plugs
Discussion in 'General' started by njbiker20088, Feb 5, 2019.
  1. njbiker20088
    njbiker20088 Active Member
    monroe nj 08831
    lsc iron horse, gold wing, 1500 intruder
    al
    Is this bs or not
    PacoPetty likes this.
  2. Jersey Big Mike
    Jersey Big Mike Well-Known Member
    Murrell's Inlet, SC
    08 K-9, 02 BMC 918ST
    Mike
    Here's a test done by someone.
    njbiker20088 likes this.
  3. francoblay1
    francoblay1 The Spaniard
    L´Escala, 17130 Spain
    K9 (2006)
    Franco
    Somebody tried them on the Dog? C´mon, it should be interesting to know from first hand.
    :chopper:
  4. kickstart
    kickstart Well-Known Member
    TN
    52 Pan,05 Bulldog, 07 K9
    Pat
    Thought they were going to darken the room :), what plugs were the OE plugs? My .02 Snakeoil
    Big D Florida, njbiker20088 and chubs like this.
  5. KaptinAmerika
    KaptinAmerika Well-Known Member
    2006 Big Dog K9
    Curtis
    We're certainly going to buy a set and test them to see.
    Just wish we had a damn Dyno to do true constructive testing.
    If you could show that type pf gain then the price of them, really high, would be worth it.
    Anyone out there feeling generous after winning the lottery.....lol.
    But then theirs nothing quite like real world testing for a street motor.
    Champions, which are what S&S recommends.
    While expensive we run E3s in all our customer's rides locally.
    I also use them in all my equipment and vehicles.
    The biggest advantage we receive in our shop, beyond customer's noticing an easier start and smoother idle, is anytime a customer comes in with a poorly tuned ride, that's missing etc, we throw a set of E3s in the motor before the test ride so we know for a fact we won't foul one or worse two plugs while we're out. For some reason E3s do not foul. I've had lawn equipment that I stupidly forgot to run the fuel out of after use and left for a couple of months then tried to start with E3s and they never foul. Can't say that with standard plugs in the equipment. The equipment rarely starts because of the bad fuel but the plug never fouls either. I imagine you could make E3s foul but I suspect it would have to be so extreme that the motor won't start or stay running. I'm not interested enough in knowing that limit to ruin a set....lol.
  6. KaptinAmerika
    2006 Big Dog K9
    Curtis
    For those interested the Pulstar # for the 117 is HE1H10. Tried looking it up on line but nothing came up so I called Pulstar.
    We'll have two in the shop in a couple of days and we'll let everyone know the results.
    njbiker20088 and Rottweiler like this.
  7. KaptinAmerika
    2006 Big Dog K9
    Curtis
    I can already tell everyone, just from general searches and reviews, that I do not expect much from these plugs.
    The lowest price I could find is $14.95, dramatically higher then E3s on average and much lower reviews than E3s receive.
    We'll have them in a couple of days though and will post back here after testing.
  8. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    I'll second the opinion on E3 spark plaugs.
    I was fouling champions at one point in less then 300 miles and the bike dying (o2 sensor issue). Put E3's in, fouling stop and bike ran, changed the O2 sensors and never looked back.
  9. aspen874
    aspen874 Well-Known Member
    Saint Louis, MO
    07 Mastiff 2010 Bulldog Bagger
    Stephen
    I have to ask what are E3 plugs?
  10. SB03chopper
    SB03chopper Active Member
    St. Louis, Mo.
    2003 Big Dog chopper, 2004 Honda 1800 R vtx
    Steve
    On the E3 plugs what is the number for them. I am interested in trying to see what happens.
  11. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    E3 is one of the companies that make an advanced spark plug. https://e3sparkplugs.com/diamondfire-electrode/
    Others like the Bosch fusion do similar things to try and get a better spark.
    I can only attest that for me and my K-9, they have worked exceptionally well, and made the bike ridable when it wasn't (due to fouling).
  12. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    e3.36 is for the 117" (ie a autolite 4164/ Champion RA8HC replacement). https://e3sparkplugs.com/parts/?part=E3.36&cr=1
    O'reilly and Advanced Auto etc carry these -- look where small engine spark plugs are usually to find them. They run around $6-7
    Big D Florida and francoblay1 like this.
  13. SB03chopper
    St. Louis, Mo.
    Steve
    Thanks mine's the 107, so I'll pull my RN12YC and see what they match up with.
  14. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    The site has a lookup tool and even knows about Big Dogs as a brand!
    francoblay1 likes this.
  15. Rottweiler
    Rottweiler Well-Known Member
    Elizabethtown, PA.
    2004 Chopper, 2014 HD Road King CVO, 1985 FXWG
    Todd
    I have always run Champion in my 107 never had any problems. Might try the E3's ? Can you post the number if you find it? 2004 / 107
  16. Rottweiler
    Elizabethtown, PA.
    Todd
    #16 Rottweiler, Feb 7, 2019
