Overtightened primary drain plug
Discussion in 'Fluids!!' started by Thisguyisthelimit, Mar 27, 2017.
  1. Thisguyisthelimit
    Oahu
    2005 Big dog chopper
    Travis
    So I went to drain my primary and realized the drain plug was so overtightened from the last guy that it's stripped. Is this going to cause some issues in the near future? How do I get it out of there?
    chubs likes this.
  2. liferider
    liferider Guru
    Louisiana
    Jonathan
    The HeliCoil product portfolio includes - Genuine HeliCoil Product Range available as HeliCoil Wire Thread Inserts - Free Running Inserts & Screw Locking Inserts, HeliCoil inserts of Nimonic 90, Nitronic 60, Titanium alloys, Inconel X-750, Phosphorus Bronze, and various other Space Age Metals, in addition to the standard range of HeliCoil available in 18-8 Grades of Stainless Steel such as SS-304, SS-316 and DTD 734. Also available are variety of Thread Repair Kits - HeliCoil Professional Kits, HeliCoil Master Kits, HeliCoil After Market Kits, HeliCoil Insertion Tools, HeliCoil Thread Taps, HeliCoil Thread Plug Gauges, HeliCoil Extraction Tools, HeliCoil Manual Tang Break off Tools, HeliCoil Automatic Spring Loaded Tang Break off Tools and Semi-Automatic & Automatic equipment for HeliCoil installation.
    Genuine HeliCoil products
    Helicoil Thread Repair Kit - Professional
    [​IMG] [​IMG]
    All HeliCoil Thread Repair Kits including the Professional Thread Repair Kits are used for creating stronger internal threads in all metals, composites, polymers and other materials by repairing damaged or stripped internal threads and regaining the original thread size. HeliCoil Thread Repair Kit creates longer lasting durable threads, avoids thread over-sizing, increases the possibility of higher torque application in weaker metals, significantly reduces the bolt breaking problems & HeliCoil being made of stainless steel protects against atmospheric corrosion. HeliCoil Professional Thread Repair Kits include everything required to do the job right – good number of inserts each of 3 lengths (short, medium & long) for multiple applications, HSS drill bit ,Finishing tap, installation tool and tang breaking tool – all in a rugged new box. These kits are available in metric range from M2 to M12 and in UNC/UNF range "4-40 to 1/2”.
    Helicoil Thread Repair Kit - Master
    [​IMG] [​IMG]
    HeliCoil Master Thread Repair Kit once again contains everything required to do the job right – good number of inserts of standard length (1.5D), HSS drill bit, Finishing tap, installation tool and tang breaking tool – all in a rugged box. These kits are available in metric range from M14 to M20, M24 upto M36 and in UNC/UNF range 9/16” to 1-1/2” .
    Helicoil Thread Repair Kit - After Market
    [​IMG] [​IMG]
    HeliCoil After Market Thread Repair Kits are available in economy packs with all basic tools required to perform a thread repair. Each kit has a finishing tap, installation tool, a good quantity of 1.5D length of inserts, tang breaking pin and complete instructions. These kits are available as selective range in metric from M4 to M20 and in UNC/UNF range 8-32 to 1/2”.
    Helicoil Free Running Inserts
    [​IMG] [​IMG]
    HeliCoil standard range is available in Stainless Steel AISI-304/ DTD734, metric series ranges from M1.6, M2 to M56 & in unified series from UNC / UNF 1-64 to 1-1/2 inch. HeliCoil is also available in strip feed or reel mounted form, HeliCoil in strip feed form are best suited for significantly reducing the installation time using power tool for installation of inserts.
    HeliCoil Inserts or Wire Thread Inserts are made of cold rolled 18-8 grade Stainless Steel to AS7245 , MIL-I-8846 & DTD734 specifications. This wire is cold rolled to a diamond cross section producing an ultimate tensile strength of approximately 1375-1725 MPa, mirror like surface finish of 2-4 Microns and flank hardness of RC 43-50 which is far in excess of the usual tapped materials and best suited for most of the industrial needs. HeliCoil Inserts can also be supplied in other materials such as SS-316, Inconel X-750, Titanium Alloys, Nimonic 90, Nitronic 60, Phosphorus Bronze, Beryllium Copper and with special coating and plating requirements such as Cadmium plating, Silver plating, Zinc plating, Nickel plating
    chubs and Thisguyisthelimit like this.
