys. Its helped stop my primary drips. Just my .02
    Tomtang likes this.
  3. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Aviation Gasket Sealer #3?
    That stuff is wonderful! Never hardens and just a little brake cleaner and it washes off with a paper towel.
    Tomtang and HMAN like this.
  4. HMAN
    fk it
    Cant remember the name exactly, but the same properties. Stays a bit flexible but fills the gaps. I've flat filed my outer down to the nickel and it still dribbles like an old dog. This stuff stopped that....mostly. lol.
    Tomtang likes this.
  5. PROFLYER
    PROFLYER SWOLE
    Denver, CO
    06 K9, 06 Mastiff (wife's)
    Sutton
    have you tried the new square type o-ring that Curtis sells at wild steed worx? Outter and inspection cover gasket.
    Tomtang likes this.
  6. BWG56
    BWG56 Guru
    Big Dog
    Ker
    #6 BWG56, Nov 29, 2017
    Tomtang likes this.
  7. Tomtang
    Tomtang Member
    Marvin
    Thanks Bro.
    Sent from my SM-G950U using Tapatalk
    BWG56 likes this.
  8. dentdude36
    dentdude36 Guru
    Suburbs of Buffalo NY
    2007 K9
    Kevin
    Really shouldn't need sealer on primary o ring gaskets are you sure it's not the vent or the starter leaking.
    Tomtang likes this.
  9. Tomtang
    Tomtang Member
    Marvin
    No I haven't. I bought a complete primary gasket set from Curtis in early16 or late 15.
  10. Tomtang
    Tomtang Member
    Marvin
    Checked the vent and no it's not leaking.
    I'm thinking about pulling the primary again and start and if no good results, then I'll purchased and open primary.
  11. Tomtang
    Tomtang Member
    Marvin
    Will try and find some before I spend the big money!
  12. dentdude36
    dentdude36 Guru
    2007 K9
    Kevin
    The baker open primary is very smooth, check around your starter before you pull it all apart, and as far as the vent (I know you checked it) but it allows oil out and it collects on bottom of primary there should be oil residue near and below the vent if there isn't I'd say the vent is not working(plugged) and the starter is getting oil in it.
    #12 dentdude36, Nov 29, 2017
    bdm7250 and Tomtang like this.
  13. phatchopper300
    phatchopper300 I just wanta ride
    Morganton, (Western) NC
    08 k-9 Dakota spedo, RIP Kit gen. one 585 cam 2 1/2 forward contr
    Mike
    I agree try that before you spend out the dough Or unless you've always wanted the outer primary like myself Then go for it
    Sent from my SM-N950U using Tapatalk
    Tomtang and dentdude36 like this.
  14. BWG56
    BWG56 Guru
    Big Dog
    Ker
    #14 BWG56, Nov 29, 2017
    dentdude36 likes this.
  15. Tomtang
    Tomtang Member
    Marvin
    Did you purchase the Primary? If so what kind? I think I'll take it apart again and give it another try! Thanks
  16. Tomtang
    Tomtang Member
    Marvin
    Ok thanks
  17. Tomtang
    Tomtang Member
    Marvin
    Just finished riding abit and I can see it leaking below the primary, down the length of it. Friend told it was leaking from the inner primary
  18. HMAN
    fk it
    When you do pull the outer cover, check to see if its flat? I bought a brand new cover and it had high spots all over.
    Here's what I used to stop the drip...
  19. phatchopper300
    Mike
    No I have not. Would if had the funds. I have put alot in the dog over the last 6 months and having it painted.
    Tomtang likes this.
  20. bigkelk9
    bigkelk9 Well-Known Member
    07 big dog k9
    Kel
    Mine has been leaking since the Kansas trip in June. Drives me crazy.. but after speaking to Curtis and realizing how big of a job it is.. I'll have to wait a minute before doing it.. but the vent was the first thing I checked after Eric informed me of it.. Mine is leaking between the engine and primary too..
    Tomtang likes this.
