Potential EHC Issue
Discussion in 'Ignition / Electronics / Batteries' started by mlambi01, Jan 3, 2015.
  1. mlambi01
    mlambi01 New Member
    2004 Big Dog Chopper
    I have a 2004 chopper and have been having issues with the headlight. After riding for a bit, after stopping and restarting the low beam will not stay on. High beem works and sonetimes if I flip high to low a few times it will go on. I changed the bulb, checked all connection and all looks fine. Checked the voltage regulator and that was good also. I am hoping its not the EHC, but dont know what else it could be. Any suggestions on what it could be?
  2. KnotSo
    KnotSo Admin
    Washington
  3. pknowles
    Supporting Member Full Member
    virginia
    paul
    Change lights and see if that helps. Check the socket while you are in the. Welcome from Va.
  4. Diesel Dan
    Diesel Dan Active Member
    Sierra Nevada mountains.Extreme NORTH CALIFORNIA M
    2004 Big Dog RidgeBack 2006 Yamaha Raptor
    Danny
    Had all the EXCAT SAME issues with my bike and POS EHC:(........Heres what you do.....IF YOUR SURE the headlight connector and bulb are ok, remove the gas tank,and find the headlight harness,get a DVOM (Digital Volts Ohm Meter) hook it up the harness,use a piercing lead that will pierce the positive lead for either side, hi or lo beam..........Turn your bike on and watch the voltage:)..........If it is full 12 volts then all of a sudden its gone,its your EHC,and it has lost the driver circuit for the headlight:(......
    That's what happened to me............Kept trying to fool myself myself to think it was something else,it wasn't...........EHC took a shit...........Rewired my bike with a EHC RIP KIT from Curtis...................Everything fine now:):cheers:......
    GoodLuck.............as usual....Keep us posted how it go's..........I'am crawling back into my bottle of Sangria for the weekend..........
    francoblay1 likes this.
  5. BadDawg Bill
    Deltona fl
    Deplorable BadDawg Bill
    Get ready for an old school rewire... the only way out...
  6. KaptinAmerika
    KaptinAmerika Well-Known Member
    Full Member
    2006 Big Dog K9
    Curtis
    No its not Bill, for you maybe but not for everybody...:roll::roll::roll:
  7. mlambi01
    mlambi01 New Member
    Thanks Diesel, I was fooling myself too. Is RIP the way to go, or has anything else come out that might be better and easier?
  8. Diesel Dan
    Danny
    The EHC RIP KIT is the best Plug in kit there is:).......The replacement controller is built by ThunderHeart and is bullet proof:cheers:.........and the wiring harness that comes with it is pre-wired,color coded,and has the correct JST connectors to plug right into the secondary harness's.........Simply remove EHC, remove gas tank and backbone harness......Install new module and hook up your new harness....plugs right in..........I did mine with a fractured right hand and two broken fingers.......easy kit......Call Curtis from Wild Steed Worx on here,he will hook you up:2thumbs:...........
  9. Jwooky
    Jwooky Well-Known Member
    Full Member
    Oxford, MI
    2008 Mastiff EFI
    JJ
    If it's only the headlight driver, you could simply hard wire it though a switch.
  10. Fat_Bastard
    Fat_Bastard Active Member
    Full Member
    Route 66
    2004 Big Dog Chopper, HD Fat Boy
    Title: "CRO" , Chief Riding Officer, SoCal riders group
    I AGREE PER ABOVE:
    My Story if it helps...
    I have a 2004 Big Dog Chopper.
    This is how I determined that my EHC was bad.
    My "EHC" symptoms are (happened in 2010):
    a) months ago Low-Beam started to intermittantly go out; had to use Hi-Beam only; All else was OK.
    b) got New Battery and trickle charged every night. Problem went away two months ago.
    c) one month ago Low-Beam out again, Hi-Beam only; bike randomly just lost all power to spark plugs while riding; continued to quit electricaly (no spark, but other lights, horn, turn signals OK, but no Hi-or-Lo beams) Let it sit by side of road for ten minutes then could start and ride it home. (I knew no spark by carrying spare spark plug I connected and held to side of cylinder while cranking.) no signs of weak new battery. All else was OK.
    d) rode home, checked voltages:
    on same New Battery: 13.5 while on charger, 13.1 off charger; 12.5 dip at startup cranking; started engine --running it charges immediately to 14.2 volts, seems OK. But no Headlight at all.
    e) Checked Headlight voltages at bulb connecter:
    Yellow wire 10.5, White 7.5; with key ON or engine running. (of course checked/swapped bulbs and jumper wired temporarily off battery to be sure all were working ok).
    f) Pulled Connecter to Headlight under gas tank and measured same exact voltages as at Headlight connector; Yellow wire 10.5, White 7.5; Checked ignition wire 12.1 volts.
    I think this means my EHC is bad --cannot get 12 volts out of the EHC to headlight... other wires out of EHC read 12+ volts...
    I can only ride with no headlights for 9 miles or fifteen minutes and bike quits per item c) above.
    ONLY Solution at the time 2010: the Wire-Plus-374 unit. Running GREAT SINCE THEN!
    As of this date 2015, probably do what "Diesel Dan" suggests...
    "Kaptin America" is a good guy to help too! :2thumbs:
  11. mlambi01
    mlambi01 New Member
    Thanks F.B. looks like I'm replacing the EHC
  12. Diesel Dan
    Danny
    Its easy bro:flag:...........When u get ready to do it,send me a PM,I will help ya anyway I can,call ya on the phone or whatever,Gotta get your bike up and running man:2thumbs::2thumbs:!!!!!!!!!
  13. francoblay1
    francoblay1 The Spaniard
    Full Member
    LĀ“Escala, 17130 Spain
    K9 (2006)
    Franco
    Be Careful with that Sangria!!!!!!!! :roll::roll::roll:
  14. francoblay1
    Full Member
    K9 (2006)
    Franco
    As KnotSo mentioned b4....
    Check THIS out :up:
  15. Guillaume
    Guillaume Active Member
    Baytown Texas
    K9 2007
    Guillaume
    What a great site, if you bike has a issue go on this site and you on the road again , love it
  16. mlambi01
    mlambi01 New Member
    Thanks Diesel, I will keep you posted
  17. cdogg556
    cdogg556 Guru
    Full Member
    Folsom, Ca.
    John
    I know, he need's "Axel's EHC!" [​IMG]
    dentdude36 likes this.
  18. cdogg556
    cdogg556 Guru
    Full Member
    Folsom, Ca.
    John
    [​IMG] [​IMG]
  19. Reddickracing
    Reddickracing Active Member
    Full Member
    Louisiana
    2006 K9, 07 Streetbob
    Jeff
    Man all these EHC post make me sick! 06 K9 with the factory EHC and I cringe and hope it runs everytime I ride it LOL. I know its a timebomb. Wonder sometimes should I change it or just go with until it happens.
  20. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Ride it until or if the electric gremlins show up, then worry about changing it.
    cdogg556, Forsaken and Reddickracing like this.