  3. Thisguyisthelimit
    Oahu
    Travis
    Thank you
    chubs likes this.
  4. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Well you should be able to get it out with an easy out and the threads are probably fine.
    I'm guessing your saying that the plug is stripped. BTW it's actually a T30 star bit...not an Allen key
    Big D Florida and chubs like this.
  5. Thisguyisthelimit
    Oahu
    Travis
    The head of the bolt is stripped.
    chubs likes this.
  6. Matheny 514
    Matheny 514 Active Member
    Auburn, Alabama
    2005 Big Dog Ridgeback
    Justin
    Can you attach a picture for us to see?
    chubs likes this.
  7. liferider
    liferider Guru
    Louisiana
    Jonathan
    BOLT??????????? Yeah, we need a pic of this!!!!
    chubs likes this.
  8. Thisguyisthelimit
    Oahu
    Travis
    Maybe bolt was the wrong terminology. The plug is stripped out to a perfect circle. Can't loosen it.
    chubs likes this.
  9. SKOGDOG
    SKOGDOG One of the old ones.
    Pittsburg, Kansas
    2008 K9-2010 Bulldog Bagger
    Rick
    Access is an issue. On mine, we put it on a lift, secured the front end, and jacked up the rear end until we could get at it, and used a hammer to drive in either a star or an Allen. That worked.
    I think someone on this forum described a time when he had to lay his bike on a blanket on the grass outside in order to get at the underside...it sure would give you an advantage over trying to get it out with only four inches between the plug and the ground.
    chubs and Unsprung like this.
  10. pknowles
    pknowles semi-retired...---... GURU C7Z06...---...
    virginia
    paul
    Jack the bike up enough to get a drill under it. Use a 1/8th drill bit and very carefully drill up thru the center of the plug. Then you can screw it out with an easy out. A right angle drill motor works really well.hope this helps. If you use this method flush the primary with a little oil before putting the new plug in. Most of the chips will or should hang on the magnet attached to the top of the plug.
    Big D Florida, chubs and bdm7250 like this.
  11. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    Could always open your inspection cover and use an evacuation pump to get most of the fluid, then remove outer primary and work on getting the drain plug out while its on a bench.
  12. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    :agree:Why not just take the cover off, clean up the mess and work on it on your work bench where you can easily get access to it.
    PROFLYER, Viking, RRRUFF and 4 others like this.
  13. kickstart
    kickstart Well-Known Member
    TN
    52 Pan,05 Bulldog, 07 K9
    Pat
    Plus 1
    chubs, bdm7250 and BWG56 like this.
  14. RRRUFF
    RRRUFF Well-Known Member
    Georgia
    2005 Big Dog Chopper
    Do you like guru said it is a lot easier. On a side note, If the threads are messed up and you decide to put a pipe plug in it be very careful. The pipe plug is tapered and will crack the housing if you over tighten. Try to stick with the original o-ring design.
    chubs and BWG56 like this.
  15. Viking
    Viking Biker
    Florida
    A much easier job than screwed up threads. Like some suggest above, take the cover off and work on it while on a bench. A drill and an easy out will have that plug out in no time. New plug can be had from Donna.
    Olde Man and chubs like this.
  16. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    The Kaptin has new plugs. I started replacing every one I run across, that's starting to look bad.
    http://bigdogbiker.com/data/banners/wsw.gif
    The threads on the plug are 1/8''-27 straight pipe. Same thread as a pipe nipple, just the threads are straight not tapered.
    PROFLYER and chubs like this.
  17. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    :old2:
    bdm7250 and chubs like this.
  18. pknowles
    virginia
    paul
    I was assuming he didn't want to go that deep into the repair. It's really easy with the drill.
  19. PROFLYER
    PROFLYER SWOLE
    Denver, CO
    06 K9, 06 Mastiff (wife's)
    Sutton
    Order a new plug from wild steed werx. A large easy-out will turn that out of there. I found one that's just a bit larger than the hole, tapped it in there gently and then turned it out and replaced the plug. It's got a torque spec of like 16ftlbs or something like that--it's really low. You just need to set that plug, not tighten the crap out of it.
    chubs and pknowles like this.
  20. bdm7250
    bdm7250 Guru
    Doug
    Not everyone has your outlook on "easy"..just sayin..:oldlaugh:
    chubs and PROFLYER like this.
